FPGA
FPGA
Blog Arty S7 50 ArtyBot - Bot Application Framework
  • Author Author: javagoza
  • Date Created: 11 Jul 2022 11:45 AM Date Created
  • Views 5413 views
  • Likes 10 likes
  • driver
  • arty-s7
  • hbridge
  • dc motors
  • pwm
  • xilinx
  • robot
  • fpga
  • vivado
  • digilent
  • framework
  • vitis
  • Spartan_Migration
  • microblaze
javagoza
javagoza
11 Jul 2022
In this post I describe the Bot Application Framework that I have prepared for the Digilent Arty S7 based bot and provides an overview of the Arty S7 Bot Application Framework, its architecture, components, and usage model.
This post is part 7 of my contribution to the "7 Ways to Leave Your Spartan-6" program, learning about the Xilinx Spartan-7 FPGA on the Digilent Arty S7 50 board.
"7 Ways to Leave Your Spartan-6" related posts
1 Arty S7 50 First Power Up and Hardware-Only Blinky
2 Arty S7 50 First Baremetal Software Project
3 Arty S7 50 Rapid Prototyping - Environmental Monitor
4 Arty S7 50 ArtyBot Pulse Width Modulation (PWM) for Motor Speed Control
5 Arty S7 50 ArtyBot Custom AXI4 Lite IP Peripheral for Sensing Motor Rotational Speed
6 Arty S7 50 ArtyBot How to Store MicroBlaze Program in the Quad-SPI Flash from Vivado
7 Arty S7 50 ArtyBot - Bot Application Framework
8 Arty S7 50 ArtyBot becomes Emubot, an educational robot for young children
9 Arty S7 50 ArtyBot - Color sensing and line follower
10 Arty S7 50 The Spartan-6 Migration Path Game. Learning the Differences Between Spartan-6 and Spartan-7 FPGAs
11 Arty S7 50 ArtyBot ToF Sensor for Obstacle Avoidance. Vivado Hierarchical Blocks
12 "7 Ways to Leave Your Spartan-6 FPGA" program. My summary
13 Arty S7 50 VGA Thermal Imaging Camera
Short video demonstrating the main driving functions using the Arty S7 Bot Framework
Hardware and Development Environment
For this Bot Application Framework you'll need, Windows 10, AMD Xilinx Vivado ML 2021.1 and the following hardware:
Product Name Manufacturer Datasheet
Arty S7 50  Digilent  Buy Now
TI-RSLK element14 Buy Now
PmodOLED Digilent Buy Now
Components and Architecture of the Bot Application Framework
The Bot Application Framework is a Hardware Abstraction Layer (HAL) that provides a function API-based service to higher-level layers that allows them to perform hardware-oriented operations independent of the actual details of the hardware.
The figure shows a representative block diagram of the Bot Application Framework in relation with a possible custom application for the bot
The Driving Driver depends on:
  • Motor Position Driver;
  • Speed PID Controller;
  • Distance PID Controller;
  • Motor PWM Speed Controller;
  • and the H-Bridge Drive
Framework configuration
The Bot Application Framework is highly customizable.
You can configure the bot parameters with the bot_parameters.h header file depending on your FPGA configuration.
  • AXI GPIO Address and Channel for the 2 board RGB LEDS
  • AXI GPIO Address and Channel for the 4 board red LEDS
  • AXI GPIO Address and Channel for the 4 board switches
  • AXI GPIO Address and Channel for the 4 board push buttons
  • AXI GPIO Address and Channel for the 4 dual hbridge control signals
  • Right Motor Timer /Counter Device ID
  • Left Motor Timer /Counter Device ID
  • Motor Speed PWM Control signal period in nanoseconds
  • Motor position feedback AXI Base Address
  • Gear box motor ratio
  • Motor Position Module Clock Frequency
  • OLED AXI LITE GPIO Base Address
  • OLED AXI LITE SPI Base Address
  • OLED white background or black background
  • Proportional Constant for the Rotational Motor Speed PID control
  • Integral factor for the Rotational Motor Speed PID control
  • Derivative factor for the Rotational Motor Speed PID control
  • Proportional factor for the Traveled Distance PID control
  • Integral factor for the Traveled Distance PID control
  • Derivative factor for the Traveled Distance PID control
  • Base duty cycle, base speed for the PID controllers
  • Distance correction factor when rotating
  • Distance correction factors when driving straight
Framework Drivers
The Bot Application Framework provides several drivers that allows to perform hardware-oriented operations independent of the actual details of the hardware.
