Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense GraffitiBot - Wheels & Motors - blog 6
  • Author Author: dougw
  • Date Created: 26 Jan 2019 11:26 PM Date Created
  • Views 1440 views
  • Likes 10 likes
  • graffitibot
  • doug wong
  • sixth sense design challenge
dougw
dougw
26 Jan 2019
I need to get the detailed mechanical design properly underway to ensure I haven't forgotten to order some critical parts.
This blog covers design of the wheels and motor mounts.
This video animates some of the CAD models to show their detail:
The steering and drive mechanism is pretty complex as the steering wheel is also the drive wheel.
The drive motor mount has a steering post on it to allow the steering motor to control direction of the drive motor. This motor housing has a very complex interior to fit the drive motor precisely. This type of shape would be very difficult to machine or make by hand, so it is very lucky I have access to a 3D printer.
Here is a video showing 3D printed parts of the drive mechanism and how they work:
Next I can get started on the main mechanical chassis. This is a little tricky since I don't have all the parts that will attach to it yet.
At this stage everything seems to be going smoothly but it is only when you try to connect everything you discover why it won't work...
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - System Interconnect - blog 5
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Load Cell PCB - GraffitiBot blog 8
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixth Sense GraffitiBot Motor Wiring - Blog 16
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
    jw0752 over 7 years ago +2
    Hi Doug, I still remember the project that you built to sufficiently good tolerances that fasteners weren't need. It is always fun to follow your builds. John
    dougw over 7 years ago in reply to jw0752 +1
    Thanks John, I am still trying to minimize fasteners, but in this case the 3 bearings are expecting to be mounted with screws.
    dubbie over 7 years ago +1
    Doug, Good 3D printed parts. Dubbie
    Hi Doug,
    Hi Doug,
    Thanks John,
