Op-Amp-a-Palooza
  • Op-Amp-a-Palooza
Op-Amp-a-Palooza
Blog Project14 | Op-Amp-a-Palooza: Win an Op-Amp Kit for Your Op-Amp Project!
Join Op-Amp-a-Palooza to participate - click to join for free!
  • Date Created: 15 Feb 2022 4:44 PM Date Created
  • Views 34328 views
  • Likes 20 likes
  • Comments 56 comments
  • opampsch
  • opamps
tariq.ahmad
tariq.ahmad
15 Feb 2022
In the Comments Below:   Let Us Know Your Op-Amp Project Ideas for a Chance to Win an Op-Amp Kits
The Most Mind Blowing Op-Amp Project Wins an Op-Amp Testing Kit:
image image image
Buy Now Buy Now Buy Now
Op-Amp-a-Palooza is an open ended exploration of op-amps using low cost components and features premium op-amp testing equipment as prizes. There's so much that can be done with OpAmps: Amplifiers and buffers, measurement, active filters, voltage references, current measurement, audio vs RF vs HT, precision circuits low noise circuits making one from discrete components.   This contest features Op-Amp components from Maxim, Renesas, and Microchip.    To win a op-amp kit let us know your op-amp project proposal in the comments below.   You are also free to use whatever components you choose for your op-amps project.
Submit Your Projects Here or Tag Your Blog opampsch:
Submit Entry
Check out our essentials series to learn more about Op-Amps:
  • Op Amps I: Low Power Op Amps
  • Op Amps II: Specialty Op-amps for High Voltage and Precision Applications
  • Op Amps III: Audio Op Amps
{tabbedtable}City Team
The Kit
If you have a project proposal based on any of the following components then submit a comment below for a chance to win an Op-Amp Kit from Renesas, Maxim Integrated, and Microchip:
Audio Power Amplifier MAX98357AETE+T image Buy Now
Operational Amplifier MAX40075ANT+T image Buy Now
Current Sense Amplifier MAX44284EAWT+T image Buy Now
Class D Audio Power Amp MAX98390EVSYS# image Buy Now
Operational Amplifier MAX40100ANT+T image Buy Now
Current Sense Amplifier, 2 Amplifier MAX40201FAUA+ image Buy Now
Zero Drift Operational Amplifier ISL28134IBZ image Buy Now
Operational Amplifier ISL28230FBZ image Buy Now
Micro-Power, RRIO Zero-Drift Amps  ISL28233FRZ image Buy Now
Operational Amplifier, Dual, 2 Amplifier, 61 MHz, 17 V/µs, 2.85V to 3.5V, SOIC, 8 Pins ISL28291FBZ image Buy Now
Operational Amplifier, Single, 1 Amplifier, 2 MHz, 1 V/µs, 1.8V to 5.5V, MSOP, 8 Pins ISL28213FUZ image Buy Now
Current Sense Amplifier, Micropower, 1 Amplifier, 6 µA, SOT-23, 5 Pins, -40 °C, 125 °C ISL28006FH50Z-T7 image Buy Now
Operational Amplifier, 1 Amplifier, 1 MHz, 1.9 V/µs, 1.8V to 5.5V, SOT-23, 5 Pins MCP6006T-E/OT image Buy Now
OPAMP, 1MHZ MCP6007-E/MS image Buy Now
Operational Amplifier, Single, 10 MHz MCP6291T-E/OT image Buy Now
MSOP DUAL 10 MHZ OP MCP6292-E/MS image Buy Now
Operational Amplifier, Single, 14 kHz, 1, 0.003 V/ s, 1.4V to 6V, SOT-23 MCP6041T-I/OT image Buy Now
Operational Amplifier, 2 Amplifier, 14 kHz, 0.003 V/µs, 1.4V to 5.5V, DIP, 8 Pins MCP6042-I/P image Buy Now
Operational Amplifier, Single, 1 Amplifier, 10 kHz, 0.004 V/µs, 1.8V to 5.5V, SOT-23, 5 Pins MCP6031T-E/OT image Buy Now
Operational Amplifier, RRIO, 2 Amplifier, 10 kHz, 4 V/ms, 1.8V to 5.5V, MSOP, 8 Pins MCP6032T-E/MS image Buy Now
Operational Amplifier, Single, 300 kHz, 1, 0.13 V/ s, 1.8V to 5.5V, SOT-23 MCP6V31T-E/OT image Buy Now
OPAMP, 300KHZ MCP6V32-E/MS image Buy Now
The Prizes
The most mind blowing Op-Amp Project Wins the Following Op-Amp Tool Kit:
The Grand Prize:
image image image
3 First Place Winners:
image image image
Here are some projects to inspire you:
image image
The Learning Circuit 68: How Op Amps Work The Learning Circuit 69: OpAmps Project: Build an Amplified Stereo Mic Kit
image image
Workbench Wednesdays 39: Op Amps Without Op Amps Episode 537: Build a Phonograph Preamplifier - How Hard Can It Be?
