Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Sci Fi Your Pi: PiDesk - Project Update #9
  • Author Author: fvan
  • Date Created: 10 Jun 2015 12:02 PM Date Created
  • Views 2415 views
  • Comments 21 comments
  • design_challenge
  • touch_motion_controls
  • sci_fi_your_pi
fvan
fvan
10 Jun 2015
Previous posts for this project:
  • Sci Fi Your Pi: PiDesk - Project Description
  • Sci Fi Your Pi: PiDesk - Project Update #1
  • Sci Fi Your Pi: PiDesk - Guide: Setting Up the Raspberry Pi 2
  • Sci Fi Your Pi: PiDesk - Project Update #2
  • Sci Fi Your Pi: PiDesk - Review: Bare Conductive Touch Board
  • Sci Fi Your Pi: PiDesk - Project Update #3
  • Sci Fi Your Pi: PiDesk - Guide: Stepper Motors with Gertbot
  • Sci Fi Your Pi: PiDesk - Project Update #4
  • Sci Fi Your Pi: PiDesk - Project Update #5
  • Sci Fi Your Pi: PiDesk - Guide: Controlling NeoPixels with the Raspberry Pi A+/B+
  • Sci Fi Your Pi: PiDesk - Project Update #6
  • Sci Fi Your Pi: PiDesk - Project Update #7
  • Sci Fi Your Pi: PiDesk - Project Update #8
  • Project Update
Project Update
Ikea desk meets multitool. There's not much more to say about it, enjoy the picture gallery and be sure to check the description image
Hope you like the result so far!
{gallery} Ikea desk meets multitool
Desk & Multitool: The desk I picked for the project and the multitool I planned on using to carve out futuristic shapes with.
Sketch: Sketched where the different components like Pi, buttons and futuristic shape for LED strip would be.
Tape: Used tape to better visualise the shapes and serve as reference when cutting.
Internals: That's what the inside of a cheap Ikea desk looks like. A block in each corner to screw the legs to and a cardboard mesh for the rest.
Cutting: Cutting using the multitool was rather easy, but tricky at times where the blade was larger than the shape to cut out.
Done: Most of the cutting work done, waiting for the final dimensions of the screen before cutting out that part.
Test: A quick test to fit the Pi and LED strip and have a look at the result. Once the final LED strip arrives, it can be installed. In the mean time, I'll be testing various diffusors.
    Jan Cumps over 11 years ago +3
    Seems you didn't buy the massive oak version of the desk
    shabaz over 11 years ago +3
    Interesting what is inside the desk! Nice use of materials for low cost yet reasonable rigidity. As one idea, 0.5mm thick white acetal ('Acetal C Natural Sheet' also known as ' Ertacetal/POM C' ) is a…
    Jan Cumps over 11 years ago in reply to shabaz +2
    ...with a lego brick height between the display and the sheet No kidding! You can actually see the 4 Lego bricks.
    As one idea, 0.5mm thick white acetal ('Acetal C Natural Sheet' also known as 'Ertacetal/POM C') is a milky color that could show LEDs through it - and is available is large sheets (2mx1m) that could cover the entire desk surface and is easy to cut to size.
    Here it is with a mobile phone (Galaxy S5 set to full brightness) pressed against it:
    And here it is with a lego brick height between the display and the sheet:
  • fvan
    fvan over 11 years ago in reply to shabaz
    Thanks shabaz, I'll be going to the hardware store this weekend, see what assortiment they have.
    I also heard something on the radio about 15% off of everything bought on Saturday, so that's an added bonus image
  • fvan
  • michaelwylie
    michaelwylie over 11 years ago in reply to fvan
    Will you be using any 2.50 coins? image
    shabaz over 11 years ago in reply to fvan
    Hi Frederick,
    I don't have photos of it any more, but I remember doing a similar thing in black once, to make a clock face. Basically there were LEDs behind perspex, but in-between was a clear plastic sheet that had been printed with black everywhere, and a dotted pattern where the light was to pass through. It kind-of worked, but probably for a table white works better. Another idea (for any color) could be the perforated vinyl type stuff for vehicle or store window graphics as seen here:
    Perforated Window Film | Sign & Digital Graphics
    I've no clue if it would be effective, I've never tried it.
    So many ideas, so little time to try them all : )
  • fvan
    fvan over 11 years ago in reply to michaelwylie
    Was not sure what you meant. Searched for "2.50 coin" and come across this: Belgium Commemorates Waterloo With a Coin, and France Is Not Pleased
    Didn't even know that existed image
