Blog [CaTS] ForgetMeNot - Week 11 (2): Continuing the build
  • Author Author: fvan
  • Date Created: 15 Oct 2014 4:05 PM Date Created
  • Views 1544 views
  • forget_me_not
  • design_challenge
  • openhab
  • tektronix
  • rpisoc
  • iot_pet_care
  • eclipse
  • internet_of_things
  • enocean
  • cats
  • raspberrypi
  • smarthome
  • challenge
  • iot
  • enocean_pi
fvan
fvan
15 Oct 2014
Previous posts for this project:
  • [CaTS] ForgetMeNot - Index
  • [CaTS] ForgetMeNot - Week 0: Project Description
  • [CaTS] ForgetMeNot - Week 1: EnOceanPi and Sensors
  • [CaTS] ForgetMeNot - Week 2: Elro CoCo and Pi Cam with OpenHAB
  • [CaTS] ForgetMeNot - Week 3: Data persistence and charts with OpenHAB
  • [CaTS] ForgetMeNot - Week 4: Arduino-OpenHAB communication
  • [CaTS] ForgetMeNot - Week 5: Getting familiar with EAGLE
  • [CaTS] ForgetMeNot - Week 6: Getting to know the TBS1052B-EDU oscilloscope
  • [CaTS] ForgetMeNot - Week 7: First tests with RPiSoC
  • [CaTS] ForgetMeNot - Week 7 (2): More testing with RPiSoC
  • [CaTS] ForgetMeNot - Week 8: Water dispenser and temperature
  • [CaTS] ForgetMeNot - Week 9: RFID Cat detection and identification
  • [CaTS] ForgetMeNot - Week 10: Peltier cooling experiment
  • [CaTS] ForgetMeNot - Week 11: Starting the build
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean sensor bracket
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean rocker switch and magnet holder
  • [CaTS] ForgetMeNot - 3D Printing: Food dispenser prototype
  • [CaTS] ForgetMeNot - 3D Printing: Weighing scale
  • [CaTS] ForgetMeNot - Security: Some basic tips
  • [CaTS] ForgetMeNot - Minion: Dave, the gassy minion
  • [CaTS] ForgetMeNot - Pi Camera: Wide Angle Lens
  • Introduction
  • Build
  • Circuits
Stress level is increasing as the end of the challenge is merely a little more than a week away and there is still so much to be done!
Today, I continued working on my build and managed to make some progress. I also had some pending circuits to be soldered.
Build
Last time, I worked on the front side of the build. Today I started the back side.
I installed the brackets holding the reservoirs in place and cut side panels. The whole thing has also been put on wheels, making it slightly easier to move around.
Finally, I cut a plexi back panel which can slide into place. This makes it easy to remove in case electronics need to be accessed.
Some points still to be tackled:
- install reservoirs and ensure dispensing in bowl
- install electronics
- finish and paint the build
I have already prepared some spacers for the electronics, So I should be able to just screw everything in place using the mounting holes.
Circuits
There are 2 little circuits that were still waiting to be done some day. And today, was that day.
The first circuit is just a little power splitter.
Taking input from the power supply via a little screw terminal, the splitters offers 3 USB ports and 3 screw terminals to connect devices to.
I didn't need that many, but at least the system is ready for possible expansion image
The second circuit is a GPIO splitter.
With different modules for the Raspberry Pi, making use of different pins on the GPIO header, I made my own custom Pi rack.
The circuit provides connectivity for the Raspberry Pi GPIO and splits it to:
- Power + I2C for my custom RF433 transmitter with ATtiny85
- Power + UART for the EnOcean Pi
- Power + SPI for the RPiSoc.
That's it for this update, off to get more done before the end of the challenge ...
  • fvan
    fvan over 12 years ago in reply to shabaz +1
    Kept the table saw low, made a first pass, then shifted the guide 1mm and repeated. This resulted in a slot large enough for the plexi
    shabaz over 12 years ago
    Hehe nice trick. That appears to have worked very well!!
  • fvan
    Kept the table saw low, made a first pass, then shifted the guide 1mm and repeated. This resulted in a slot large enough for the plexi image
    Very cool : ) How did you do the slots, did you have some routing tool, or did you keep the table-saw blade low?
    DAB over 12 years ago
    Nice solution to extending your IO.
