Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense GarffitiBot - First Dry Run - Blog17
  • Author Author: dougw
  • Date Created: 23 Mar 2019 6:03 PM Date Created
  • Views 2596 views
  • Likes 14 likes
  • Comments 10 comments
  • graffitibot
  • doug wong
  • sixth sense design challenge
dougw
dougw
23 Mar 2019
This is a big day - the GraffitiBot made its maiden voyage!
This was just the first attempt at programming an autonomous route that would test the steering and the main drive.
It is literally a dry run, there are no pumps or even reservoir on board.
I could spend some time to make it look more impressive and get some better camera angles, but I need to start working on the hydraulics - the nozzles need a lot of work, not to mention the software.
Getting this far has taken a lot of work, but see it run is what is all about.
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
KMT32B Magnetic Angle Sensor
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - System Interconnect - blog 5
Sixth Sense GraffitiBot - Wheels & Motors - blog 6
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Load Cell PCB - GraffitiBot blog 8
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixth Sense GraffitiBot Motor Wiring - Blog 16
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
    genebren over 7 years ago +5
    Looking good! Seems like steering and drive are stable and responsive. Good luck as you tackle the hydraulics. Gene
  • three-phase
    three-phase over 7 years ago +5
    You seem to have everything well under control. Good luck with the next stage of the project. Kind regards.
    beacon_dave over 7 years ago in reply to 14rhb +5
    Doug's next project... hacking a Karcher hard floor cleaner... https://www.youtube.com/watch?v=TX8vGFwNj4I ... into a M-O clean-up droid https://www.youtube.com/watch?v=i3YWXOwYT3Y
    shabaz over 7 years ago
    Hi Doug,
    This is looking great! Good luck with the hydraulics!
    Hi Doug,
