Test & Tools
Test & Tools
Blog Keithley DMM6500: How to Create a Bitmap for a Custom App
  • Date Created: 15 Jan 2019 12:45 AM Date Created
  • Views 4575 views
  • Likes 18 likes
  • Comments 12 comments
  • RoadTest
  • dmm6500
  • rt
  • keithley
15 Jan 2019
I'm road testing the  Keithley Bench Digital Multimeter DMM6500.
The instrument can run apps, and you can roll your own (what a great time do be alive image).
In this blog, I'll show how you can show images on the display.
Why, Jan?
Apps make it possible to change how the instrument operates. It can give a completely different look and feel.
When you are using this for prescribed situations, or in a fixed setup, this can help to have repeatable results.
You can use this to run a set op predefined scenarios, show info in an operator friendly way, show binning info, show tag cards with instructions.
There's a pre-installed app on the device that shows such an instruction card flow, called Instructions.
It's a set of 5 cards that you can scroll to, showing where the main user interface functions are.
Here's an example of one of the instruction cards.
Example
On the Keithley product page for this meter, the source for this app is available via the downloads button.
Let's change that example and replace the first card by a custom one, just to see if it works.
You need to have the image, in PNG format.
An image of 800 * 430 fills the whole width and fits under the title bar.
You have to convert it to BASE64.
Here's a website that can do that conversion online: https://onlinepngtools.com/convert-base64-to-png
Paste the BASE64 content in the application source file that you downloaded from Keithley's website, over the content of the first image.
Put it between these lines of code, replacing anything that was in there originally:
loadimage home intro_DMM
-- paste the content here
endimage
loadimage board2 intro_DMM
Save the script to a USB stick (.tspa extension). Then press the APPS button, and navigate to the USB.
Then select the app, and RUN it.
You'll see the image you created pop up first. When you press the TRIGGER button, it will navigate to the remaining original tag cards.
Home brings you back to your custom image.
If you want to have a look at the original images from the script, you can use this link to reverse from BASE64 to PNG:
Related Blog
Software Control Options Pt 1 - TSP Script Builder, LabVIEW, Web Interface
TSP Script Example - Measure Power
Verify a µCurrent Manually
Verify a µCurrent in an Automated Setup
Measure Amp-Hours of a microcontroller with a µCurrent
Trigger from External Trigger Input
Trigger from External Trigger Input in LabVIEW
Software Control Options Pt 2 - Test Commands with Communicator
App to Hold Measurements
Store Multiple Measurements Manually
Keithley DMM6500: Script Example - Externally Triggered Measurements
 Keithley DMM6500: Software Control Options Pt 3 - VSCode TSP Toolkit
    shabaz over 7 years ago +2
    It's a great feature! I couldn't resist trying this procedure out. Here's a space theme: ..and the 800x430 size .png file, for anyone who wants to use it (click on it first so that it is the correct size…
  • michaelkellett
    michaelkellett over 7 years ago in reply to Jan Cumps +2
    In a rush now so may think of something else later. The neatest thing I've done with the 7510 was to use the data acquisition mode to capture data from a low frequency filter (customer had designed it…
  • michaelkellett
    Hello Jan, I'm impressed by what you have done already - I've only ever programmed these things just enough to get the immediate job done so it's great if you do it for free To help you on your way: https…
    Jan Cumps over 7 years ago
    Instrument manufacturers often struggle to build user friendly remote software. Translating an instrument (e.g. oscilloscope) to a software front-end hasn't been done successfully very often.
    I think that the user interface for this instrument, if you translate the 8 soft buttons next to the display to screen buttons, would work well on a remote touch screen.
    Maybe once computers are more and more equipped with touch screens, instrument builders have a better chance to provide a user friendly remote app ...
