Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog MagI³C Power Modules
  • Author Author: Würth Elektronik
  • Date Created: 22 Jan 2024 1:21 PM Date Created
  • Views 9212 views
  • design in
  • layout review
  • thermal design
  • interface free power supplies
  • emc filter
  • magi³c_power_module
  • dc/dc conversion
Würth Elektronik
Würth Elektronik
22 Jan 2024
MagI³C DC/DC Power Conversion
The design of interference-free power supplies is by no means trivial and ties up scarce development resources. Integrated power supply modules that can be easily inserted into an application as a ready-made solution provide a remedy here. Such a power module represents the evolution of a discrete DC/DC voltage converter. All discrete components including controller IC, transistors, diodes, inductors and small capacitors are integrated into one package. All the following design steps, which are necessary for a discrete DC/DC converter, have already been performed in a MagI³C power module:
  • Design of the DC/DC converter itself
  • Select the topology
  • Select the controller IC
  • Calculate and select the power parts (MOSFET, Diode, Inductor)
  • Calculate and select the input and output capacitors
  • Test bench development
  • Optimization for stable regulation over the entire input/output voltage and load current range
  • Layout routing for good EMI and thermal performance
  • Validation of the overall design for easy manufacturing
  • Pre compliance tests for EMI and safety
  • Logistics chain and production security
MagI³C power modules allow application developers to simply select a module based on the electrical specifications of the application and get rid of all the design steps mentioned above . Therefore, a power module enables design engineers to speed up the process of integrating a power supply into their system compared to a conventional discrete DC/DC converter design.
The DC/DC power modules offer a high power density solution in a small footprint.
More background information about MagI³C power modules can be found in the “ABC of Power Modules” or in the Farnell Online Shop.
Service & Support
Do you have questions or suggestions on the topics of design-in support, PCB layout review, EMC filters or thermal design? We will be happy to help you!
With just a few details, we can answer your enquiry.
Contact us
Design-In Support
  • Product related & application specific support by hotline
  • Troubleshooting and individual design solutions
Layout Review Support
  • Individual review of customer layouts
  • Reference layout given in every datasheet
EMC Filter Design Support
  • Solution for conducted & radiated emissions
  • Tested filter configurations for EN55032 / CISPR-32 class B compliance
  • Real EMI behavior shown as well as gain and phase response of EMI filter shown on REDEXPERT
Thermal Design Support
  • Temperature distribution
  • Total power handling
  • Thermal behaviour of power modules as well as interactive power loss chart shown on REDEXPERT
Videos / Webinars
Videos
Würth Elektronik Videos from #askLorandt_explains:
  • MagI³C Power Modules as LED driver Evaluation board practical demonstration
  • Multi Color LED Driver with MagI³C Modules
  • Current sharing with MagI³C Power Modules
Videos from third parties:
  • Zap Netzteil mit Step-Down-Modul Boom Kann das funktionieren?
  • Atari 2600 restaurieren Champagne Es geht weiter!
  • How to make your own Night Vision Device!
Webinars
  • MicroModules - DC/DC Step-Down Converters f. Space-Constr. Applications
  • MicroModule design-in made easy - Tips and tricks
  • Improving the EMI performance of isolated power modules
To get behind the magic of the MagI³C Power Modules:
  • Frequently Asked Questions
  • Basic Knowledge - Isolated MagI³C Power Module Masters the 24V Industry Bus
    • Selection Criteria and Voltage Ranges
    • Wide Voltage Range – Input Voltage Limits
    • Minimum Input Voltage – Lower Limit
    • Maximum Input Volgate - Upper Limit
    • Power Boost Feature
  • See simulations in REDEXPERT®
