Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Sci Fi Your Pi: PiDesk - Project Update #12
  • Author Author: fvan
  • Date Created: 24 Jun 2015 4:42 PM Date Created
  • Views 1655 views
  • Comments 8 comments
  • design_challenge
  • touch_motion_controls
  • sci_fi_your_pi
fvan
fvan
24 Jun 2015
Previous posts for this project:
  • Sci Fi Your Pi: PiDesk - Project Description
  • Sci Fi Your Pi: PiDesk - Project Update #1
  • Sci Fi Your Pi: PiDesk - Guide: Setting Up the Raspberry Pi 2
  • Sci Fi Your Pi: PiDesk - Project Update #2
  • Sci Fi Your Pi: PiDesk - Review: Bare Conductive Touch Board
  • Sci Fi Your Pi: PiDesk - Project Update #3
  • Sci Fi Your Pi: PiDesk - Guide: Stepper Motors with Gertbot
  • Sci Fi Your Pi: PiDesk - Project Update #4
  • Sci Fi Your Pi: PiDesk - Project Update #5
  • Sci Fi Your Pi: PiDesk - Guide: Controlling NeoPixels with the Raspberry Pi A+/B+
  • Sci Fi Your Pi: PiDesk - Project Update #6
  • Sci Fi Your Pi: PiDesk - Project Update #7
  • Sci Fi Your Pi: PiDesk - Project Update #8
  • Sci Fi Your Pi: PiDesk - Project Update #9
  • Sci Fi Your Pi: PiDesk - Guide: Capacitive Touch with Atmel's AT42QT1070 Touch Sensor IC
  • Sci Fi Your Pi: PiDesk - Project Update #10
  • Sci Fi Your Pi: PiDesk - Guide: Magic Lamp with wireless charger, Adafruit Trinket & NeoPixels
  • Sci Fi Your Pi: PiDesk - Project Update #11
  • Project Update
Project Update
The sun was shining and I had some time to myself, ideal conditions to start cutting things and annoy the neighbours with the sound of powertools. I started working on the enclosure that will hold the computer that will slide in and out of the desk. Because the dimensions were beyond what my CNC can handle, everything was done by hand and I finally gave the router a try. I messed up here and there, but the result so far is more than acceptable image
Check out the picture gallery below to get an idea of the work that was done.
{gallery} Screen Enclosure
Two pieces: I cut out two pieces with the same dimensions out of a larger MDF board. The screen and Pi 2 wii be contained in between the two layers.
Dimensions: A cutout will be made for the usable part of the screen, grooves will be made to have the screen held in place.
Cutting: Using the same oscillating multitool as I used to cut the desk, I cut out the rectangle for the screen.
Pop: The cuts are very slim and straight enough for something done by hand. The piece popped out easily.
Guide: Using clamps and a spare piece of MDF, I made a guide for the router.
First time: My first time using the router, ever! Slipped away from the guide a few times, but no problem.
Smoother: The second side went a lot smoother as you can see from the picture above.
It fits: With the grooves routed on all four sides, the screen fits nicely.
Front: View from the front with screen inserted. As you can see, I messed up on one of the sides when the router cut too deep.
Fixed: Managed to fix the mistake from earlier using some wood filler. I'll be applying the same method to the corners to fix the cuts.
    Jan Cumps over 11 years ago +1
    kudos for not routing through your wooden table.
  • fvan
    fvan over 11 years ago in reply to Jan Cumps +1
    and not losing any fingers!
  • clem57
    clem57 over 11 years ago +1
    Yes, I like the screen holder. Clem
  • fvan
  • fvan
