Pi Chef Design Challenge
  • Pi Chef Design Challenge
Blog The Spice of Pi - Glenn Blog # 7
  • Author Author: glennvanderveer
  • Date Created: 24 Mar 2018 7:12 PM Date Created
  • Views 951 views
  • google voice hat
  • pi chef*
  • google aiy voice kit
  • google speech api
glennvanderveer
glennvanderveer
24 Mar 2018
WE HAVE LIFTOFF!!!
Friday dougw gave me the assembled platter and some spice bottles to help work on the code and voice control aspect of the project.  So I rushed home to de-solder my servos from my Voice board and attach some headers to attach the platter servos.  It was then I remembered that I had lent my soldering iron to my brother (who lives about an hour away) to do some rework on his 'vintage' stereo amplifier collection.  So this morning I made a trip to the electronics store to pick up a new iron and some solder.
After I had soldered on the headers I attached the servos and made them move, although not by voice command yet...
You will see that the outer ring bottles seem to lift higher than the inner ring.  I am quite sure that the lift action is the same on both sides, so I think it is because the inner lifter is not as close to the center of the hole as the outer ring, as shown by the picture below:
I also spun the platter in a circle, and watched it go back and forth:
Now to find the right PWM values for the outer ring so I can stop the platter in the middle of the jar so the lifter has easy access to the jar with out hitting the edges accidentally.
Design Challenge Links:
About the challenge
The other challengers
The kit
Terms & Conditions
Summaries by Charles Gantt
Project Links:
Blog Doug 1 - The Concept
Blog Glenn 1 - AIY Voice Kit Unboxing
Blog Doug 2 - The Block Diagram and Bill of Materials
Blog Doug 3 - Spice Jar Lift Mechanism
Blog Glenn 2 - Firmware Considerations
Blog Doug 4 - Carousel Design
Blog Doug 5 - Platter Rotation Mechanism
The Spice of Pi - Blog Glenn 3
Blog Doug 6 - 3D Printed Platter Parts
Blog Doug 7 - Main Drive Assembly
Blog Doug 8 - Working Carousel
Blog Doug 9 - Google Assistant
Blog Doug 10 - Pi Enclosure
The Spice of Pi - Glenn blog #4
The Spice of Pi - Glenn blog #5
The Spice of Pi - Glenn blog # 6
    genebren over 8 years ago +1
    Great update. Good to see the platter and lifter control working. It will be great to see the final steps. Keep up the good work! Gene
    Gene
    Gene