  • Bot Driver: Initializes the whole framework or specific parts of the framework.
  • Driving Driver : Functions to drive the bot: forward, backward, turn left. turn right and swinging on both wheels
  • Motor Position: Keep track of motor rotation counters.
  • Speed PID Controller: PID control with goal of maintaining the same target speed for both wheels
  • Distance PID Controller: PID control with goal of maintaining the same traveled distance for both wheels
  • Motor PWM Speed Controller: Motor Speed controller Controls with Pulse Width Modulated signals
  • H-Bridge Driver: Control motor direction and sleep mode
  • Buttons Driver: Driver to poll to the four board buttons state
  • Switches Driver: Driver to poll to the four board switches state
  • Leds Driver: Driver to control the four board red leds state
  • RGB Leds Driver:  Driver to control the four board RGB leds state
  • OLED Extensions: Functions to extend OLED Driver as displaying integers and floats
  • OLED Driver: Functions to control the OLED display
Bot Driver
  • BOT_init()
  • BOT_init_driving_driver()
  • BOT_init_gpio_inputs()
  • BOT_init_gpio_outputs()
  • BOT_init_oled_display()
Driving Driver
  • DRIVING_DRIVER_end()
  • DRIVING_DRIVER_init()
  • DRIVING_DRIVER_drive_backward_cm()
  • DRIVING_DRIVER_drive_backward_continuous_cm()
  • DRIVING_DRIVER_drive_forward_cm()
  • DRIVING_DRIVER_drive_forward_continuous_cm()
  • DRIVING_DRIVER_set_speed()
  • DRIVING_DRIVER_swing_turn_left_degrees()
  • DRIVING_DRIVER_swing_turn_right_degrees()
  • DRIVING_DRIVER_turn_left_continuous_degrees()
  • DRIVING_DRIVER_turn_left_degrees()
  • DRIVING_DRIVER_turn_right_continuous_degrees()
  • DRIVING_DRIVER_turn_right_degrees()
  • MOTOR_POSITION_clear_pos_counter()
  • MOTOR_POSITION_clear_speed_counters()
  • MOTOR_POSITION_get_distance_traveled()
  • MOTOR_POSITION_get_edge_counts()
  • MOTOR_POSITION_get_position_difference()
  • MOTOR_POSITION_get_positions()
  • MOTOR_POSITION_get_speeds()
  • MOTOR_POSITION_init()
  • SPEED_PID_CONTROLLER_init()
  • SPEED_PID_CONTROLLER_reset_errors()
  • SPEED_PID_CONTROLLER_get_new_outputs()
  • SPEED_PID_CONTROLLER_set_duty_cycle()
  • DISTANCE_PID_CONTROLLER_get_new_outputs()
  • DISTANCE_PID_CONTROLLER_init()
  • DISTANCE_PID_CONTROLLER_reset_errors()
  • DISTANCE_PID_CONTROLLER_set_duty_cycle()
  • PWM_DRIVER_disable()
  • PWM_DRIVER_enable()
  • PWM_DRIVER_get_duty_pct()
  • PWM_DRIVER_get_period_ns()
  • PWM_DRIVER_init()
  • PWM_DRIVER_set_duty_pct()
  • PWM_DRIVER_set_period_ns()
H-Bridge Driver
  • HBRIDGE_DRIVER_get_hbridge_state()
  • HBRIDGE_DRIVER_init()
  • HBRIDGE_DRIVER_left_motor_backward()
  • HBRIDGE_DRIVER_left_motor_direction_toggle()
  • HBRIDGE_DRIVER_left_motor_forward()
  • HBRIDGE_DRIVER_right_motor_backward()
  • HBRIDGE_DRIVER_right_motor_direction_toggle()
  • HBRIDGE_DRIVER_right_motor_forward()
  • HBRIDGE_DRIVER_set_direction()
  • HBRIDGE_DRIVER_set_hbridge_state()
Board Buttons Driver
 Driver to poll to the four board buttons state with unbouncing function
  • BUTTONS_DRIVER_button1_pressed()
  • BUTTONS_DRIVER_button2_pressed()
  • BUTTONS_DRIVER_button3_pressed()
  • BUTTONS_DRIVER_button4_pressed()
  • BUTTONS_DRIVER_get_state()
  • BUTTONS_DRIVER_init()
  • BUTTONS_DRIVER_poll()
  • BUTTONS_DRIVER_reset()
Board Switches Driver
 Driver to poll to the four board switches state with unbouncing function
  • SWITCHES_DRIVER_get_state()
  • SWITCHES_DRIVER_init()
  • SWITCHES_DRIVER_poll()
  • SWITCHES_DRIVER_poll_switch1()
