Test & Tools
Test & Tools
Documents Programmable Electronic Load - Analyse the Summing Node Zero Point
  • Date Created: 1 Dec 2017 4:08 PM Date Created
  • Last Updated Last Updated: 15 May 2020 3:38 PM
  • Views 12907 views
  • Likes 8 likes
  • Comments 107 comments
This blog documents investigates the feedback node of the electronic load that Robert Peter Oakes, jc2048 and Jan Cumps are designing.
It's an important spot in the load's design. It measures the set point and the feedback from the output.
When the output is driven to 0, it should be on a potential as close as possible to 0 V.
On the first prototype it's -0.2 V. Not so much off, but the negative value  influences our ADC measurements.
This document checks how we can get this node to 0 V.
Because this document is evolving, some comments below may be out of sync with the content. That's because the content is adapted based on the conversation.
The measurements taken here are based on the original design, without R32 in place and U3B + tied to ground.
The current sense side of R7 is connected to ground, and a variable negative voltage from 0 V down is applied to the current sense side of R8 to simulate current being sensed.
The circuit isn't complex. The set point is driven by a DAC. It's set to 0 for this test.
The second input to this node is OpAmp 3C. It has both inputs tied to ground so should theoretically have 0 V at the output.
On my board I measure a potential of -0.212V at the left side of R33.
I hope to get this closer to 0 V to ease the ADC a bit - its performance degrades with negative voltage at its inputs.
Like the other blogs for the electronic load, this is a working document that will be updated with findings from anyone who wants to chime in.
Behaviour at 0V
buzy image
  • metrology
  • differentiator
  • boosterpack
  • opamp
  • msp432
  • launchpad
  • analog
  • laboratory
  • instrument
  • jc2048
    jc2048 over 8 years ago in reply to Robert Peter Oakes +4
    As you say, changing the op-amp is one possibility. There are bipolar op-amps with much lower bias currents, but an alternative nowadays is a precision CMOS op-amp (you'd have to check whether other characteristics…
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago +3
    To hopefully simplify things a little We have this, Upper op amp is simply to provide an inversion of the measured value back tot he ADC, hence the gain of -1 Lower right op amp measures the volts across…
  • jc2048
    jc2048 over 8 years ago in reply to Jan Cumps +3
    Love the advertisement for "John's excellent probes". It's like one those things from the old days of American TV where the presenter would suddenly turn, look very earnestly at the camera, and start reading…
    Jan Cumps over 8 years ago
    I'm going to redo this exercise now that the OpAmps are replaced with lower bias ones and I have more precise measurement tools.
    From the blog Programmable Electronic Load - LabVIEW Test Automation: Characterise the Instrument we can see that the behaviour is very linear.
    But we have a non-0 start point. When th DAC is driven to 0, there is an output current flowing of a few mA.
    I assume that it's our control circuit that's doing that, because if I disable the output (pull the gate to ground), the current that flows is neglectable. And it's the same FET that's fully blocking the current flow then.
    I've re-stacked the load so that the control board is on top and I have easier access to the measure point.
    I can't use the LCD display in that case. I'll use the SCPI interface to set values.
    I'll measure DAC output and the voltages at relevant control circuit points to see what drives the FET to conduct a little.
    I think I'll document the results in new blog post. We can then think on measures to get the lowest current lower than 2 mA.
    Jan Cumps over 8 years ago in reply to Jan Cumps
    I've been checking for a while and get 0.6 µA when measuring with a multimeter. I usd a fairly high input voltage of 14 V to compensate for any cable resistance.
    When I shortcut the DAC1 output, I get almost the same as when the output is off. So it seems that the offset is caused by offset of the DAC.
    When driving the DAC to 0, I get 0.731 mV output. The measured voltage over the sensor resistor is then 0.054 mV.
    If I shortcut DAC A, I measure 0.005 mV over the 0R05 sense resistor. That's virtually the same as INPUT OFF (0.003 mV).
    I'll have to check if I can deal with the positive DAC offset ...
    When I remove everything from the DAC, the offset voltage is 0.529 mV.
    Same as when the eload is connected, the ADC DAC only starts to ramp up from that offset once the DAC value is close to 100.
