Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog Sixth Sense GraffitiBot Motor Wiring - Blog 16
  • Author Author: dougw
  • Date Created: 23 Mar 2019 5:10 AM Date Created
  • Views 1358 views
  • Likes 13 likes
  • graffitibot
  • doug wong
  • motor wiring
  • sixth sense design challenge
dougw
dougw
23 Mar 2019
I have finally managed to wire up the motor controllers to the MCU. Here is a video showing what it looks like:
Next I will try to program the MCU to run the steering and drive motors in a simple autonomous route.
There is nothing like trying to make a full system run properly in one day while avoiding catastrophic errors, but what is life without a little drama....
Relevant Links
Sixth Sense Design Challenge: About This Challenge
Sixth Sense Design Challenge: Technical Documents
KMT32B Magnetic Angle Sensor
GraffitiBot Project Blogs
Sixth Sense GraffitiBot - blog 1
Sixth Sense - Kit Unboxing and Other Parts - GraffitiBot blog 2
Sixth Sense - Sensor Circuits - GraffitiBot blog 3
Sixth Sense - Interfaces - GraffitiBot blog 4
Sixth Sense GraffitiBot - System Interconnect - blog 5
Sixth Sense GraffitiBot - Wheels & Motors - blog 6
Sixth Sense GraffitiBot - ST Sensor Tile App - blog 7
Sixth Sense - Load Cell PCB - GraffitiBot blog 8
Sixth Sense - Magnetic Angle Sensor - GraffitiBot - Blog 9
Sixth Sense - LCD Interface - GraffitiBot - blog 10
Sixth Sense - Pump Controller - GraffitiBot Blog 11
Sixth Sense Main Drive Motor - GraffitiBot - blog 12
Sixth Sense Motor Controller Mods - GraffitiBot blog 13
Sixth Sense - RTD - GraffitiBot Blog 14
Sixth Sense Mechanical Design - GraffitiBot Blog 15
Sixthe Sense GarffitiBot - First Dry Run - Blog17
Sixth Sense GraffitiBot Hydraulics - Blog 18
Sixth Sense GraffitiBot Printing Graffiti - Blog 19
Sixth Sense GraffitiBot - Summary - Blog 20
  • 14rhb
    14rhb over 7 years ago +4
    Hi Douglas, A great design with very neat cabling. You could perhaps glue a magnet and small piece of steel to keep your pump tray located whilst still being able to remove it for maintenance/refilling…
    dougw over 7 years ago in reply to 14rhb +3
    Good idea.
    DAB over 7 years ago +3
    The project is coming along nicely. DAB
  • 14rhb
    Hi Douglas,
    A great design with very neat cabling. You could perhaps glue a magnet and small piece of steel to keep your pump tray located whilst still being able to remove it for maintenance/refilling. That said, I know you are using the KMT32B so perhaps a bad idea after all !
    Rod
    Good idea.
    Good idea.
