Op-Amp-a-Palooza
  • Op-Amp-a-Palooza
Op-Amp-a-Palooza
Blog Project14 | Op-Amp-a-Palooza: Win an Op-Amp Kit for Your Op-Amp Project!
Join Op-Amp-a-Palooza to participate - click to join for free!
  • Date Created: 15 Feb 2022 4:44 PM Date Created
  • Views 34358 views
  • Likes 20 likes
  • Comments 56 comments
  • opampsch
  • opamps
tariq.ahmad
tariq.ahmad
15 Feb 2022
In the Comments Below:   Let Us Know Your Op-Amp Project Ideas for a Chance to Win an Op-Amp Kits
The Most Mind Blowing Op-Amp Project Wins an Op-Amp Testing Kit:
image image image
Buy Now Buy Now Buy Now
Op-Amp-a-Palooza is an open ended exploration of op-amps using low cost components and features premium op-amp testing equipment as prizes. There's so much that can be done with OpAmps: Amplifiers and buffers, measurement, active filters, voltage references, current measurement, audio vs RF vs HT, precision circuits low noise circuits making one from discrete components.   This contest features Op-Amp components from Maxim, Renesas, and Microchip.    To win a op-amp kit let us know your op-amp project proposal in the comments below.   You are also free to use whatever components you choose for your op-amps project.
Submit Your Projects Here or Tag Your Blog opampsch:
Submit Entry
Check out our essentials series to learn more about Op-Amps:
  • Op Amps I: Low Power Op Amps
  • Op Amps II: Specialty Op-amps for High Voltage and Precision Applications
  • Op Amps III: Audio Op Amps
{tabbedtable}City Team
The Kit
If you have a project proposal based on any of the following components then submit a comment below for a chance to win an Op-Amp Kit from Renesas, Maxim Integrated, and Microchip:
Audio Power Amplifier MAX98357AETE+T image Buy Now
Operational Amplifier MAX40075ANT+T image Buy Now
Current Sense Amplifier MAX44284EAWT+T image Buy Now
Class D Audio Power Amp MAX98390EVSYS# image Buy Now
Operational Amplifier MAX40100ANT+T image Buy Now
Current Sense Amplifier, 2 Amplifier MAX40201FAUA+ image Buy Now
Zero Drift Operational Amplifier ISL28134IBZ image Buy Now
Operational Amplifier ISL28230FBZ image Buy Now
Micro-Power, RRIO Zero-Drift Amps  ISL28233FRZ image Buy Now
Operational Amplifier, Dual, 2 Amplifier, 61 MHz, 17 V/µs, 2.85V to 3.5V, SOIC, 8 Pins ISL28291FBZ image Buy Now
Operational Amplifier, Single, 1 Amplifier, 2 MHz, 1 V/µs, 1.8V to 5.5V, MSOP, 8 Pins ISL28213FUZ image Buy Now
Current Sense Amplifier, Micropower, 1 Amplifier, 6 µA, SOT-23, 5 Pins, -40 °C, 125 °C ISL28006FH50Z-T7 image Buy Now
Operational Amplifier, 1 Amplifier, 1 MHz, 1.9 V/µs, 1.8V to 5.5V, SOT-23, 5 Pins MCP6006T-E/OT image Buy Now
OPAMP, 1MHZ MCP6007-E/MS image Buy Now
Operational Amplifier, Single, 10 MHz MCP6291T-E/OT image Buy Now
MSOP DUAL 10 MHZ OP MCP6292-E/MS image Buy Now
Operational Amplifier, Single, 14 kHz, 1, 0.003 V/ s, 1.4V to 6V, SOT-23 MCP6041T-I/OT image Buy Now
Operational Amplifier, 2 Amplifier, 14 kHz, 0.003 V/µs, 1.4V to 5.5V, DIP, 8 Pins MCP6042-I/P image Buy Now
Operational Amplifier, Single, 1 Amplifier, 10 kHz, 0.004 V/µs, 1.8V to 5.5V, SOT-23, 5 Pins MCP6031T-E/OT image Buy Now
Operational Amplifier, RRIO, 2 Amplifier, 10 kHz, 4 V/ms, 1.8V to 5.5V, MSOP, 8 Pins MCP6032T-E/MS image Buy Now
Operational Amplifier, Single, 300 kHz, 1, 0.13 V/ s, 1.8V to 5.5V, SOT-23 MCP6V31T-E/OT image Buy Now
OPAMP, 300KHZ MCP6V32-E/MS image Buy Now
The Prizes
The most mind blowing Op-Amp Project Wins the Following Op-Amp Tool Kit:
The Grand Prize:
image image image
3 First Place Winners:
image image image
Here are some projects to inspire you:
image image
The Learning Circuit 68: How Op Amps Work The Learning Circuit 69: OpAmps Project: Build an Amplified Stereo Mic Kit
image image
Workbench Wednesdays 39: Op Amps Without Op Amps Episode 537: Build a Phonograph Preamplifier - How Hard Can It Be?
