1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Blog Gr0G - 01 - Introduction
  • Author Author: amgalbu
  • Date Created: 18 Oct 2020 11:32 AM Date Created
  • Views 1069 views
  • 1meterofpi
  • gr0g
  • 1meter of pi
amgalbu
amgalbu
18 Oct 2020
Here is a list of the posts in this challenge
Gr0G - 02 - Why aeroponics?
Gr0G - 03 - High-pressure system design
Gr0G - 04 - Mechanical design
Gr0G - 05 - Electrical design
Gr0G - 06 - Building the box
Gr0G - 07 - Playing with the Gertbot
Gr0G - 08 - Installing LEDs
Gr0G - 09 - The control board
Gr0G - 10 - Software design
Gr0G - 11 - Building the box (2)
Gr0G - 12 - Building the high-pressure system
Gr0G - 13 - Building the high-pressure system (2)
Gr0G - 14 - Piping
Gr0G - 15 - Improvements
Gr0G - 16 - Remote UI
Gr0G - 17 - Remote UI (2)
Gr0G - 18 - Conclusions
Source code available at https://github.com/ambrogio-galbusera/gr0g, https://github.com/ambrogio-galbusera/gr0g-ble-android and https://github.com/ambrogio-galbusera/gr0g-ble
Growing crops in microgravity is in many way different from farming on earth. In particular, the challenges of growing plants is space are
  • Space is an important resource on a spaceship, so it must be exploited to the utmost. However, in a microgravity environment, there is also a big opportunity in that there is no up or down: plants simply grow towards the light
  • Plants are exposed to stresses like hypoxia and oxidation due to poor soil aeration
  • At your destination site, there are no resources, so everything on the starship should be reusable
Proposed project
The proposed project for this project is to build a growing box that tries to solve the above-mentioned challenges. In particular
  • seed are planted on all the six internal faces of the cubs
  • an aeroponic system will be devised to overcome all the issues related to the presence of soil
The overall structure of the growing box is shown in picture below
All the six internal faces of the cube are equipped with housing for plants. Seed will be implanted in rockwool
At destination, the cube will be opened to provide fertile soil for the colony
Project plan
Research
  • The problems related to building an aeroponic system will be researched
  • The best accomodation for all required components will be investigated
System design
  • Block diagram
  • Mechanical design
  • Piping
  • Software design
System Build
  • Electronics build, Mechanical Build, Software programming
Developmental Testing
  • System electrical testing, System software testing, System mechanical testing
System Application Tests
  • The system will be tested and lattuce will be cultivated
Documentation & Conclusions
  • Each of the project plan tasks will include a related blog
  • amgalbu
    amgalbu over 5 years ago in reply to ralphjy +1
    Yes, thanks: it's aeroponic but nevertheless I will include "creating a new music genre" in the project goals
  • ralphjy
    ralphjy over 5 years ago
    I think that you meant aeroponic unless you are also adding music image.
  • ralphjy
  • amgalbu
    Yes, thanks: it's aeroponic but nevertheless I will include "creating a new music genre" in the project goals image
