Test & Tools
Test & Tools
Blog SCPI on a Linux Board - Letter of Intent
  • Date Created: 27 Apr 2018 5:41 PM Date Created
  • Views 6039 views
  • Likes 14 likes
  • Comments 21 comments
  • pi
  • bbb
  • BeagleBone
  • raspberrypi
  • scpi
27 Apr 2018
I'm trying to build a SCPI shell for Linux.
I'd like to have it working over TCP/IP on a Raspberry Pi and a BeagleBone.
tl;dr It works. The rest of the blog series explains how to build a lab automation device that controls 8 outputs (2 of them relays), and read 8 inputs. With a Raspberry Pi and a PiFace Digital (2).
Here on element14, we've been playing with SCPI and microcontrollers. We have several instruments working on MSP432, Arduino and Hercules devices.
This time I'd like to get a Linux instrument up. To get some device independence, I'll try to make the source work on two different boards with different distros.
The program is expected to run as a background process.
I have a head start. My favourite SCPI library has a LwIP SCPI server example.
A relative head start, that is, because I have to find out how to get all the dependencies - I want to develop on a Windows PC image.
If this project fails, it'll be because of my develop for Linux skills.
related blog
SCPI on a Linux Board - Part 1: Proof of Concept
SCPI on a Linux Board - Part 2a: PiFace Digital C programming
SCPI on a Linux Board - Part 2b: PiFace Digital C++ programming
SCPI on a Linux Board - Part 3: TCP/IP Socket C++ programming
SCPI on a Linux Board - Part 4: TCP/IP SCPI and Instrument Service
SCPI on a Linux Board - Part 4b: TCP/IP SCPI and Instrument Service 100% Working
SCPI on a Linux Board - Part 4c: TCP/IP SCPI and Instrument Service - Run as a Daemon
SCPI on a Linux Board - Part 5a: LabVIEW Driver for LAB Switch: Open, Close and Switch functions
    Jan Cumps over 8 years ago in reply to Jan Cumps +4
    Yay! It works. Above is the capture of a LabVIEW back and forth communication - with the Raspberry Pi as a VISA TCP/IP device. *IDN? command sent, and the reply from the Pi arrived at LabVIEW.
    DAB over 8 years ago +3
    Good luck Jan. DAB
    Jan Cumps over 8 years ago in reply to Jan Cumps +3
    what's not working ok: even though I get a reply, the Visa Read block in LabVIEW throws a timeout error. when I close a connection (regardless of telnet, LabVIEW), the service on the Raspberry Pi goes…
    Good luck Jan.
    Good luck Jan.
