Pi Chef Design Challenge
  • Pi Chef Design Challenge
Blog The Spice of Pi - Glenn blog # 6
  • Author Author: glennvanderveer
  • Date Created: 22 Mar 2018 2:08 AM Date Created
  • Views 1216 views
  • Likes 8 likes
  • google voice hat
  • pi chef design challenge
  • google aiy voice kit
  • pi chef
  • google speech api
glennvanderveer
glennvanderveer
22 Mar 2018
Another quick update.  This mainly deals with the fidgeting servos.  e14phil suggested using the pigpio library try to eliminate the twitches.  I finally was able to get to do this and here is a video of the results:
You will notice that the delay between the servo moving is blocking the AIY voice recognizer from running. That is why the assistant does not respond to my Ok Google request.  The first delay is 100 ms which is not announced on the video, and then I bumped it up to 1 second which I do mention before the servo starts spinning.  With this library, there is very little fidgeting.  Now I need to get it to respond to voice commands...
Also dougw, I think this is what you wanted to fix your icon on the desktop not executing your AIY scipt: https://raspberrypi.stackexchange.com/questions/65744/launch-python-script-in-desktop-without-root-privileges .  You have to make sure that the .desktop file that you create, in the permissions tab, is set to be able to execute by everyone.
Design Challenge Links:
About the challenge
The other challengers
The kit
Terms & Conditions
Summaries by Charles Gantt
Project Links:
Blog Doug 1 - The Concept
Blog Glenn 1 - AIY Voice Kit Unboxing
Blog Doug 2 - The Block Diagram and Bill of Materials
Blog Doug 3 - Spice Jar Lift Mechanism
Blog Glenn 2 - Firmware Considerations
Blog Doug 4 - Carousel Design
Blog Doug 5 - Platter Rotation Mechanism
The Spice of Pi - Blog Glenn 3
Blog Doug 6 - 3D Printed Platter Parts
Blog Doug 7 - Main Drive Assembly
Blog Doug 8 - Working Carousel
Blog Doug 9 - Google Assistant
Blog Doug 10 - Pi Enclosure
The Spice of Pi - Glenn blog #4
The Spice of Pi - Glenn blog #5
    dougw over 8 years ago +1
    Very nice - it looks like there is plenty of accuracy to handle 16 platter angles. Thanks for the shortcut tip...
    genebren over 8 years ago +1
    Nice update on your servo control. Hopefully you can find the proper mix of delays and other fixes to give you the smooth servo action that you need, without causing the spice tray to 'crawl' into position…
  • three-phase
    three-phase over 8 years ago +1
    Good to see you have found a solution to the jittering. He's not a bad lad that e14phil Kind regards
    Nice update on your servo control. Hopefully you can find the proper mix of delays and other fixes to give you the smooth servo action that you need, without causing the spice tray to 'crawl' into position.
    Good luck,
    Gene
    Good luck,
    Gene
