Make Life Accessible
  • Make Life Accessible
Blog EyePrints - Post 17 - Final demo
  • Author Author: amgalbu
  • Date Created: 30 Jun 2016 11:56 AM Date Created
  • Views 1074 views
  • makelifeaccessible
  • eyeprints
  • accessibility_projects
  • demo
  • make_life_accessible
amgalbu
amgalbu
30 Jun 2016
Previous posts
Post 1 - Introduction
Post 2 - Installing OpenCV - Prerequisites
Post 3 - Installing OpenCV
Post 4 - Installing Pygaze
Post 5 - Installing eye tracker
Post 6 - SPI communication
Post 7 - SPI communication in Python
EyePrints - Post 8 - Getting started with Kinetis
EyePrints - Post 9 - Mechanical design
EyePrints - Post 10 - Mechanical design: the plotter
EyePrints - Post 11 - Eye tracker software
EyePrints - Post 12 - Getting started with the kit
EyePrints - Post 13 - KDS Project
EyePrints - Post 14 - The drawing board
EyePrints - Post 15 - The plotter
EyePrints - Post 16 - The unhappy end
In this post, I will pack up everything I built and developed during this challenge. First of all, here is the wiring between the Freedom Board and the Raspberry Pi
This is the webcam mounted on a baseball cap
Before using the tracker, a calibration is required
Now, EyePrints can run!
Final considerations
I never used the Freedom board, but I really appreciated the quality of the board, the number of peripherals available (including the accelerometer), the easyness of use of the IDE and the completeness of the examples.
The motor controller board I think is a bit less mature than the Freedom board. There are some useful tools that calculated the parameters for the control algorithm, but it's not easy to add your custom to the generated project. Probably a cleaner project structure would include fewer code in the main function. Also, some comments like "Add your code here" would help users
Provided control algorithms seem to work very well. I tested the sensorless speed control, and the motor speed is quite constant with smooth ramps
The only disappointing thing is that the challenger's kit components had a very limited availability. This prevents me from completing the project. However, the eyetracker proved to be enough precise and not so difficult to get accustomed to. Strange to say, bu the webcam in front of your eyes is almost "invisible", in that it does not interfere with your sight. So, should the motor controller and the motor itself have been available on time, I'm quite confident I would have been able successfully complete this project
Source code.zip
    DAB over 10 years ago +1
    Good summary and demo of eye tracking. I can see a lot of uses for your basic software. Once you get the camera calibrated, you could control a quadcopter, RC vehicle or aircraft, or just use it for basic…
  • amgalbu
    amgalbu over 10 years ago
    Thank you DAB
    You are right: the eye tracker could be used as a basic "mouse".
    To stay in the challenge topic, it could be used to control a wheel chair
    Cheers
    Ambrogio
  • amgalbu
    Thank you DAB
    Cheers
    Ambrogio
