Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog Sci Fi Your Pi: PiDesk - Project Update #17
  • Author Author: fvan
  • Date Created: 9 Aug 2015 8:09 PM Date Created
  • Views 2197 views
  • Comments 10 comments
  • design_challenge
  • touch_motion_controls
  • sci_fi_your_pi
fvan
fvan
9 Aug 2015
Previous posts for this project:
  • Sci Fi Your Pi: PiDesk - Project Description
  • Sci Fi Your Pi: PiDesk - Project Update #1
  • Sci Fi Your Pi: PiDesk - Guide: Setting Up the Raspberry Pi 2
  • Sci Fi Your Pi: PiDesk - Project Update #2
  • Sci Fi Your Pi: PiDesk - Review: Bare Conductive Touch Board
  • Sci Fi Your Pi: PiDesk - Project Update #3
  • Sci Fi Your Pi: PiDesk - Guide: Stepper Motors with Gertbot
  • Sci Fi Your Pi: PiDesk - Project Update #4
  • Sci Fi Your Pi: PiDesk - Project Update #5
  • Sci Fi Your Pi: PiDesk - Guide: Controlling NeoPixels with the Raspberry Pi A+/B+
  • Sci Fi Your Pi: PiDesk - Project Update #6
  • Sci Fi Your Pi: PiDesk - Project Update #7
  • Sci Fi Your Pi: PiDesk - Project Update #8
  • Sci Fi Your Pi: PiDesk - Project Update #9
  • Sci Fi Your Pi: PiDesk - Guide: Capacitive Touch with Atmel's AT42QT1070 Touch Sensor IC
  • Sci Fi Your Pi: PiDesk - Project Update #10
  • Sci Fi Your Pi: PiDesk - Guide: Magic Lamp with wireless charger, Adafruit Trinket & NeoPixels
  • Sci Fi Your Pi: PiDesk - Project Update #11
  • Sci Fi Your Pi: PiDesk - Project Update #12
  • Sci Fi Your Pi: PiDesk - Project Update #13
  • Sci Fi Your Pi: PiDesk - Project Update #14
  • Sci Fi Your Pi: PiDesk - Project Update #15
  • Sci Fi Your Pi: PiDesk - Project Update #16
  • Sci Fi Your Pi: PiDesk - Guide: Endstops with Gertbot
  • Project Update
    • Touch controls
    • Power distribution
    • Motors and endstops
    • Cable management
    • Python
Project Update
It's been a busy week for me, not so much for the desk though. First, I went on holiday with my wife and kids to the belgian coast for the week, and I closed the weekend by introducing a visitor from New Zealand to belgian beers and strolling through Brussels together with another belgian member. First one to guess both members gets 10 points. (No real points, no prize can be claimed!)
Anyway, back on topic ... there have been little bits of progress on the desk. Let's go over them ...
Touch controls
The conductive pads and tracks have been laid out on the desk. All that is left to do is to hook them up to the prototyping board I made last time and hope they work as expected!
I started off by laying out the copper tracks and then drew the shapes of the contact pads using a drinking glass and a marker. Afterwards, I carefully painted the pads using conductive paint.
Power distribution
To simplify things, I'd like to power the entire setup from a single power supply. The two voltages required are 5V (Pi, LED strip) and 12V (Stepper motors, laptop screen), so I plan to use a single 12V power supply and have a converter to step it down to 5V for the components that require it. This also means that different splitters are required to ensure every device gets powered.
Motors and endstops
I've mounted the motors at the bottom of the frame using some MakerBeam pieces I had around. With my printer still giving me headaches, I ended up taking a piece of wood, drilling holes for the threaded rods to fit through and make a larger hole on the bottom side holding the two captive nuts. First tests indicate the stepper motors have no trouble handling the weight and can lift the screen assembly as expected. I'll try to get a video out for this in the coming days.
The endstops have been installed on the side of the frame, the first one triggering when the screen is lowered flush with the desk, the other one when it's been raised enough. You can see both switches on the picture in the next paragraph.
Cable management
Another thing I managed to do, is some basic cable management, ensuring the wires of the motors and endstops are tucked away neatly. I used a plastic cable guide for that, which I attached on the side of the screen's frame.
Python
Finally, I started merging the different bits of code I created over the course of the challenge, combining all the different features like sound effects, neopixel control, capacitive touch, etc ... I haven't been able to test it yet, that's planned for next week. If everything ends up working as expected, I can start finalising the build and get testing and tweaking. I'm not using a particular IDE for this, as I've found the Sublime text editor to do the necessary syntax highlighting and completion.
    mcb1 over 11 years ago +3
    Was that the guy I saw hanging around with these two suspicious characters ....?
  • fvan
    fvan over 11 years ago in reply to mcb1 +2
    I know the guy in the middle, but who are the other two ?
  • fvan
    fvan over 11 years ago in reply to balearicdynamics +1
    Hi Enrico, I'm using the paint because I have it and it's easy to apply. You could just as well use some aluminium foil I suppose. The paint was part of a kickstarter I backed, so I might as well use it…
  • Problemchild
    Problemchild over 11 years ago in reply to mcb1
    Good one are you both drumming up new staff then Mark ????
    balearicdynamics over 11 years ago in reply to fvan
    Hi Frederick, thank you for the clarification. I saw a lot of ads about this conductive paint that seemed the future of the flexible touch sensors and I was just wondering what new kind of product it was image
    Enrico
  • fvan
    Hi Enrico,
    The paint was part of a kickstarter I backed, so I might as well use it before it dries up image
    As for the shapes, I picked circles for no particular reason, but it could be squares, triangles, blobs, ...
    Frederick
    Nice and polite, Frederick. This project is growing fine.
    I have never used the conductive paint and I am curious to see how much this works fine. It seems me a bit too expansive. As you are using exactly rounded surfaces was not the worth to use some cheap conductor? Or the paint has some special property? Sorry but I have never managed this kind of products.
    Enrico
