    • Avnet Boards Community
Project Videos
  • Project Videos
Project Videos
Documents Arduino-powered Hexadecimal Color Code Clock -- Episode 466
  • Date Created: 29 Sep 2020 7:31 PM Date Created
  • Last Updated Last Updated: 2 Oct 2020 7:24 AM
  • Views 3586 views
  • Likes 8 likes
  • Comments 8 comments
In the socially-distanced, work-from-home apocalypse of Southern California, clocks have become obsolete as time has become essentially meaningless. After months of no longer using an alarm clock, Matt has missed the simple act of checking the time--even for curiosity's sake--and decides to build a clock that measures the passage of time in a completely novel way: by converting hours, minutes, and seconds into hexadecimal values and displaying the relative color value associated with that time. It's certainly not the most practical chronometer in the world, but this hexadecimal color code clock proves that form doesn't always have to follow function!
Supplemental Content:
  • How To Read Hexadecimal Numbers
  • How Do Hexadecimal Color Codes Work
  • How To Build An Arduino Clock
  • How To Build A Battery Backup Real Time Clock
  • Driving LED Displays With Arduino And MAX7219
  • How To Set Up A TFT Screen On Arduino With The RA8875
  • Project ColorTyme Code and Design Assets
Bill of Material:
RTC IC, Date Time Format (Day/Date/Month/Year hh:mm:ss), I2C, Serial, 4.5 V to 5.5 V, DIP-8 MAXIM INTEGRATED PRODUCTS 1 Buy Now
IC & Component Socket, 8 Contacts, DIP Socket, 2.54 mm, 7.62 mm, Copper Alloy AMPHENOL ICC 1 Buy Now
Battery Holder, Coin Cell - 20mm x 1, Through Hole KEYSTONE 1 Buy Now
Through Hole Resistor, 10 kohm, MCCFR0W4J Series, 250 mW, ± 5%, Axial Leaded, 250 V MULTICOMP PRO 2 Buy Now
Crystal, Cylinder, 32.768 kHz, Cylinder Radial, 6.2mm x 2mm Dia, 6 pF, 20 ppm, CFS206 Series CITIZEN FINEDEVICE 1 Buy Now
AC/DC Power Supply, ITE, 1 Output, 9 V, 1 A PRO ELEC 1 Buy Now
DC Power Connector, Jack, 2.1 mm, Chassis Mount MCM 1 Buy Now
DC Power Connector, Plug, 11 mm, Cable Mount, Panel Mount, Wire Lead MCM 1 Buy Now
Alphanumeric LED Display, Red, 20 mA, 2, 13.7 mm, 1.9 V BROADCOM 3 Buy Now
LED Driver, 4V to 5.5V input, 8 Outputs, 10 MHz Switch. Frequency, 4.5V/320 mA out, DIP-24 MAXIM INTEGRATED PRODUCTS 1 Buy Now
IC & Component Socket, 24 Contacts, DIP Socket, 2.54 mm, 7.62 mm, Phosphor Bronze TE CONNECTIVITY 1 Buy Now
Protoboard, Epoxy Paper, 1.5mm, 100mm x 160mm CIF 1 Buy Now
Arduino Uno ARDUINO 1 Buy Now
Through Hole Resistor, 220 ohm, MCCFR0W4J Series, 250 mW, ± 5%, Axial Leaded, 250 MULTICOMP PRO 1 Buy Now
Premium Male/Male Jumper Wires, 40 x 3" (75mm) ADAFRUIT 1 Buy Now
Tactile Switch, MCDTS-2 Series, Top Actuated, Through Hole, Plunger for Cap, 260 gf, 50mA at 12VDC MULTICOMP PRO 2 Buy Now
Switch Cap, Multicomp Pro MCDTS2 Series Tactile Switches, Ivory, CAPS For MCDTS2 Series MULTICOMP PRO 2 Buy Now
Battery, 3 V, 2032, Lithium Manganese Dioxide, 225 mAh, Pressure Contact, 20 mm PANASONIC 1 Buy Now
DISPLAY, LCD TFT, 5", 800X480, LANDSCAPE MIDAS 1 Buy Now
3D PRINTER FILAMENT, PLA, 1.75MM, WHITE MULTICOMP 1 Buy Now
Toggle Switch, On-On, SPDT, Non Illuminated, 2MS1 Series, Through Hole, 100 mA MULTICOMP PRO 1 Buy Now
RA8875 Driver Board for 40-pin TFT Touch Displays - 800x480 Max ADAFRUIT 1 Buy Now
Additional Parts:
Product Name
40 conductor ribbon cable
element14 presents
element14 presents  |  About Matt |  Project Videos
  • diy arduino clock
  • arduino uno
  • mcm
  • hexadecimal clock
  • arduino rtc
  • e14presents_airbornesurfer
  • arduino hexadecimal clock
  • pro elec
  • hexadecimal color code clock
  • real time clock
  • tft display
  • rtc
  • amphenol
  • diy clock
  • matt eargle
  • friday release
  • color clock
  • multicomp
  • maxim
  • KeyStone
  • arduino color clock
  • adafruit
  • friday_release
    DAB over 4 years ago +3
    Fun build. Well done. DAB
  • lorrainbow
    lorrainbow over 4 years ago +3
    Love love this project! I want to make a giant clock for my workspace and am definitely nabbing this idea.. maybe not as complicated! I'm thinking of giant 7 segment numbers with the hour numbers changing…
  • davedarko
    davedarko over 4 years ago +2
    I have this huge RGB lamp, would have to hack it - but then one of my walls could be a clock! Nice. I'd start with red in the morning and fade slowly to blue over the day.
  • davedarko
  • airbornesurfer
    airbornesurfer over 4 years ago in reply to davedarko
  • airbornesurfer
