Make Life Accessible
  • Make Life Accessible
Blog EyePrints - Post 15 - The plotter
  • Author Author: amgalbu
  • Date Created: 17 Jun 2016 3:25 PM Date Created
  • Views 817 views
  • makelifeaccessible
  • python
  • eyeprints
  • servo
  • make_life_accessible
amgalbu
amgalbu
17 Jun 2016
Previous posts
Post 1 - Introduction
Post 2 - Installing OpenCV - Prerequisites
Post 3 - Installing OpenCV
Post 4 - Installing Pygaze
Post 5 - Installing eye tracker
Post 6 - SPI communication
Post 7 - SPI communication in Python
EyePrints - Post 8 - Getting started with Kinetis
EyePrints - Post 9 - Mechanical design
EyePrints - Post 10 - Mechanical design: the plotter
EyePrints - Post 11 - Eye tracker software
EyePrints - Post 12 - Getting started with the kit
EyePrints - Post 13 - KDS Project
EyePrints - Post 14 - The drawing board
In this post, I will show some pictures and video of the plotter
The plotter has a servo that can lift the pencil when the painter wants to move to another area without drawing anything on the board
The servo is controlled by a small Python script
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(11,GPIO.OUT)
pwm=GPIO.PWM(11,50)
To put down the pencil, the start method of the pwm object is invoked
pwm.start(7)
pwm.start(0)
To lift the pencil up, the start method of the pwm object is invoked with different values
pwm.start(5.5)
pwm.start(0)
Both values (7 and 5.5) has been determined empirically. The second invokation of the start method (pwm.start(0)) is required to "stop" the servo. The PWM signal generated by the Rapsberry Pi is not very stable, so the servo keeps on correcting its position. The pwm.start(0) function prevents the servo from moving continuously around its final position
Here is the plotter with the pen in the "up" position
And here is the pen in "down" position
Finally, here is a video of the plotter in action
    DAB over 10 years ago
    I am not sure that gravity alone will work, but it would be easy to spring load the pen.
    Have you determined the useability levels for the eye tracking?
    I am curious just how much control you end up with.
  • amgalbu
    amgalbu over 10 years ago in reply to DAB
    Hi DAB
    Gravity alone actually seems to work bit let's see what happens when drawing on a inclined plane
    Regarding the usability, I am just starting experiencing bit it seems I wiil have to analyze the fixation point. Current approach makes it very difficult to calibrate pupil position
    Cheers
    Ambrogio
  • amgalbu
    Hi DAB
    Cheers
    Ambrogio
