Legacy Personal Blogs Electromechanics - Basic Principles and Connector Design Explanations
  • Author Author: sleuz
  • Date Created: 29 Jan 2013 10:10 AM Date Created
  • Views 739 views
  • basic_principles
  • connector_design_explanations
  • connector_application
  • material_requirements
  • electromechanical
sleuz
sleuz
29 Jan 2013
Basic Principles and Connector Design Explanationsimage
Extracts from Würth Elektronik´s Trilogy of Connectors for any help on your electromechanical solutions. Check out the documents below for requirements, applications and general information.
Electromechanics - Basic Principles and Connector Explanations
more design and application guidlines
Basic Principles
A connector is an electromechanical system which provides a separable connection between two subsystems of an electronic device without an unacceptable effect on the performance of the device. It will be shown that there are a lot of complex parameters to handle properly to make this statement true.
Extract ...
Passives  - Basic Principles, Components and Applications
Basic Principles
Components
Applications
Design / Selection / Assembly
This extract provides an overview of design and material requirements for contact finishes, contact springs and connector housings as well as the major degradation mechanisms for these connector components. Material selection criteria for each will also be reviewed.
Extract ...
More solutions to various areas of the electronic scene
Balunless measurement
Power Inductors
USB Port Protection
LED driver
Forward Converter
Effective EMI Shielding Concepts
Level of Interconnection
Levels of Interconnection addresses where the connector is used within an electronic system. The location of the connector in the system influences the environmental exposure and the assembly/mating durability requirements the connector must support. These factors, in turn influence the type of connector which will be used for a given application.
Extract ... 
Appendix
This last chapter will put into practice some of the previous theories in order to give you a practical aspect of connectors’ applications. It will go into further detail regarding assembly processes, power application and packaging.
Extract ...
