Op-Amp-a-Palooza
  • Op-Amp-a-Palooza
Op-Amp-a-Palooza
Blog Project14 | Op-Amp-a-Palooza: Win an Op-Amp Kit for Your Op-Amp Project!
Join Op-Amp-a-Palooza to participate - click to join for free!
  • Date Created: 15 Feb 2022 4:44 PM Date Created
  • Views 33733 views
  • Likes 20 likes
  • Comments 56 comments
  • opampsch
  • opamps
tariq.ahmad
tariq.ahmad
15 Feb 2022
In the Comments Below:   Let Us Know Your Op-Amp Project Ideas for a Chance to Win an Op-Amp Kits
The Most Mind Blowing Op-Amp Project Wins an Op-Amp Testing Kit:
image image image
Buy Now Buy Now Buy Now
Op-Amp-a-Palooza is an open ended exploration of op-amps using low cost components and features premium op-amp testing equipment as prizes. There's so much that can be done with OpAmps: Amplifiers and buffers, measurement, active filters, voltage references, current measurement, audio vs RF vs HT, precision circuits low noise circuits making one from discrete components.   This contest features Op-Amp components from Maxim, Renesas, and Microchip.    To win a op-amp kit let us know your op-amp project proposal in the comments below.   You are also free to use whatever components you choose for your op-amps project.
Submit Your Projects Here or Tag Your Blog opampsch:
Submit Entry
Check out our essentials series to learn more about Op-Amps:
  • Op Amps I: Low Power Op Amps
  • Op Amps II: Specialty Op-amps for High Voltage and Precision Applications
  • Op Amps III: Audio Op Amps
{tabbedtable}City Team
The Kit
If you have a project proposal based on any of the following components then submit a comment below for a chance to win an Op-Amp Kit from Renesas, Maxim Integrated, and Microchip:
Audio Power Amplifier MAX98357AETE+T image Buy Now
Operational Amplifier MAX40075ANT+T image Buy Now
Current Sense Amplifier MAX44284EAWT+T image Buy Now
Class D Audio Power Amp MAX98390EVSYS# image Buy Now
Operational Amplifier MAX40100ANT+T image Buy Now
Current Sense Amplifier, 2 Amplifier MAX40201FAUA+ image Buy Now
Zero Drift Operational Amplifier ISL28134IBZ image Buy Now
Operational Amplifier ISL28230FBZ image Buy Now
Micro-Power, RRIO Zero-Drift Amps  ISL28233FRZ image Buy Now
Operational Amplifier, Dual, 2 Amplifier, 61 MHz, 17 V/µs, 2.85V to 3.5V, SOIC, 8 Pins ISL28291FBZ image Buy Now
Operational Amplifier, Single, 1 Amplifier, 2 MHz, 1 V/µs, 1.8V to 5.5V, MSOP, 8 Pins ISL28213FUZ image Buy Now
Current Sense Amplifier, Micropower, 1 Amplifier, 6 µA, SOT-23, 5 Pins, -40 °C, 125 °C ISL28006FH50Z-T7 image Buy Now
Operational Amplifier, 1 Amplifier, 1 MHz, 1.9 V/µs, 1.8V to 5.5V, SOT-23, 5 Pins MCP6006T-E/OT image Buy Now
OPAMP, 1MHZ MCP6007-E/MS image Buy Now
Operational Amplifier, Single, 10 MHz MCP6291T-E/OT image Buy Now
MSOP DUAL 10 MHZ OP MCP6292-E/MS image Buy Now
Operational Amplifier, Single, 14 kHz, 1, 0.003 V/ s, 1.4V to 6V, SOT-23 MCP6041T-I/OT image Buy Now
Operational Amplifier, 2 Amplifier, 14 kHz, 0.003 V/µs, 1.4V to 5.5V, DIP, 8 Pins MCP6042-I/P image Buy Now
Operational Amplifier, Single, 1 Amplifier, 10 kHz, 0.004 V/µs, 1.8V to 5.5V, SOT-23, 5 Pins MCP6031T-E/OT image Buy Now
Operational Amplifier, RRIO, 2 Amplifier, 10 kHz, 4 V/ms, 1.8V to 5.5V, MSOP, 8 Pins MCP6032T-E/MS image Buy Now
Operational Amplifier, Single, 300 kHz, 1, 0.13 V/ s, 1.8V to 5.5V, SOT-23 MCP6V31T-E/OT image Buy Now
OPAMP, 300KHZ MCP6V32-E/MS image Buy Now
The Prizes
The most mind blowing Op-Amp Project Wins the Following Op-Amp Tool Kit:
The Grand Prize:
image image image
3 First Place Winners:
image image image
Here are some projects to inspire you:
image image
The Learning Circuit 68: How Op Amps Work The Learning Circuit 69: OpAmps Project: Build an Amplified Stereo Mic Kit
image image
Workbench Wednesdays 39: Op Amps Without Op Amps Episode 537: Build a Phonograph Preamplifier - How Hard Can It Be?
image image
Op-amp made from Discrete Components by fmilburn Playing with an OP 191 Op Amp by jw0752
image image
Op Amps - The Norton CDA by jc2048 Op Amps: NIC (Negative Impedance Converter) and the Chua Oscillator by jc2048
image image
Experimenting with Op Amps: Input Offset Voltage by jc2048 Smart Coin Sorter by Inductive Sensing. #03 Experimenting with Op Amp Colpitts Oscillators by javagoza
Your Chance to Win
Be Original
Stick to the Theme
  • You could come up with a clever name that make's your project memorable!