  • SWITCHES_DRIVER_poll_switch2()
  • SWITCHES_DRIVER_poll_switch3()
  • SWITCHES_DRIVER_poll_switch4()
Board Red Leds Driver
  • LEDS_DRIVER_get_leds_state()
  • LEDS_DRIVER_init()
  • LEDS_DRIVER_set_led1_off()
  • LEDS_DRIVER_set_led1_on()
  • LEDS_DRIVER_set_led1_toggle()
  • LEDS_DRIVER_set_led2_off()
  • LEDS_DRIVER_set_led2_on()
  • LEDS_DRIVER_set_led2_toggle()
  • LEDS_DRIVER_set_led3_off()
  • LEDS_DRIVER_set_led3_on()
  • LEDS_DRIVER_set_led3_toggle()
  • LEDS_DRIVER_set_led4_off()
  • LEDS_DRIVER_set_led4_on()
  • LEDS_DRIVER_set_led4_toggle()
  • LEDS_DRIVER_set_leds_state()
Board RGB Leds Driver
  • RGB_LEDS_DRIVER_get_rgb_leds_state()
  • RGB_LEDS_DRIVER_init()
  • RGB_LEDS_DRIVER_set_rgb_led1_blue_off()
  • RGB_LEDS_DRIVER_set_rgb_led1_blue_on()
  • RGB_LEDS_DRIVER_set_rgb_led1_blue_toggle()
  • RGB_LEDS_DRIVER_set_rgb_led1_green_off()
  • RGB_LEDS_DRIVER_set_rgb_led1_green_on()
  • RGB_LEDS_DRIVER_set_rgb_led1_green_toggle()
  • RGB_LEDS_DRIVER_set_rgb_led1_red_off()
  • RGB_LEDS_DRIVER_set_rgb_led1_red_on()
  • RGB_LEDS_DRIVER_set_rgb_led1_red_toggle()
  • RGB_LEDS_DRIVER_set_rgb_led1_set_color()
  • RGB_LEDS_DRIVER_set_rgb_led2_blue_off()
  • RGB_LEDS_DRIVER_set_rgb_led2_blue_on()
  • RGB_LEDS_DRIVER_set_rgb_led2_blue_toggle()
  • RGB_LEDS_DRIVER_set_rgb_led2_green_off()
  • RGB_LEDS_DRIVER_set_rgb_led2_green_on()
  • RGB_LEDS_DRIVER_set_rgb_led2_green_toggle()
  • RGB_LEDS_DRIVER_set_rgb_led2_red_off()
  • RGB_LEDS_DRIVER_set_rgb_led2_red_on()
  • RGB_LEDS_DRIVER_set_rgb_led2_red_toggle()
  • RGB_LEDS_DRIVER_set_rgb_led2_set_color()
  • RGB_LEDS_DRIVER_set_rgb_leds_state()
OLED Extensions
  • OLED_putFloatVariable()
  • OLED_putIntVariable()
Usage Model
Initialization using Driving Drivers, Led Driver and Buttons Driver
void test_bot() {
    BotDrivers botDrivers;
    xil_printf("BOT TEST Started\n\r");
    BOT_init(&botDrivers);
    while (1) {
        LEDS_DRIVER_set_led1_toggle(&botDrivers.ledsDriver);
        oled_show_home(&botDrivers.oled, "  PRESS BUTTON");
        if (BUTTONS_DRIVER_button1_pressed(&botDrivers.buttonsDriver)) {
            play_button_1_show(&botDrivers.drivingDriver, &botDrivers.oled);
            BUTTONS_DRIVER_reset(&botDrivers.buttonsDriver);
        if (BUTTONS_DRIVER_button2_pressed(&botDrivers.buttonsDriver)) {
            play_button_2_show(&botDrivers.drivingDriver, &botDrivers.oled);
        if (BUTTONS_DRIVER_button3_pressed(&botDrivers.buttonsDriver)) {
            play_button_3_show(&botDrivers.drivingDriver, &botDrivers.oled);
        usleep(5000);
    DRIVING_DRIVER_end(&botDrivers.drivingDriver);
    OLED_End(&botDrivers.oled);
    xil_printf("BOT TEST Finished\n\r");
Driving the bot
void play_button_3_show(DrivingDriver* botDriver, PmodOLED* oled) {
    xil_printf("BTN2 pressed\n\r");
    sleep(1);
    oled_show_action(oled, "  SWING LEFT 90");
    DRIVING_DRIVER_swing_turn_left_degrees(botDriver, 90);
    usleep(50000);
    oled_show_action(oled, "  FORWARD 7 cm");
    DRIVING_DRIVER_drive_forward_cm(botDriver, 7);
    usleep(50000);
    oled_show_action(oled, "  TURN RIGHT 90");
    DRIVING_DRIVER_turn_right_degrees(botDriver, 90);
    usleep(50000);
    usleep(50000);
    sleep(1);
    DRIVING_DRIVER_swing_turn_right_degrees(botDriver, 90);
    usleep(50000);
    usleep(50000);
    oled_show_action(oled, "TURN LEFT 90");
    DRIVING_DRIVER_turn_left_degrees(botDriver, 90);
    usleep(50000);
    usleep(50000);
    sleep(1);
Using only LEDs and push buttons
void test_leds_and_buttons() {
