FPGA
FPGA
Blog Learning Vitis: Build Environment Quickie 1 - See forever!
  • Author Author: drozwood90
  • Date Created: 30 Apr 2020 3:14 PM Date Created
  • Views 1049 views
drozwood90
drozwood90
30 Apr 2020
Disable Screen Blanking
Assuming that you have seen the previous blogs and are using the Avnet recommended Ubuntu build environment, here is a tip that will increase your productivity!
This is another tip that I found useful!  If you have a tip you think is useful, comment below!
As this virtual machine is running on your host laptop/desktop, if your corporate policies allow, disabling screen blanking can reduce the time and steps it takes to use the Virtual Machine.  For the most part, your host machine should have all of the proper security to protect you as this is a Virtual Machine, it is just an application on your host machine.  For all of these reasons, it is recommended to disable screen blanking.
Click on the application button.
Search for and launch Power
Select Never from the pull down menu
Now you will not have to log into your VirtualBox Virtual Machine after you go answer an email and the timeout hits!  You may also want to disable the Automatic Suspend, however that is a setting that you should decide for yourself as that depends more on the fact of this running on a laptop or desktop!
  • drozwood90
    drozwood90 over 5 years ago
    Hi all,
    I wanted to make it easier to find the various Vitis articles.  And while you can certainly just search, here is a nice easy list for you!
    Learning Vitis: 1 Setting up a Virtual Machine
    Learning Vitis: 2 How to Download and "install" a pre-built platform
    Learning Vitis: Build Environment Quickie 2 - Wide Terminal?!
    Learning Vitis: 3 How to build an Example Application
    Learning Vitis: Build Environment Quickie 3 - A Tidy Shop is a Productive Shop
    Learning Vitis: 4 How to TEST an Example Application
    Learning Vitis: Build Environment Quickie 5 - Monitor the World?
    --Dan
  • drozwood90
    Hi all,
    --Dan
