1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Blog Gr0G - 04 - Mechanical design
  • Author Author: amgalbu
  • Date Created: 25 Oct 2020 6:13 AM Date Created
  • Views 1266 views
  • 1meterofpi
  • gr0g
  • 1meter of pi
amgalbu
amgalbu
25 Oct 2020
Here is a list of the posts in this challenge
Gr0G - 01 - Introduction
Gr0G - 02 - Why aeroponics?
Gr0G - 03 - High-pressure system design
Gr0G - 05 - Electrical design
Gr0G - 06 - Building the box
Gr0G - 07 - Playing with the Gertbot
Gr0G - 08 - Installing LEDs
Gr0G - 09 - The control board
Gr0G - 10 - Software design
Gr0G - 11 - Building the box (2)
Gr0G - 12 - Building the high-pressure system
Gr0G - 13 - Building the high-pressure system (2)
Gr0G - 14 - Piping
Gr0G - 15 - Improvements
Gr0G - 16 - Remote UI
Gr0G - 17 - Remote UI (2)
Gr0G - 18 - Conclusions
Source code available at https://github.com/ambrogio-galbusera/gr0g, https://github.com/ambrogio-galbusera/gr0g-ble-android and https://github.com/ambrogio-galbusera/gr0g-ble
In this post, I will give some sketches of Gr0G box from a mechanical point of view.
The structure will be built with aluminum extrusion. I found some bars designed to house LED strips (see picture). These bars will made up the top and bottom panels of the cube.
The four lateral panels will be made up with a bar for the LED strip, two L-shaped aluminum extrusion (at the top and the bottom) and a 20 x 1 mm aluminum bar.
This is the detail of the junction between two adjacent lateral panels
The four lateral panels are joined to the bottom panel by means of a joint to allow the box t be folded and unfolded. The top panel will be joined to one of the lateral panels in the same way
The aluminum bars will be riveted
The structure will be covered with transparent Plexiglas panels. Lateral and top panels will be covered with 2mm panels, the bottom with a 4 mm one, in order to hold up the compressor and the other pneumatic components. Plexiglas panels will be kept in place by tapping screws
  • amgalbu
    amgalbu over 6 years ago in reply to dougw +3
    Hello Douglas I found the aluminum estrusion and the plexiglas panels at a warehouse close to me and I spent about 25 euros. Regarding the bars for LED, there any many offers on the Internet and I think…
    dougw over 6 years ago +1
    Wow, top notch materials - with a price to match, no doubt.
  • amgalbu
    Hello Douglas
    I found the aluminum estrusion and the plexiglas panels at a warehouse close to me and I spent about 25 euros. Regarding the bars for LED, there any many offers on the Internet and I think I can buy for about 30 euros. So this is not too expensive
