Project Videos
  • Project Videos
Project Videos
Documents Gigantic 3D Printed 7 Segment Display Clock -- Episode 482
  • Date Created: 21 Jan 2021 6:17 PM Date Created
  • Last Updated Last Updated: 22 Jan 2021 8:24 AM
  • Views 9475 views
  • Likes 18 likes
  • Comments 18 comments
Lorraine wanted a clock for her workshop, but given she’s an element14 video content producer it wasn’t going to be any old clock! Follow Lorraine as she puts her own spin on a 3d print to create a unique timepiece you’ve never seen before. This is the first part of two videos about this clock. In the second video Lorraine will go through the different boards and the clocks potential different uses including an exercise stopwatch.
Supplemental Content:
  • 7 segment display clock by lorrainbow
  • The Learning Circuit 53 - How to Drive a 7-segment Display
  • NanoDrive your 7-segment display by luislabmo
  • Episode 476: IoT Arduino NTP World Clock with SPI Display
  • Episode 466: Arduino-powered Hexadecimal Color Code Clock
  • Cat Commander iot Clock and Kibble Dispenser by fmilburn
  • A Crystal Clock with 1 Transistor - the Pierce Oscillator by Jan Cumps
  • (Modified) Work Clock by dwinhold
  • Spectrum Clock by maxpowerr
  • NeRDPACk - No RTC DigitPad Alarm Clock by nmccloud
  • SunPathClock by bernhardmayer
  • BulbDial - A Tale of a Sundial without the Sun by wolfgangfriedrich
  • Engineerish - Build a HUGE 7-Segment Display!
element14 presents
Giant 3D Printed 7 Segment Display Clock
element14 presents  |  About Lorraine |  Project Videos
  • clock
  • rainbow clock
  • e14presents_lorraineunderwood
  • neopixels
  • 7 segment display
  • 7-segment display
  • lorraine underwood
  • e14presents_lunderwood
  • friday_release
  • maxpowerr
    maxpowerr over 5 years ago +5
    It would be interesting to see the new Raspberry Pi PICO. In addition, it already has built-in RTCs.
  • davedarko
    davedarko over 5 years ago +4
    Wonderful project It might help to add some height to the segments and maybe make it 5 instead of 3 LEDs per segment. When I was working for a copy shop, I had access to rolls of "backlight" paper that…
  • lorrainbow
    lorrainbow over 5 years ago +4
    Vote for which board I should use to code the clock here! Or add a comment below https://www.element14.com/community/polls/3247
    beacon_dave over 5 years ago
    You could perhaps try edge-lighting the frosted acrylic or alternatively put a reflective material in the base of the segments to bounce the light from the LEDs off of first to diffuse the light more and reduce the hot spotting. May need to increase the number of LEDs as Dave has already suggested.
    beacon_dave over 5 years ago in reply to beacon_dave
    John Park demonstrates a method for getting good diffusion with large 7-segment displays here:
    Assemble Panels | Ninja Timer: Giant 7-Segment Display | Adafruit Learning System
    May be of interest / worth giving it a try.
    Video on YouTube demonstrating the effect of distance vs diffusion here:
    https://youtu.be/WUU8AQsf2Zw?t=156
    (skip to 02:30 to see the test stand)
  • lorrainbow
    lorrainbow over 5 years ago in reply to beacon_dave
    Thanks Dave. I saw John's video after mine, he's such a pro! Great ideas for getting the diffusion right.
  • lorrainbow