    Jan Cumps over 8 years ago in reply to jc2048
    I'm adapting the test set to allow 4 additional measures using an oscilloscope. I'll start with P7.1
    I don't have a LabVIEW capable DMM, so I'm using the scope as voltage probe.
    I'm making it an optional instrument. I'd like to be able to run quick tests without having to set up the oscilloscope just to make it work.
    Are you interested in the gate voltage with or without offset compensation? I'm running it without first (I've removed the compensation botches)?
    Might be an idea to give it a look-over with a scope too. The meters might not be showing you the whole picture.
    Todo
  • jc2048
    Can you measure the voltage at P7.1 so we can see what the integrator thinks it is telling the MOSFET to do as you go past the cut-off in the current.
    I've tried option 1, adding a negative offset to the summing node.
    Unbuffered. I made a voltage divider with a 10 K potentiometer between GND and -5, turned it to -2 mV and used a 100K resistor to feed it to the summing node.
    Because it's unbuffered, the voltage moves closer to GND when the DAC1 is pushing current in the node.
    6190,000666200,000676210,0035126220,0036136230,0037136240,003914
    No magic on the lowest level.
  • jc2048
    My suggestion wasn't a good one. U3C is a differential amplifier configuration, so the input pins aren't always sitting close to ground (the pin you are injecting into isn't a 'virtual ground'). Since they move around, the current you inject will vary (in this case your DAC and resistor are a very poor approximation to a current source). I should have thought more about it before throwing the idea at you.
    I'm currently working on the output board. Tomorrow I'll be in a position to wire the whole thing together and see how this one behaves.
    Pushing the offset higher doesn't solve the issue. It just pushes it uphill.
    In this graph, I set DAC B, that creates the offset correction, to 300.
    Behaviour is the same, a steep jump from nothing to > 2 mA, but at a higher starting point of DAC A.
    1840,00051850,00251860,00251870,00261880,00281890,00291900,003
    (are we fighting against the diodes at the backside of the integrator?)
    I've used the LabVIEW process to gather the current between DAC settings 0 and 300 to measure the current
    I haven't analysed it yet.
    1190,00050,00050,00050,00050,00060,00061200,00050,00050,00050,00050,00060,00061210,00240,00240,00050,00240,00230,00251220,00250,00260,00240,00250,00250,00251230,00260,00270,00260,00270,00270,00271240,00270,00280,00270,00270,00280,0028
    The bump when the DAC kicks in has moved up but the bump is still abrupt and the lowest controlled current is still 2 mA ...
    I'll use a more precise meter to measure the current. Unfortunately I can't log the results ...
    ... the discussion in Jon's build thread may give a solution for the impact of DAC A offset to the lowest range.
    We can use a >> 100K resistor to insert some additional offset into the opamp 3C. Because it feeds back into the integrator, we can use that to undo the DAC A offset.
    DAC B can be used to generate the offset.
    On my board, the positive offset of approx 0.7 mA of DAC A causes that the load has a lowest range of > 1 mA.
    Offsetting (sic) that offset via an additional signal into U3, makes that you can push the power fet down to its lowest conductance. The same value as when you switch off the input via Q1.
    This has impact on the reported current by U3B, and I haven't analysed that yet. I hope I can correct that in firmware.
    To get this additional circuitry added on the board isn't too hard. Get a 10M (I tested with 3M3 because because) 1206 resistor and place it on footprint C11.
    Then put a bodge wire from the bottom side of C12 to pin 4 of connecor P3 (to tap off DAC B).
    Robert Peter Oakes, jc2048, I'm looking for the best place in the control circuit where we can inject a solution for DAC offset.
    A good place here we can offset that DAC output when set to 0x0000.
    If we can do that with injecting a positive voltage somewhere in the control circuit, we could use one of the free DAC channels to provide that compensaton, and use the calibration API to set that value.
    It may not be that easy though. In my setup, DAC A has an offset of about 0.7 mV (Jon's DAC has less), and the DAC output doesn't change until the input value increases above that level.
    But that's something we can work around in software. If we can compensate for the DAC offset voltage inserted into the integrator, I can adapt the firmware to start from that point on. We will lose about 100 values in total (out of 65000) as usable settings, but that's negligible.
    Here are the measurements in the range below the offset of the DAC.
    What's clear is that the analog control circuit can go much lower than what the DAC (in my setup) can control; because of its offset.
