Pi Chef Design Challenge
  • Pi Chef Design Challenge
Blog The Spice of Pi - Blog Doug 8
  • Author Author: dougw
  • Date Created: 1 Mar 2018 4:52 AM Date Created
  • Views 2341 views
  • Likes 10 likes
  • Comments 10 comments
  • doug wong
  • spice of pi
  • pi chef design challenge
  • pi chef
dougw
dougw
1 Mar 2018
I have finally assembled the complete mechanical system. Both the carousel rotation mechanism and the jar lifter mechanism have been mounted on the bamboo base plate. The video below shows the first operation of the complete mechanism.
Hopefully the PCB I designed at the beginning of the project will arrive soon so I can get the electronics build completed.
And then it is on to the software....
Design Challenge Links:
About the challenge
The other challengers
The kit
Terms & Conditions
Summaries by Charles Gantt
Project Links:
Blog Doug 1 - The Concept
Blog Glenn 1 - AIY Voice Kit Unboxing
Blog Doug 2 - The Block Diagram and Bill of Materials
Blog Doug 3 - Spice Jar Lift Mechanism
Blog Glenn 2 - Firmware Considerations
Blog Doug 4 - Carousel Design
Blog Doug 5 - Platter Rotation Mechanism
Blog Doug 6 - 3D Printed Platter Parts
Blog Doug 7 - Main Drive Assembly
Blog Doug 8 - Working Carousel
    genebren over 8 years ago +2
    Doug, Great job! I don't know if I am having a slow internet day, or if there is a problem with your video, but I could not get past the 10 sec mark of your video. I will try again later. Gene
  • three-phase
    three-phase over 8 years ago +2
    Nice video showing the operation. I also had a problem viewing in within the blog, I got to 15 seconds and it then stopped, but it played fine when viewed directly on Youtube. Kind regards
    dougw over 8 years ago in reply to three-phase +2
    If problems persist, I will reload the video.
    DAB over 8 years ago
    Good starting point.
    You might get some issues with fuller jars due to the change in momentum with the extra mass.
    You might also need some additional gearing to get the torque levels more consistent for a smoother rotation.
