Test & Tools
Test & Tools
Blog SCPI on a Linux Board - Letter of Intent
  • Date Created: 27 Apr 2018 5:41 PM Date Created
  • Views 5938 views
  • Likes 14 likes
  • Comments 21 comments
  • pi
  • bbb
  • BeagleBone
  • raspberrypi
  • scpi
27 Apr 2018
I'm trying to build a SCPI shell for Linux.
I'd like to have it working over TCP/IP on a Raspberry Pi and a BeagleBone.
tl;dr It works. The rest of the blog series explains how to build a lab automation device that controls 8 outputs (2 of them relays), and read 8 inputs. With a Raspberry Pi and a PiFace Digital (2).
Here on element14, we've been playing with SCPI and microcontrollers. We have several instruments working on MSP432, Arduino and Hercules devices.
This time I'd like to get a Linux instrument up. To get some device independence, I'll try to make the source work on two different boards with different distros.
The program is expected to run as a background process.
I have a head start. My favourite SCPI library has a LwIP SCPI server example.
A relative head start, that is, because I have to find out how to get all the dependencies - I want to develop on a Windows PC image.
If this project fails, it'll be because of my develop for Linux skills.
related blog
SCPI on a Linux Board - Part 1: Proof of Concept
SCPI on a Linux Board - Part 2a: PiFace Digital C programming
SCPI on a Linux Board - Part 2b: PiFace Digital C++ programming
SCPI on a Linux Board - Part 3: TCP/IP Socket C++ programming
SCPI on a Linux Board - Part 4: TCP/IP SCPI and Instrument Service
SCPI on a Linux Board - Part 4b: TCP/IP SCPI and Instrument Service 100% Working
SCPI on a Linux Board - Part 4c: TCP/IP SCPI and Instrument Service - Run as a Daemon
SCPI on a Linux Board - Part 5a: LabVIEW Driver for LAB Switch: Open, Close and Switch functions
    Jan Cumps over 8 years ago in reply to Jan Cumps +4
    Yay! It works. Above is the capture of a LabVIEW back and forth communication - with the Raspberry Pi as a VISA TCP/IP device. *IDN? command sent, and the reply from the Pi arrived at LabVIEW.
    DAB over 8 years ago +3
    Good luck Jan. DAB
    Jan Cumps over 8 years ago in reply to Jan Cumps +3
    what's not working ok: even though I get a reply, the Visa Read block in LabVIEW throws a timeout error. when I close a connection (regardless of telnet, LabVIEW), the service on the Raspberry Pi goes…
    Inspired by the BeagleBone Webcast series, I'm picking up this thread again (I have a few running in parallel these days image )
    I've installed the latest Debian on my BB and have just successfully cross-compiled and loaded a test program.
    Here's an action shot of the active debug session:
    For this exercise, there should be no difference between the Raspberry Pi and BeagleBone for the SCPI library and network socket API.
    It's only when talking to hardware that things will be different, but that's not the scope of this series.