    • This project is your baby! Part of the fun of bringing something new into the world is coming up with a name.
  • Your project could introduce something new or that is not commercially available or affordable!
  • If you have an idea for a project that doesn't fit the current theme then submit your idea in the comments section of the monthly poll.
List the Steps
Submit Video Proof
  • Provide the steps you took to complete your project (text, video, or images).
    • This could be a step by step how-to-guide, vlog, schematics, coding, napkin drawings, voice narration, or whatever you think will be useful!
  • If it doesn't work that's fine, this is more about the journey than the end product.
  • A short video is all that is required but you can shoot as much video as you like.
  • You are encouraged to be creative and have as much fun as possible!
Your Project Examples
Op-Amp-a-Palooza
Smart Coin Sorter by Inductive Sensing. #03 Experimenting with Op Amp Colpitts Oscillators   by javagoza Op-amp made from Discrete Components by fmilburn
Your Prizes
One Grand Prize Winner Wins an Op-Amp Testing Kit plus a $200 Shopping Bundle Three First Place Winners Win  an Op-Amp Testing Kit plus a $100 Shopping Cart
  • One Grand Prize Winner Wins an Op-Amp Testing Kit (Arbitrary Waveform Generator , Bench Power Supply , and Handheld Oscilloscope  ) plus a $200 Shopping Cart!
  • 3 First Place Winners a Win an Arbitrary Waveform Generator , Bench Power Supply , and USB Oscilloscope ) plus a $100 Shopping Cart!
image image
Some Terms & Conditions Apply:  How to Redeem Your Shopping Cart for Project14
Your Project, Your Ideas!
About Project14
Directions
Every month you'll have a new poll where you'll get to decide an upcoming project competition, based on your interests, that will take place a couple of months in advance. Themes are broad in scope so that everyone can participate regardless of skill set.
What are Monthly Themes?
  • Every month (around the 14th of each month) a new theme will be posted on Project14.
  • Submit your ideas (proposals) for your projects to get feedback from the rest of the community.
  • Submit a project entry in the Theme space once you start working on it.
What are Monthly Theme Polls?
  • Every month (around the 14th of each month) there is a project theme poll.
  • Vote on which project competition you want to see for the following upcoming theme.
    • The themes voted on during the previous poll decided the upcoming theme.
    • If you submit an idea for a theme that is not used then it can still be used in a future poll.
  • Themes comments and ideas from the comments section of the project theme poll.
Visit:  Op-Amp-a-Palooza  or tag your project blog opampsch
You have until April 27th End of Day to submit your completed project!
A jury consisting of your peers will judge project submissions!
  • rsjawale24
    rsjawale24 over 4 years ago +1
    I had planned to make this project long back. Finally, it's time to implement it. Opamps are fun and have lots of applications. I plan to make an audio spectrum visualizer using active filters based on…
    dougw over 4 years ago in reply to robogary +1
    With one op-amp you can make a 3rd order Pafnuty Cebyshev band-pass filter. One of my favorites... How is that for dropping a name? It is interesting that some filter books are now on-line: https…
  • javagoza
    javagoza over 4 years ago in reply to fmilburn +1
    You have nothing to apologize for. The mistake was mine that I wanted to imagine that. On the board it is clear that all servos receive the same signal. If I had "read" the board carefully I wouldn't have…
  • rsjawale24
    Opamps are fun and have lots of applications. I plan to make an audio spectrum visualizer using active filters based on opamps. The idea is to split the audio signal (20 Hz - 20 kHz) into 3 sub-bands (Bass, midrange, and the treble). I'm choosing to use an opamp with good unity-gain bandwidth (up to 1MHz) such as MCP6006T-E/OT.
    The audio input signal is first amplified using a preamp (based on general-purpose opamp) , then using 3 opamps, 3 active filters with cutoff frequencies as shown in the picture are designed. The output of the active filters will drive 3 different colored LEDs. The picture below gives a basic overview of the complete project.
    audio-spectrum
  • robogary
    robogary over 4 years ago in reply to rsjawale24
    Nice project, 3rd order butterworth filters ???  :-)     I just like the sound of saying 3rd order butterworth filter, like I know what I'm talking about...... ROFL !
  • robogary
  • rsjawale24
    rsjawale24 over 4 years ago in reply to robogary
    Haha!
    The order of the filter is determined by the number of poles (each pole corresponds to one order). In my case, I'm designing three different filters. Filter designing is really interesting, you get to learn a lot of analog electronics while experimenting with filters.
  • robogary
    Yes, the 3rd order filter has a real steep cutoff and needs alot of components, thats why I joked about it.  Notch filters are pretty interesting.
    With one op-amp you can  make a 3rd order Pafnuty Cebyshev band-pass filter. One of my favorites...Alien
    https://www.tinaja.com/ebooks/afcb.pdf
    http://dsp-book.narod.ru/PADFD.pdf
  • rsjawale24
    rsjawale24 over 4 years ago in reply to dougw
    The opamp just acts as a the active element. The filtering is still done by passive elements (RC or LC filters) also the order is controlled by the number of independent reactive elements.
    Those books seem interesting. Will refer them while building the project.
  • robogary
    robogary over 4 years ago in reply to dougw
    I hadnt heard that name in 40 + years. I'm having long buried homework recall episodes