    And the values are stable across a wide range of input voltages (I tested that while doing this exercise).
    Good news for Robert Peter Oakes, because that indicates that his analog design is usable from 80 µA on. What we'll have to try now is close the gap between that 80µA and the >1 mA minimum when using the DAC as current setter.
    edit: the lowest I can get with the DAC is a control voltage of 0.78. At that voltage, the current drawn by the load is 1.3 mA. The analog part can go as low as 0.08 mA. That's more than an order of magnitude lower. Worth pursuing, I think ...
    I'll try to see what a 2K load at the output does to the voltage (tested with 10K and that does nothing - I don't have high hopes for 2K).
    I'll also try to set the current with a potentiometer instead of the DAC, to see if I can control between 0 and 2mA then.
    If I put a multi-turn pot between ground and VREF and feed that into the circuit, I should be able to rule out the whole analog circuit as cause for that difficulty to control the very low currents ...
    Here's the test setup stack for that:
    You can see that between the green PCB (the ADC/DAC board) and the purple one (control circuit), I've bent the pin for the DAC that controls the current setting of the load.
    I'll replace that with the center tap of a potentiometer wired between 0 V and Vref.
    Jan Cumps over 6 years ago in reply to Jan Cumps
    The conclusion may be premature, but the cause for the bump seems to be the offset in the current sense opamp.
    When working that offset in the U3C away to under 200 µV, I get nicer behaviour when the regulation circuit starts.
    Here's a long running sample. 5400+ samples. Ignore the blip at 2400 because that's when I paused the test to go out with my youngest daughter. I don't want to burn my house.
    It's still running. I'll stop it when I close for the night (bloody early flight, need to be up at 4:00 image ).
  • jc2048
    For a comparatively simple circuit, it's been a very good vehicle for blogging. I'm learning a lot from it, though I think it will be a while before you give me my diploma in servo systems (I never was any good at maths, and I'm certainly not now).
    One worry I have about those blogs you refer to is that I'm not an expert in this. All the simple project stuff [I'm thinking about Arduino stuff here] doesn't matter too much (it's just fluff, though it's fun and serves a useful purpose in getting people interested and acts as a way of introducing concepts), but those blogs were moving into the area of theory, but theory that I'm not qualified to teach. I think, on balance, it's worth doing this stuff (as much because it gives an idea of how electronic design is done and how you think about things and solve problems as the actual detail of what you're blogging about), but I often think that there are lots of people out there who could do it so much better than I could.
    To extend the range down you just need a higher value sense resistor (though you obviously lose the top end). A 5R sense resistor should get you down a couple more decades. You might need to swap the MOSFET (though it would be an interesting experiment to try the 5R in the existing circuit and see what happens with the MOSFET if you take the drain current down further). That then leads to the idea you could switch the load resistors into circuit, but that falls on the difficulty that anything you use as a switch has a significant resistance compared to the 50mOhm. Another possibility would be the two resistors in series, with a relay to short out the 5R for higher currents, but you'd need two sense circuits and some way to switch between them.
    A further idea, if the current when forced off is very low, is two parallel two circuits with either being allowed to operate - a high current one and a low current one. You might even be able to arrange for both to be operating together, though I suspect the loop stuff gets a bit hairy if you do that. [One thing to watch, though, is that the clever scheme of shifting the ground point to the source of the MOSFET rather than the negative load connection would compromise that.]
    I've got a much, much lower cost design using transistors (a completely op-amp free zone!) - I did that a while back as a challenge to myself to see if I could design something more complex than a textbook circuit. I haven't prototyped it yet but it works ok in the simulator. (I'm a bit slow in my old age - it was only after I'd started it that I realised I was actually designing a discrete op amp, though it does differ a bit from the traditional do-anything op-amp design). It's nothing like the precision of this one and it's not a true servo system, but it's much faster. Component cost would be a few pounds. I'm saving it for the next DIY Test Equipment contest.
    jc2048  wrote:
    It doesn't matter to you because the loop seems to be dealing with it quite happily.
    Yes, it's impressive that the control mechanism gets such a good grip on the current with the MOSFET being a tough device to control in this range of operation.
    But do you actually need the load to be able to do this? Do you need the load to operate continuously over more than 4 decades of current?
    No. My main goal was to see if I could turn Peter's design into a programmable one. I started from that point, with no other goals.
