Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
  • Author Author: dougw
  • Date Created: 23 Dec 2018 5:18 AM Date Created
  • Views 1059 views
  • Likes 10 likes
  • graffitibot
  • doug wong
  • sixth sense design challenge
dougw
dougw
23 Dec 2018
The past week has been about doing enough detailed design to get long lead time components on order.
The parts kit from STMicroelectronics and TE Connectivity came in and I have been looking through the datasheets.
Some parts I ordered have also come in and I've been designing a 3D printed nozzle to test the feasibility of the printing concept, so I can blog about the tangible parts.
Here is a video which explains what arrived plus some initial thoughts on the project:
Here is the pinout of the TE Connectivity load cell - you can see what I mean about the silk screen being partly obscured by the gasket:
V- and V+ are excitation supply pads. O- and O+ are output signal pads.
The pin pads in the image look black although the actual pads look solderable in person.
Now that we have the sizes of all the sensors, the next order of business is to get the custom PCBs designed so they can be ordered.
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - System Interconnect - blog 5
Sixth Sense GraffitiBot - Wheels & Motors - blog 6
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Load Cell PCB - GraffitiBot blog 8
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixth Sense GraffitiBot Motor Wiring - Blog 16
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
    genebren over 7 years ago +2
    Doug, Looking good! Some of those IC are darn near impossible to hand solder. I keep running into parts that I can't solder with my iron, so I have started to search out an oven or a good hot air system…
    Doug,
    Looking good!  Some of those IC are darn near impossible to hand solder.  I keep running into parts that I can't solder with my iron, so I have started to search out an oven or a good hot air system.  Good luck!
    Gene
    Doug,
    Gene