image image
Op-amp made from Discrete Components by fmilburn Playing with an OP 191 Op Amp by jw0752
image image
Op Amps - The Norton CDA by jc2048 Op Amps: NIC (Negative Impedance Converter) and the Chua Oscillator by jc2048
image image
Experimenting with Op Amps: Input Offset Voltage by jc2048 Smart Coin Sorter by Inductive Sensing. #03 Experimenting with Op Amp Colpitts Oscillators by javagoza
Your Chance to Win
Be Original
Stick to the Theme
  • You could come up with a clever name that make's your project memorable!
    • This project is your baby! Part of the fun of bringing something new into the world is coming up with a name.
  • Your project could introduce something new or that is not commercially available or affordable!
  • If you have an idea for a project that doesn't fit the current theme then submit your idea in the comments section of the monthly poll.
List the Steps
Submit Video Proof
  • Provide the steps you took to complete your project (text, video, or images).
    • This could be a step by step how-to-guide, vlog, schematics, coding, napkin drawings, voice narration, or whatever you think will be useful!
  • If it doesn't work that's fine, this is more about the journey than the end product.
  • A short video is all that is required but you can shoot as much video as you like.
  • You are encouraged to be creative and have as much fun as possible!
Your Project Examples
Op-Amp-a-Palooza
Smart Coin Sorter by Inductive Sensing. #03 Experimenting with Op Amp Colpitts Oscillators   by javagoza Op-amp made from Discrete Components by fmilburn
Your Prizes
One Grand Prize Winner Wins an Op-Amp Testing Kit plus a $200 Shopping Bundle Three First Place Winners Win  an Op-Amp Testing Kit plus a $100 Shopping Cart
  • One Grand Prize Winner Wins an Op-Amp Testing Kit (Arbitrary Waveform Generator , Bench Power Supply , and Handheld Oscilloscope  ) plus a $200 Shopping Cart!
  • 3 First Place Winners a Win an Arbitrary Waveform Generator , Bench Power Supply , and USB Oscilloscope ) plus a $100 Shopping Cart!
image image
Some Terms & Conditions Apply:  How to Redeem Your Shopping Cart for Project14
Your Project, Your Ideas!
About Project14
Directions
Every month you'll have a new poll where you'll get to decide an upcoming project competition, based on your interests, that will take place a couple of months in advance. Themes are broad in scope so that everyone can participate regardless of skill set.
What are Monthly Themes?
  • Every month (around the 14th of each month) a new theme will be posted on Project14.
  • Submit your ideas (proposals) for your projects to get feedback from the rest of the community.
  • Submit a project entry in the Theme space once you start working on it.
What are Monthly Theme Polls?
  • Every month (around the 14th of each month) there is a project theme poll.
  • Vote on which project competition you want to see for the following upcoming theme.
