Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense - Load Cell PCB - GraffitiBot blog 8
  • Author Author: dougw
  • Date Created: 14 Feb 2019 7:15 AM Date Created
  • Views 2053 views
  • Likes 10 likes
  • Comments 5 comments
  • graffitibot
  • doug wong
  • load cell
  • sixth sense design challenge
dougw
dougw
14 Feb 2019
I finally received enough parts to assemble the load cell signal conditioning circuit board.
The circuit schematic and PCB layout for load cell signal conditioning were covered in a previous blog.
The TE Connectivity FX1901 load cellFX1901 load cell will be used to measure the amount of fluid in the Graffitibot reservoir by weighing it.
It isn't clear which variant of load cell (in terms of full scale output) I have, so I will have to hook it up and see what the output looks like.
Also I am not quite sure how to mount the load cell - there are no obvious mounting fasteners, so I will have to test how it responds to force on various surfaces.
Here is what the circuit looks like in action:
The signals take some time to settle down because I have a pretty severe low-pass filter on the signal - to minimize fluctuations due to fluid sloshing around.
The output voltage is slightly negative with no load - this is okay because the weight of the empty reservoir with motors in it will bring the signal above zero.
This is a good start to getting the custom PCBs working.
The next sensor will be the magnetic angle sensor.
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - System Interconnect - blog 5
Sixth Sense GraffitiBot - Wheels & Motors - blog 6
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixth Sense GraffitiBot Motor Wiring - Blog 16
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
    dougw over 7 years ago in reply to genebren +5
    I will use a hinged load plate where the hinge will prevent tipping but not take any of the vertical load.
  • e14phil
    e14phil over 7 years ago +4
    Most Canadian test weights ever.
    dougw over 7 years ago in reply to e14phil +4
    If you look really closely you might discern some of them were made in Slovakia. They make 6 million per year. Made from rubber and carbon black. They are also made in Canada of course. I have a multitude…
    DAB over 7 years ago
    Good update Douglas.
