Industrial Automation
Blog AVNET SmartEdge IIOT Gateway: Display Industrial I/O on Node-RED Dashboard
  • Date Created: 5 Feb 2021 8:52 PM Date Created
  • Views 1477 views
  • smartedge
  • node-red
  • edge_computing
  • dashboard
5 Feb 2021
The SmartEdge IIOT GatewaySmartEdge IIOT Gateway is a Raspberry Pi 3 Compute based industrial Linux box.
It runs Raspbian with some additions. There's a set of industrial hardware extensions. In this 2nd Node-RED blog I show the industrial I/O status on a Node-RED dashboard.
In the 1st Node-RED blog, I controlled the SmartEdge's industrial I/Os in a process flow.
Here, I'm extending that same flow, to show an input pin state on a Node-RED dashboard.
Let's pretend that we have a boiler on/off detector attached to input A I1.
The state is shown on 3 controls:
  • a "button style" indicator
  • a label
  • a history of the last hour
This is easy. I replaced the debug output block of last post with the 3 controls.
Label
The state reader block, labeled DIGIO A I1,  gives character 1 or 0, dependent on the state of SmrtEdge's DIGIO A input 1.
I just added a text node, connected the reader output to it. And gave it a name.
History Graph
This one is also directly connected. I changed some attributes to make it looks good.
I didn't find a way to just show 0 and 1 on the Y axis, without in-between ticks and labels
Indicator
This one expects a boolean input.
I put a conversion function between the reader output and the indicator:
Then, I made the switch read-only and told it to show the input status:
Keeping the View Up-to-date
The last task was to take care that the status is read regularly.
In the previous post, I used an Inhjection block. Every time it's clicked, the input pin's state is read.
I've kept that same block, but scheduled it:
You can choose the interval as you please. If you want a faster refresh than 1 second, you can use decimals.
That's it. These little additions give you a dashboard that you can view from a PC or tablet.
Related Blog
Industrial I/O
Use the Industrial I/O
Control Industrial I/O directly from GPIO Pins
C Program for the Industrial I/O
Control Industrial I/O directly from Node-RED
CAN Bus
Use the Isolated CAN
CAN programming in C on Linux: Filter and Mask
2020 Linux Image
The 2020 Linux Image and IoTConnect Scripts
Understand the Custom Scripts and Services (Pt. 1: intro and reset button service)
Understand the Custom Scripts and Services (Pt. 2: led service)
Understand the Custom Scripts and Services (Pt. 3: IoT Connect service)
    Jan Cumps over 5 years ago
    In the blog, I used the default representation of a button.
    But if you prefer a more sober layout (with additional advantage that it isn't animated when you click on it), you can use simpler icons.
    The image below shows the state when the input is engaged (left) and disengaged.
    Here are the settings:
