Upcycle It
  • Upcycle It
Upcycle It
Blog [Upcycle It] Interactive Race Car Driver - Car modification
  • Author Author: Workshopshed
  • Date Created: 15 Apr 2017 1:16 PM Date Created
  • Views 926 views
  • interactiveracecardriver
  • upcycle_it
  • upcycled_interactiveracecardriver
Workshopshed
Workshopshed
15 Apr 2017
My main concerns about the car were the high driving position and general space for the electronics. There were some handy screws on the front and back so I though those would make good points to attach my own platform. There is also a bit of flex in the chassis now so my additions will need to include re-enforcement.
{gallery} Car Modifications
Before: The car base
Step 1: After removing the battery box the platform was still quite high
Stripped: So I stripped it down even further
Driver: New lower driving position
Edison: There should be space in the engine compartment for the Edison
Disaster and repair
Although I'd previously thought that the gearboxes were fine, I noticed that one of the wheels was freewheeling whereas the other side turned as a pair. I opened up the gearbox again and spotted that one of the pinions was rotating freely on it's axle. When I removed it, it split into two.
I looked through my collection of gears and found a replacement, except it was connected to another gear. I sawed it off with a junior hacksaw and it fitted onto the spindle. It was a little loose so I added some cyanoacrylate adhesive (superglue).
Now my vehicle is back on the road and ready for some new electronics.
Previous Posts
[Upcycle It] Interactive Race Car Driver - Plan of action
[Upcycle It] Interactive Race Car Driver - Software
[Upcycle It] Interactive Race Car Driver - Lights
[Upcycle It] Interactive Race Car Driver - Detailed Plan
[Upcycle It] Interactive Race Car Driver - Edison
[Upcycle It] Interactive Race Car Driver - Drive Motor Testing
    DAB over 9 years ago +1
    Great fix in the true engineering spirit. DAB
  • jasonwier92
    jasonwier92 over 9 years ago +1
    I like the Frankenstein it is becoming. Using the servo to "lean" into a corner would be cool.
    shabaz over 9 years ago
    Hi Andy!
    Very cool to see the Edison becoming mobile : )
    This stuff is really neat by the way (although it looks like you didn't actually need it for your particular gears):
    <p>Loctite 770 primer</p><p></p><p>Loctite 770 primer</p><p></p>
    It makes the superglue stick really well to some plastics, I used it on gears which I think were nylon, and it worked well.
    Hi Andy!
  • Workshopshed
    Workshopshed over 9 years ago in reply to shabaz
    Thanks, I'll definitely check that out. Nylon is notoriously difficult to glue.
