WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Learn Three Ways You Can Create Bode Plots - Workbench Wednesdays 64
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 9 Nov 2022 6:10 PM Date Created
  • Last Updated Last Updated: 23 Nov 2022 8:24 AM
  • Views 24013 views
  • Comments 19 comments
Creating a bode plot from a simulation (or transfer function) is easy. But what if you want to create a bode plot for a REAL op-amp circuit or filter? One way is to measure a few parameters with an oscilloscope and function generator and then put those into a spreadsheet. Another is to use network analysis or frequency response analysis to do it automatically!
Watch the Video:
Supplemental Content:
  • Workbench Wednesdays 42: Compare Ideal vs. Real Filter with an LCR Meter
  • Workbench Wednesday 17: Instrument Basics: Function Generator
  • Workbench Wednesdays 54: How Oscilloscope Acquisition Modes Work
  • Workbench Wednesday 18: Digilent Analog Discovery Review
  • Workbench Wednesdays 49: Instrument Basics: Vector Network Analyzer (VNA) with PicoVNA
  • DC to Daylight 13: How Operational Amplifiers Work
  • The Learning Circuit 68: How Op Amps Work
  • Voltage Feedback Op-Amp Gain and Bandwidth App Note
Bill of Material:
LM358 - Audio TI 1 Buy Now
TL081 - JFET General Purpose, 4 MHz SOIC-8 ST Microelectronics 1 Buy Now
Bench Oscilloscope - 200 MHz, 1 GSa/s, 14-bit, AFG, DMM Multicomp Pro 1 Buy Now
[Bundle] Development Kit, Analog Discovery 2 Pro Bundle, 30MHz Oscilloscope, 12MHz Waveform Generator Digilent 1 Buy Now
MXO4 - 4 Channel Oscilloscope 200 MHz Rohde & Schwarz 1 Buy Now
element14 presents
element14 Presents  |  About James|  Workbench Wednesdays
  • bode plot
  • network analyzer
  • Network analysis
  • oscilloscope
  • function generator
  • frequency response analysis
  • FRA
  • scottiebabe
    scottiebabe over 3 years ago in reply to jc2048 +3
    I think BE just had bad luck with the intern/murphy . The TL081 spice model doesn't include any capacitance on its input, let alone the parasitic capacitance on a breadboard. Green: No cf, Red: Cf…
  • jc2048
    jc2048 over 3 years ago in reply to baldengineer +1
    Here's a possible theory you might test. The TL081 has a pair of offset pins which you appear to have left unconnected. As well as using them to adjust the offset, which you wouldn't need to worry about…
  • baldengineer
    baldengineer over 3 years ago in reply to scottiebabe +1
    Cool! My plan is to solder a duplicate circuit to a perfboard (with generous solder) and do the sweep/plot again when I talk about how to automate the measurement in python (for those that don’t have an…
  • scottiebabe
    scottiebabe over 3 years ago in reply to baldengineer
    That sounds wonderful! Being able to automate your measurements is a game changer for sure!
    To clarify the reason I didn't see the issue nearly as pronounced as you had was because the breadboard was doing me a favor!
    I got this capacitor for free:
  • baldengineer
    baldengineer over 3 years ago in reply to rsjawale24
    Until FRA options came out, I was never happy with the function generators built into a scope, unless you could get the option for free. (I always thought the budget was better spent on either a standalone unit or just something else!)
    But having the integrated source AND measurement is a fantastic measurement package.
  • baldengineer
    Cool! My plan is to solder a duplicate circuit to a perfboard (with generous solder) and do the sweep/plot again when I talk about how to automate the measurement in python (for those that don’t have an FRA option on their scope.)
    But your way sounds more fun.
  • scottiebabe
    I tried your circuit with a TL072 (don't have a 071) and got a substantially different results, the gain peaked maybe 5-10%.
    So I was intrigued to dig a little deeper. I had the bend the output pin up and solder the one leg of feedback resistor to demonstrate the effect.
    Again, great episode!
  • baldengineer
    baldengineer over 3 years ago in reply to baldengineer
    And by "me," of course, I mean The Intern.
  • baldengineer
    Gosh. It's almost like there was a reason I made sure to attach the TL081 model I used. Slight smile  (Not sure if you used that one or another. I think I got that one from TI.)
    I found just 5 pF got a similar result. (I had a Cf cap at one point too.) Enough to realize what was going on.
    I knew the prolific members here would likely catch this one. But it did throw me for a few minutes.
    DAB over 3 years ago
    Another great episode.
  • scottiebabe
    I think BE just had bad luck with the intern/murphy. The TL081 spice model doesn't include any capacitance on its input, let alone the parasitic capacitance on a breadboard.
    Green: No cf, Red: Cf=4pF
    On the LM358 the output and inverting input pins are adjacent so you get the breadboard row-row capacitance a helpful bonus by introducing a zero to help counteract the pole created in the feedback network from capacitance to ground.
    If the peaking problem disappears with smaller feedback resistors say 1kOhm, then the gain was likely peaking due to capacitance on the inverting input node (reducing the closed loop phase margin).
  • baldengineer
    On the LM358, there was peaking with X1 probes. The TL081 peaked with both X1 and X10.
    I'll give the output a little more scrutiny next time I'm in the lab. You have me curious about what I missed. I had several setups going on, so I might be mixing up scenarios.
  • scottiebabe
    The output waveform shouldn't dance around. I think if you look at an FFT of the output, the amplitude of your test tone will be the correct amplitude. And, you will also see and there is also something else present. I don't know if its oscillating at a lower frequency...
    If you were to probe your op-amp's output with a 1x scope probe, the measured bode plot with gain peaking is entirely plausible. But, I am pretty sure you are using 10x probes.
    Still, I blame the intern Slight smile and great video!
    *had to delete to edit*
