Connector Technology & Design
Forum Overview: Amphenol / SV Microwave SF2921-61506-1S SMA coaxial connector series
  • Replies 11 replies
  • Subscribers 126 subscribers
  • Views 4465 views
  • sv microwave
  • amphenol
  • SF2921-61506
  • SF2921-61506-1S
Jan Cumps
Jan Cumps over 3 years ago
imageBlog Index
  • Overview: Amphenol / SV Microwave SF2921-61506-1S SMA coaxial connector series
  • Amphenol / SV Microwave SF2921-61506-1S SMA coaxial connector: behavior under vibration
  • Create a custom footprint in KiCad 7 - 1: collect info and component details
  • Create a custom footprint in KiCad 7 - 2a: create the footprint for an SMA coax connector with the editor - initial outline
  • Create a custom footprint in KiCad 7 - 2b: create the footprint for an SMA coax connector with the editor - copper pour, solder mask clearance, holes, pads
  • Use a LibraryLoader Footprint in KiCad 7
I'm testing a set of Amphenol /  SV Microwave SF2921-61506-1S  SMA coaxial connectors.
I'll cover 3 angles:
Footprint and PCB layout
This part focuses on getting a good PCB layout for the connector, that can be used for a microstrip design.
It starts from a community sourced footprint, ending with a clean layout. This part was a collaboration exercise with shabaz. We both designed footprints, using the same editor, but different approaches.
Spring contact resilience to vibrations
The connector's main difference with other PCB mount coaxial models, is that it's spring-actioned instead of soldered-on. I use the vibration table and measurement tools from the Vibration Measurement with the MCC 172 roadtest. During the test, I check if the DC resistance alters under vibration, or if the contact interrupts.
Connector in use
I'll check the connector with the microstrip designs that shabaz made, and in combination of a set of antennas I have, from a Molex kit and a Texas Instruments PCB antenna design kit.
Link to all posts
  • scottiebabe
    scottiebabe over 3 years ago +4
    Nice work! I read this article yesterday and thought of you lol Are the authors over exaggerating the alignment process? https://www.everythingrf.com/news/details/15928-samtec-develops-visual-alignment…
    Jan Cumps over 3 years ago in reply to dang74 +3
    I'm working on the setup:
    shabaz over 3 years ago +2
    This will be a great test! Looking forward to seeing how it goes.
  • scottiebabe
    scottiebabe over 3 years ago in reply to Jan Cumps
    That's wonderful hear! Great work putting this connector through its paces.
    I guess it depends on mounting drill hole size, provided you use the correct size hopefully its a non-issue.
    That would be quite frustrating if your connector rotated a few degrees and shorted out the incoming t-line.