    LedsDriver ledsDriver;
    RgbLedsDriver rgbLedsDriver;
    ButtonsDriver buttonsDriver;
    SwitchesDriver switchesDriver;
    XGpio GpioLedsAndRgbLeds; /* Dual GPIO Driver for LEDs and RGB LEDS*/
    XGpio GpioSwitchsAndButtons; /* Dual GPIO Driver for Switchs and Push Buttons */
    LEDS_DRIVER_init(&ledsDriver, &GpioLedsAndRgbLeds,
    BOT_LEDS_RGBLEDS_DEVICE_ID,
    BOT_LED_CHANNEL, 0b0000);
    RGB_LEDS_DRIVER_init(&rgbLedsDriver, &GpioLedsAndRgbLeds,
    BOT_RGB_LED_CHANNEL, 0b000000);
    BUTTONS_DRIVER_init(&buttonsDriver, &GpioSwitchsAndButtons,
    BOT_BUTTONS_SWITCHES_DEVICE_ID, BOT_BUTTONS_CHANNEL);
    SWITCHES_DRIVER_init(&switchesDriver, &GpioSwitchsAndButtons,
    BOT_BUTTONS_SWITCHES_DEVICE_ID, BOT_SWITCHES_CHANNEL);
    unsigned long semiperiod = 250000;
    xil_printf("LED TEST Started\n\r");
    LEDS_DRIVER_set_led1_toggle(&ledsDriver);
    usleep(semiperiod);
    usleep(semiperiod);
    LEDS_DRIVER_set_led2_toggle(&ledsDriver);
    usleep(semiperiod);
    usleep(semiperiod);
    LEDS_DRIVER_set_led3_toggle(&ledsDriver);
    usleep(semiperiod);
    usleep(semiperiod);
    LEDS_DRIVER_set_led4_toggle(&ledsDriver);
    usleep(semiperiod);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_RED);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_GREEN);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_BLUE);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_CYAN);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_MAGENTA);
    usleep(semiperiod);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_YELLOW);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_WHITE);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led1_set_color(&rgbLedsDriver, COLOR_BLACK);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_RED);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_GREEN);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_BLUE);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_CYAN);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_MAGENTA);
    usleep(semiperiod);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_YELLOW);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_WHITE);
    usleep(semiperiod);
    RGB_LEDS_DRIVER_set_rgb_led2_set_color(&rgbLedsDriver, COLOR_BLACK);
    usleep(semiperiod);
    while (!BUTTONS_DRIVER_button3_pressed(&buttonsDriver)) {
        LEDS_DRIVER_set_leds_state(&ledsDriver,
                BUTTONS_DRIVER_poll(&buttonsDriver));
        RGB_LEDS_DRIVER_set_rgb_leds_state(&rgbLedsDriver,
                SWITCHES_DRIVER_poll(&switchesDriver) << 2
                        | SWITCHES_DRIVER_poll(&switchesDriver));
    xil_printf("LED TEST Finished\n\r");
Github repository
Bot Application Framework Github Repository
Bot Framework documentation
See the complete framework library documentation:
Credits
Parts of the driving library are inspired on Arvin Tang's ArtyBot Library
References
  • GitHub - javagoza/E14SpartanMigrationProgram: Project repository for my entry in the Element14 community's "7 Ways to Leave Your Spartan-6" program.
Summary
It has been a long development. The libraries are quite extensive and cover all the hardware configured so far in the FPGA for our Bot.
This framework will allow us to carry out new experiments with our robot with less effort.
  • javagoza
    javagoza over 4 years ago
    I have submitted a new blog with an educational application using this Bot Application Framework: Emubot, an educational robot for young children
  • javagoza