    • The themes voted on during the previous poll decided the upcoming theme.
    • If you submit an idea for a theme that is not used then it can still be used in a future poll.
  • Themes comments and ideas from the comments section of the project theme poll.
Visit:  Op-Amp-a-Palooza  or tag your project blog opampsch
You have until April 27th End of Day to submit your completed project!
A jury consisting of your peers will judge project submissions!
  • rsjawale24
    rsjawale24 over 4 years ago +1
    I had planned to make this project long back. Finally, it's time to implement it. Opamps are fun and have lots of applications. I plan to make an audio spectrum visualizer using active filters based on…
    dougw over 4 years ago in reply to robogary +1
    With one op-amp you can make a 3rd order Pafnuty Cebyshev band-pass filter. One of my favorites... How is that for dropping a name? It is interesting that some filter books are now on-line: https…
  • javagoza
    javagoza over 4 years ago in reply to fmilburn +1
    You have nothing to apologize for. The mistake was mine that I wanted to imagine that. On the board it is clear that all servos receive the same signal. If I had "read" the board carefully I wouldn't have…
  • javagoza
    I plan to do something that is really uncomfortable for me without writing a single line of code or dealing with development environment installations that take several days to configure.
    Let's see if with tutorials and a little sweat I can build a line follower vehicle that incorporates a PID controller and PWM drivers all using op Amps, to obtain the error, for the proportional the differential and the integral modules. Added I want to control the motors of the vehicle by PWM.
    This would be the block diagram of the control part of the vehicle.
    It may also add some op amp based low pass filters for the optical sensors, at least leave the possibility of incorporating them.
    There are many op amps among almost 20 something that really bothers me :D
  • javagoza
  • robogary
    robogary over 4 years ago in reply to javagoza
    way back, 35-40 years ago, I worked on a slitting line with an analog loop pit regulator that looked alot like your project drawing.
    The position loop was 40 feet into the ground. Every 8-10 feet down was a volkswagon headlight. Opposite side of the pit was a light sensitive tube. The output of each sensor tube was fed into a summing op amp (the op amp was a card made from discrete components) . The depth setpoint was fixed at halfway down when in auto. The PID was an op amp (card) fed into the speed reference trim of the winder. The winder itself was wild, it had a "psuedo" diameter op amp, that fed a motorized rheostat. The rheostat position modeled coil diameter to set the speed reference and diameter related torque compensations.
    The unwinder could run without the pit, as diameter arm trimmed current regulator.
    The sheet wasnt perfectly flat and uniform across the coil, the pit loop slices would be different depths.
  • robogary
    In your steering design, you'll likely want the relative gain to be small on the inner photodetectors for small corrections, and the further out from center the sensors are, have higher strength of correction. It may be simpler too, if one wheel is fixed speed, and the other wheel slows or speeds up for steering correction.
  • javagoza
    javagoza over 4 years ago in reply to robogary
    Thanks, I like the idea of having different gains depending on the distance of the sensors from the center, even that gain is adjustable to fine tune the final solution, I had not thought about it.
    The second idea has left me a bit in shock, how had I not thought of it! I will work on it, my knowledge of analog electronics is that of a total beginner, it makes me a little embarrassed and encouraged at the same time that they have chosen a project of mine to illustrate the competition.
  • javagoza
    20 years ago I worked in a newspaper printing house but in charge of the IT department and the prepress and phototypesetting machines. From time to time I had to modify the program of some programmable automata for the newspaper press. Those reels have reminded me. I don't get grease anymore, now I work for a bank.
  • rsjawale24
    rsjawale24 over 4 years ago in reply to javagoza
    I made a simple line follower using opamps as comparators. I didn't use analog PID and it worked just fine. Without PID there's a limit on the rpm of motors. Too high rpm will deviate the robot from it's path before the opamp comparator can sense the path.
    Implementating analog PID is cool! Looking forward to the project! Slight smile
