Pi Chef Design Challenge
  • Pi Chef Design Challenge
Blog The Spice of Pi - Glenn blog #5
  • Author Author: glennvanderveer
  • Date Created: 18 Mar 2018 4:07 PM Date Created
  • Views 1269 views
  • Likes 8 likes
glennvanderveer
glennvanderveer
18 Mar 2018
Another update with a video.
In order to choose the spices, Doug has 3d printed a platter that will be required to spin and lift the spice bottles. In order to do that he has designed in 2 servos to do the spinning and lifting.  I get to make the code to spin and lift the servos.  There is a python library to access the servos that I will be using. After working on this Friday night and a good chunk of Saturday I have very limited success.  I have been able to get the servo-demo script that the library provides to work, but when I add it to my actual code I get segmentation faults all the time.  That is why I have to press the button to get the servo commands to work.  You will also notice in the video, that the servo seems to be 'fidgeting'.  So I think that the power will have to be turned on only when the servo is actually needed to do some work.
So, time to do some research as to why the segmentation faults are happening and see if I can get around them.
Design Challenge Links:
About the challenge
The other challengers
The kit
Terms & Conditions
Summaries by Charles Gantt
Project Links:
Blog Doug 1 - The Concept
Blog Glenn 1 - AIY Voice Kit Unboxing
Blog Doug 2 - The Block Diagram and Bill of Materials
Blog Doug 3 - Spice Jar Lift Mechanism
Blog Glenn 2 - Firmware Considerations
Blog Doug 4 - Carousel Design
Blog Doug 5 - Platter Rotation Mechanism
The Spice of Pi - Blog Glenn 3
Blog Doug 6 - 3D Printed Platter Parts
Blog Doug 7 - Main Drive Assembly
Blog Doug 8 - Working Carousel
Blog Doug 9 - Google Assistant
Blog Doug 10 - Pi Enclosure
The Spice of Pi - Glenn blog #4
  • e14phil
    e14phil over 8 years ago +4
    Hey Glen I have seen people discuss the twitching Servos before, i think its a timing issue, depending on your set up people have previously changed the library to fix. " I swapped to the pigpio library…
    genebren over 8 years ago +1
    It's alive! Good that you have worked through to this point. Sometimes the simplest of things takes a lot of work. Good luck on your continued progress and successes! Gene
  • three-phase
    three-phase over 8 years ago +1
    Nice update, do you think the 'fidgeting' may be reduced once the weight of the platter is added onto the server? Kind regards
  • three-phase
    Kind regards
  • three-phase
    Kind regards
  • glennvanderveer
    glennvanderveer over 8 years ago in reply to three-phase
    No, I don't think so.  If you look at the first video on Doug's blog number 8 (The Spice of Pi - Blog Doug 8 ) the platter is actually sitting on a bearing assembly and the platter is spun by a belt/gear assembly instead of the servo itself.