image image
Op-amp made from Discrete Components by fmilburn Playing with an OP 191 Op Amp by jw0752
image image
Op Amps - The Norton CDA by jc2048 Op Amps: NIC (Negative Impedance Converter) and the Chua Oscillator by jc2048
image image
Experimenting with Op Amps: Input Offset Voltage by jc2048 Smart Coin Sorter by Inductive Sensing. #03 Experimenting with Op Amp Colpitts Oscillators by javagoza
Your Chance to Win
Be Original
Stick to the Theme
  • You could come up with a clever name that make's your project memorable!
    • This project is your baby! Part of the fun of bringing something new into the world is coming up with a name.
  • Your project could introduce something new or that is not commercially available or affordable!
  • If you have an idea for a project that doesn't fit the current theme then submit your idea in the comments section of the monthly poll.
List the Steps
Submit Video Proof
  • Provide the steps you took to complete your project (text, video, or images).
    • This could be a step by step how-to-guide, vlog, schematics, coding, napkin drawings, voice narration, or whatever you think will be useful!
  • If it doesn't work that's fine, this is more about the journey than the end product.
  • A short video is all that is required but you can shoot as much video as you like.
  • You are encouraged to be creative and have as much fun as possible!
Your Project Examples
Op-Amp-a-Palooza
Smart Coin Sorter by Inductive Sensing. #03 Experimenting with Op Amp Colpitts Oscillators   by javagoza Op-amp made from Discrete Components by fmilburn
Your Prizes
One Grand Prize Winner Wins an Op-Amp Testing Kit plus a $200 Shopping Bundle Three First Place Winners Win  an Op-Amp Testing Kit plus a $100 Shopping Cart
  • One Grand Prize Winner Wins an Op-Amp Testing Kit (Arbitrary Waveform Generator , Bench Power Supply , and Handheld Oscilloscope  ) plus a $200 Shopping Cart!
  • 3 First Place Winners a Win an Arbitrary Waveform Generator , Bench Power Supply , and USB Oscilloscope ) plus a $100 Shopping Cart!
image image
Some Terms & Conditions Apply:  How to Redeem Your Shopping Cart for Project14
Your Project, Your Ideas!
About Project14
Directions
Every month you'll have a new poll where you'll get to decide an upcoming project competition, based on your interests, that will take place a couple of months in advance. Themes are broad in scope so that everyone can participate regardless of skill set.
What are Monthly Themes?
  • Every month (around the 14th of each month) a new theme will be posted on Project14.
  • Submit your ideas (proposals) for your projects to get feedback from the rest of the community.
  • Submit a project entry in the Theme space once you start working on it.
What are Monthly Theme Polls?
  • Every month (around the 14th of each month) there is a project theme poll.
  • Vote on which project competition you want to see for the following upcoming theme.
    • The themes voted on during the previous poll decided the upcoming theme.
    • If you submit an idea for a theme that is not used then it can still be used in a future poll.
  • Themes comments and ideas from the comments section of the project theme poll.
Visit:  Op-Amp-a-Palooza  or tag your project blog opampsch
You have until April 27th End of Day to submit your completed project!
A jury consisting of your peers will judge project submissions!
  • rsjawale24
    rsjawale24 over 4 years ago +1
    I had planned to make this project long back. Finally, it's time to implement it. Opamps are fun and have lots of applications. I plan to make an audio spectrum visualizer using active filters based on…
    dougw over 4 years ago in reply to robogary +1
    With one op-amp you can make a 3rd order Pafnuty Cebyshev band-pass filter. One of my favorites... How is that for dropping a name? It is interesting that some filter books are now on-line: https…
  • javagoza
    javagoza over 4 years ago in reply to fmilburn +1
    You have nothing to apologize for. The mistake was mine that I wanted to imagine that. On the board it is clear that all servos receive the same signal. If I had "read" the board carefully I wouldn't have…
  • martinlong1978
    martinlong1978 over 4 years ago
    My project idea is to build a basic modular bench multimeter / scope. The analogue side based on op amps, including a current sense amplifier, and various op amps to control the signal amplification. Digital side using something like a ESP32, with a small TFT screen. It would also allow a phone/tablet/laptop to be connected via wifi/bluetooth, for better display of scope functions.
    Additional modules include:
     - milliamp clamp meter
     - remote monitoring/logging e.g. for IoT devices. Measure power consumption in line and logging to MQTT
     - signal generator
     - data loggers for temperature, light, current, voltage, humidity, etc
  • martinlong1978
     - signal generator
