Legacy Personal Blogs SimpleLink™︎ Sub-1 GHz Wireless Microcontroller blog series: from Unbox to Building a Transmitter
  • Date Created: 4 Aug 2016 9:13 AM Date Created
  • Views 1206 views
  • cc1310
  • sigfox
  • simplelink
  • sub_1ghz
  • ti_rt
4 Aug 2016
I've written a series of blogs to get started with the SimpleLink CC1310 Sub-1 GHz LaunchPads.
The first blog starts with unboxing and checking the demo application. Then I move step by step towards Sender and Receiver config, debugging both Sender and Receiver at the same time and understanding the functionality.
The series ends with instructions to build a first  Transmitter from scratch.
I had pointed out in the SimpleLinkTm Sub-1 GHz Wireless Microcontroller RoadTest that 2 modules are required for a meaningful evaluation. I received the two CC1310 SimpleLink LaunchPads from Texas Instruments in return.
The blog series is the write-up of my beginner experience with the devices. I had no prior knowledge.
The learning curve:
It took me one month to go from zero experience to building a working radio program. There's loads of knowledge to be gained in the beginning. Now, after that month, I can build a radio Sender or Receiver project in 15 minutes.
So prepare for an intensive first learning ramp-up, and a smooth use once you 'get it'.
{gallery} SimpleLink CC1310
The First Transmitter program
Test the Sender and Receiver with SmartRF Studio
The Sender and Receiver Debugged at the same time, on the same computer.
Visual clues to identify your sender and receiver session in PuTTY
Visual clues to identify your sender and receiver session in Code Composer Studio
Measure the Power Consumpion of the Wireless Sensor Network example and Sensor Controller Engine
SIGFOX connection
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Check  Received Signal Strength
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Use SmartRF to Try Radio Configs
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Debug 2 LaunchPads at the Same Time
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Side Note: Recognise your PuTTY Sessions
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Side Note: Recognise your Code Composer Studio Sessions
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Debug a Sender to Receiver Conversation
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Side Note: Start a Fresh Project
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Create a Transmitter with SmartRF Studio Part 1
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Create a Transmitter with SmartRF Studio Part 2
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Sensor Controller Engine Part 1: Dry Run
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Sensor Controller Engine Part 2: RTOS Integration
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Sensor Controller Engine Part 3: Wake Up Options
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - Side Note : Measure Power Use of Sensor Controller Engine
SimpleLinkTm Sub-1 GHz Wireless Microcontroller - ToolKit for Range Testing
on TI E2E community: How to connect a CC1310 LaunchPad to the SIGFOX network
    DAB over 10 years ago +2
    Great post Jan. Thanks for making the screen prints large enough for us old folk to read. DAB
    Great post Jan.
    Thanks for making the screen prints large enough for us old folk to read. image
    Great post Jan.
    Jan Cumps over 10 years ago in reply to DAB
    They are sized to fit in a 1280 * 720 window. That's my frame for creating movies.