    It's certainly not a perfect exercise.  I learned and re-learned a lot while doing this (I'm expected to be a diploma'd control mechanism guy but I needed loads of studying to get hold of the theory and practice again - this exercise bumped me back into the stratosphere of control theory image ). And I'm pleased that it yielded those blog posts you made that explain the behaviour of the control part.
    I think this instrument as it stands now is useful in its operating range. Mine is fairly stable and linear between 2 mA and 6 A for the control part. The measurement part I have only roughly tamed. It needs more work before we can see how well that behaves.
    Maybe, because everything is published, there is a chance that someone improves on it. Maybe by increasing range and precision. Or by reducing the costs by factoring out some of the ridiculously expensive components I used ... (and improving the PCB design)
  • jc2048
    The MOSFET behaviour is very interesting and I'd like to investigate that. I don't know much about how these power MOSFETs behave if you try and use them in the linear region like this - the manufacturer intends them as power switches, so the datasheet doesn't help very much - but if I had to guess, I'd say that maybe you're seeing the effect of having an array of MOSFETs in parallel, all with slightly different characteristics, and characteristics that change with temperature and so are dependent on how the currents arrange themselves (a power MOSFET like this will be an array of smaller MOSFETs). It's possible that down around the threshold voltage there's a certain amount of somewhat chaotic behaviour to the gate voltage (ie there might be several arrangements that allow for the small total current and which you get may depend on very subtle variations as you approach - if that were the case, it ought to be possible to repeat the measurement many times and map the various 'paths' through that area).
    Anyway, that's just wild speculation [quite out of character for me!] and might be totally wrong - where are all the experts when you need them? It doesn't matter to you because the loop seems to be dealing with it quite happily.
    Back to the load. I've just sat thinking about all this and it seems to me that you're asking a lot of this circuit. The sense resistor is 50mOhms, so for 1mA current you get 50uV on the sense. You then give it to an op amp with an offset voltage of 180uV (typ)/ 600uV(max) to deal with. I suspect we're getting to the point where you would need to think about trimming the offset on that first amplifier.
    But do you actually need the load to be able to do this? Do you need the load to operate continuously over more than 4 decades of current? If you don't, perhaps you might do better to build two instruments covering different ranges.
    Well, it didn't smoothen that out image
    The input voltage this time was 6 volt.
    Here is the same exercise with Scope bandwidth on and input voltage = 5 V.
    I'm doing the gate measurements again. I've just learned how to program the Bandwidth filter of my scope.
    I've done the same measurement a second time. Even though the current graph is stable, the gate graph shows significant difference:
    No offset remediation, 5 V input:
    Current:
    Gate voltage:
    DAC ACurrentGate Voltage00,00143,35343710,00143,35269820,00143,3507330,00143,35337440,00143,35242250,00143,35390960,00143,35404570,00143,3546680,00143,35480390,00143,354254100,00143,35567110,00143,351876120,00143,352835130,00143,352695140,00143,355678150,00143,351142160,00143,354182170,00143,348902180,00143,352893190,00143,353103200,00143,348097210,00143,345566220,00143,350055230,00143,351615240,00143,348017250,00143,348708260,00143,346317270,00143,347818280,00143,347957290,00143,344709300,00143,344922310,00143,349371320,00143,348553330,00143,348708340,00143,348363350,00143,351747360,00143,351609370,00143,349983380,00143,348498390,00143,351478400,00143,353572410,00143,349933420,00143,351079430,00143,352707440,00143,352893450,00143,354721460,00143,351874470,00153,354321480,00153,355607490,00143,356076500,00143,353433510,00143,35324520,00143,354