Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense GarffitiBot - First Dry Run - Blog17
  • Author Author: dougw
  • Date Created: 23 Mar 2019 6:03 PM Date Created
  • Views 2596 views
  • Likes 14 likes
  • Comments 10 comments
  • graffitibot
  • doug wong
  • sixth sense design challenge
dougw
dougw
23 Mar 2019
This is a big day - the GraffitiBot made its maiden voyage!
This was just the first attempt at programming an autonomous route that would test the steering and the main drive.
It is literally a dry run, there are no pumps or even reservoir on board.
I could spend some time to make it look more impressive and get some better camera angles, but I need to start working on the hydraulics - the nozzles need a lot of work, not to mention the software.
Getting this far has taken a lot of work, but see it run is what is all about.
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
KMT32B Magnetic Angle Sensor
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - System Interconnect - blog 5
Sixth Sense GraffitiBot - Wheels & Motors - blog 6
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Load Cell PCB - GraffitiBot blog 8
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixth Sense GraffitiBot Motor Wiring - Blog 16
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
    genebren over 7 years ago +5
    Looking good! Seems like steering and drive are stable and responsive. Good luck as you tackle the hydraulics. Gene
  • three-phase
    three-phase over 7 years ago +5
    You seem to have everything well under control. Good luck with the next stage of the project. Kind regards.
    beacon_dave over 7 years ago in reply to 14rhb +5
    Doug's next project... hacking a Karcher hard floor cleaner... https://www.youtube.com/watch?v=TX8vGFwNj4I ... into a M-O clean-up droid https://www.youtube.com/watch?v=i3YWXOwYT3Y
    jw0752 over 7 years ago
    Hi Doug,
    If you haven't already considered this you might want to use a duckbill check valve on your jets. They provide a slight back pressure so that there is less chance of a gravity siphon. Here are some that are used on the oil lines of a chain saw.
    https://www.ebay.com/i/253803363604?chn=ps
    • Vote Up +5 Vote Down
    Hi Doug,
    dougw over 7 years ago in reply to jw0752
    That is a good idea.
    My biggest problem is purging the air from the lines and keeping it out.
    The nozzles restrict flow enough that air bubbles aren't forced through the hose very well.
    Air also defeats any siphon as well, but when air is properly purged, the siphon effect is not very apparent.
    There are several other more pressing problems.
    jw0752 over 7 years ago in reply to dougw
    Hi Doug,
    If you can decrease the ID of the hose you are using the increased flow rate might purge the bubbles.
