Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense GraffitiBot - System Interconnect - blog 5
  • Author Author: dougw
  • Date Created: 26 Jan 2019 10:19 PM Date Created
  • Views 2215 views
  • Likes 10 likes
  • Comments 8 comments
  • graffitibot
  • doug wong
  • sixth sense design challenge
dougw
dougw
26 Jan 2019
I finally have all four custom PCBs designed and on order so I can spend some time describing the system a bit better.
The diagram below shows how all the electrical subsystems are connected in the GraffitiBot.
Although this is a busy diagram with lots of subsystems, there are just as many sensors on the Sensor Tile itself which are not broken out on the diagram.
There are 2 batteries - one will power the pumps and drive motors, the other one will power the rest of the electronics.
The keypad and dual LCDs will form the user interface, although the STMicroelectronics Sensor Tile has BLE on it, so Bluetooth remote control is also a possibility.
The big interconnect card doesn't have a lot of circuitry on it , but in addition to connecting all the subsystems, it serves as a platform for the LCDs. Its size makes it much more expensive than the other custom cards.
Here is a schematic showing how the interconnect card works:
Here is the corresponding PCB layout:
Now that all the electronic subsystems and components are on order I will start working through the mechanical design.
I have already done quite a bit of thinking through of the mechanical design to try and get the long lead components on order.
I think I have most of the mechanical components on order but the detailed design may spawn new component requirements.
Most of the remaining mechanical design will be parts that need to be 3D printed.
I'm not quite sure how many 3D parts will end up in the machine, but I expect around 10.
As expected, this is a complex project with a lot of moving parts, a lot of subsystems, a lot of software and a lot of blogging.
I would like to to doing some software, but getting hardware on order is the priority.
I just hope the Chinese New Year holidays don't impact deliveries too badly. I'm hoping I got the last PCB in under the wire.
Now to get the 3D printer cranked up.....
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - Wheels & Motors - blog 6
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Load Cell PCB - GraffitiBot blog 8
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixth Sense GraffitiBot Motor Wiring - Blog 16
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
    genebren over 7 years ago +3
    Doug, Nice job on the system interconnect drawing. I really like the 3D views of all the parts, floating in space. Nice and clear! Gene
  • kulky64
    kulky64 over 7 years ago +3
    So if I understand it correctly you are going to supply both DC motor driver boards with 5V from one of your power banks (I guess you will run cable from J10 connector on aquarim pumps driver board to…
    dougw over 7 years ago in reply to kulky64 +1
    You are correct, that is roughly the plan, but there are contingency plans if issues arise. The pump controller is also 3.3V although the pump FETs will supply 5 V to the pumps.
  • kulky64
    So if I understand it correctly you are going to supply both DC motor driver boards with 5V from one of your power banks (I guess you will run cable from J10 connector on aquarim pumps driver board to these two boards), you will remove I2C pull-up resistors from both motor driver boards (and probably from all other boards except STEVAL-STLCX01V1) and you will run I2C bus on 3.3V voltage levels?
  • kulky64
  • kulky64
    kulky64 over 7 years ago in reply to dougw
    And second power bank will go to USB connector on Nucleo board? Will 500 mA be enough for all devices on 3.3V bus?
    Good question. I expect them to require much less than 500 mA, but I will measure to make sure.
  • kulky64
    Just the backlights on both displays will probably consume big chunk of your current budget. At SparkFun site they claim that backlight on those displays can consume as much as 100 mA:
    https://learn.sparkfun.com/tutorials/graphic-lcd-hookup-guide
    Although your diplays look a bit different, so the figures may not apply. What for do you need two displays anyway?
    The backlights will not be used on these displays - they would only be needed at night when the graffiti wouldn't be visible anyway. These displays are similar (software compatible) to the displays from SparkFun, but use a different pinout. Without the backlight, they are very low power displays - like what you would find in a dumb watch.
    Why 2 displays? - There are a large number of sensors to display, plus I want to display the graphics to be printed by the bot.