931530,00143,353911540,00153,35405550,00153,35445560,00143,355271570,00153,355128580,00143,35331590,00143,354188600,00143,353165610,00143,349245620,00143,352023630,00143,348979640,00143,348836650,00143,348171660,00143,350323670,00143,34721680,00143,346877690,00143,351272700,00143,347602710,00143,353373720,00143,351874730,00143,352428740,00143,355275750,00143,355136760,00143,355128770,00143,354117780,00143,353505790,00143,354453800,00143,350465810,00143,353911820,00143,352018830,00143,352834840,00153,356083850,00143,353508860,00143,352357870,00143,352086880,00143,351743890,00143,354119900,00143,35405910,00143,351533920,00143,353846930,00143,349652940,00143,354663950,00143,350929960,00153,354728970,00153,352423980,00143,349096990,00143,3555381000,00143,3539931010,00143,3539781020,00153,3554681030,00153,3567651040,00163,3606141050,00183,3609571060,00183,3613481070,00193,3619461080,0023,3634011090,00223,3678861100,00233,3818541110,00243,3895671120,00263,3974531130,00263,4006511140,00273,404911150,00293,4192361160,0033,42611170,00313,4361551180,00333,4420671190,00343,4439051200,00343,4441751210,00363,4454071220,00363,446081230,00383,4479351240,0043,4514211250,00413,4518071260,00433,4542371270,00423,4552941280,00443,4581661290,00463,4618811300,00463,4618341310,00483,4641871320,00493,4667011330,0053,4678361340,00523,4697751350,00533,4713181360,00543,4741281370,00553,4796891380,00573,4783691390,00583,4840441400,00593,494371410,00593,4981731420,00613,4984081430,00623,5082021440,00633,5141291450,00643,5185741460,00653,5243791470,00673,5276281480,00683,5278771490,00683,5320271500,0073,5342361510,00713,536711520,00723,538541530,00743,5452391540,00753,5559571550,00763,5520351560,00783,5588611570,00793,5569111580,00793,5617021590,0083,5686871600,00823,5707941610,00833,5802261620,00843,5796111630,00853,5795491640,00863,5817841650,00883,5834721660,00883,583961670,0093,5846981680,00913,5852371690,00923,58831700,00933,5895111710,00943,5891811720,00963,5923681730,00973,5920971740,00983,591411750,00993,5940531760,013,5954081770,01033,5958141780,01043,5975061790,01063,5974391800,01073,5977771810,01073,5981171820,01093,5981151830,01093,5986571840,01113,5990731850,01123,5991351860,01133,5989321870,01143,5994011880,01153,5991981890,01163,5991981900,01183,5994011910,01193,5995461920,0123,5998741930,01223,5994691940,01233,5996721950,01233,599811960,01253,5996081970,01263,5996721980,01263,5995411990,01273,5996082000,01293,5996722010,0133,5996722020,01313,5999462030,01333,5999422040,01343,5999432050,01373,5997392060,01373,5999452070,01393,5998732080,01393,6000192090,0143,5996722100,01413,6001422110,01423,5998072120,01453,6008022130,01463,6000732140,01463,6003452150,01483,600542160,01483,6024532170,0153,6018612180,01513,6019922190,01523,6052992200,01543,6056292210,01553,6099792220,01553,6085942230,01563,6177022240,01583,6042422250,01593,6114462260,0163,6197482270,01613,6184872280,01623,6173672290,01633,6256712300,01653,6258672310,01663,6216582320,01673,6283142330,01693,6300722340,0173,6346222350,01723,6320452360,01733,6304862370,01753,6350782380,01763,6348292390,01773,6352352400,01783,63492410,01783,6350922420,0183,6359062430,01813,6378722440,01823,6396022450,01833,6400592460,01853,6403332470,01853,6409362480,01863,6399622490,01883,6420982500,01893,6403982510,0193,6417612520,01913,6413452530,01933,6433012540,01943,6471122550,01963,645142560,01973,6482732570,01973,6460842580,01983,6476552590,023,6496892600,02013,6546552610,02023,6549942620,02043,6524092630,02043,6549912640,02063,6574952650,02083,6566192660,02093,6595192670,0213,6593962680,02113,6583082690,02123,6636062700,02133,6680072710,02143,662322720,02153,6655672730,02163,6667212740,02173,6679412750,02183,6672682760,02193,6696382770,0223,6697072780,02223,6715322790,02233,6698382800,02243,6720032810,02253,673092820,02273,673232830,02273,6724112840,02293,674512850,0233,674512860,02323,6737052870,02333,6758642880,02343,6744422890,02353,6757962900,02353,6753972910,02363,6757282920,02383,6753982930,02393,676272940,02413,6764082950,02423,6776232960,02433,6772852970,02453,6777582980,02463,6776232990,02473,6778943000,02483,677961
    I have this working. I'm logging pin P7.A via the scope ...
