      • Japan
      • Vietnam
Project14
Project14
Blog Project14 | Winners Announcement: Op-Amp-a-Palooza: Op-Amp Projects!
  • Theme Suggestions
  • Date Created: 17 May 2022 2:09 PM Date Created
  • Views 12632 views
  • Likes 12 likes
  • Comments 12 comments
  • opampch
tariq.ahmad
tariq.ahmad
17 May 2022
Congratulations to javagoza for Op-Amp Line Follower - Blog 3 The Line Follower!   You are the grand prize winner!
Congratulations to sunnyiut for Breathing AMP,  milosrasic98 for Op-Amp Based Adjustable Load , and genebren for Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 4 - Making Connection and Playing a Song.!   You are the first place winners!
imageThe Op-Amp-a-Palooza contest was an open ended exploration of op-amps using low cost components and features premium op-amp testing equipment as prizes. There's so much that can be done with OpAmps: Amplifiers and buffers, measurement, active filters, voltage references, current measurement, audio vs RF vs HT, precision circuits low noise circuits making one from discrete components.
Special thanks to Renesas, Maxim, and microchip for donating kit samples.   Thanks to baldengineer for coming up with cool prizes that an engineer would want to win as part an Op-Amp contest, as well as, Multicomp for providing those special prizes.  Finally,  thank you to dougw,  jancumps, amgalbu,  robogary, and dab for sorting through a ton of great projects and doing the hard job of picking winners!
In addition to the usual shopping cart,  here is what they also won:
Prizes
The Grand Prize:
image image image
Buy Now Buy Now Buy Now
3 First Place Winners:
image image image
Thank you to all members who contributed to the conversation about op-amps in our theme doc, with their projects, and for their support of members working on op-amp projects!
Without further ado....   Here are your winners!
The Grand Prize:
Op-Amp Line Follower by javagoza
  • Op-Amp Line Follower - Blog 1 First Steps
  • Op-Amp Line Follower - Blog 2 Following the research
  • Op-Amp Line Follower - Blog 3 The Line Follower
image image
image image
Breathing AMP by sunnyiut
image image
image image
Op-Amp Based Adjustable Load by milosrasic98
image image
image image
Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. by genebren
  • Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 2 - Power supply bring up and Analyzing the Noise Source.
  • Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 3 - Playing with noise.
  • Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 4 - Making Connection and Playing a Song.
image image
image image
Runner Ups:
The following projects received votes from our judges:
Maneki Neko: Lucky Cat with a Laser by fmilburn
image image
image image
Spectrophotometer for chemical analysis(Proof of Concept) by vinayyn
image image
image image
Op-amp Based Wien Bridge Oscillator by scottiebabe
image image
image image
E14 Op-amp Kit - First Power Up by scottiebabe
image image
image image
Inductors in Disguise by scottiebabe
image image
image image
Keep Being Awesome and Thank you for your continued support of Project14!
Be sure to congratulate the Winners in the Comments Below!
    Jan Cumps over 3 years ago +3
    Hey First Place Winners, I made a LabVIEW driver for the function generator you won. The driver is open source. LabVIEW Community Edition is free.
  • sunnyiut
    sunnyiut over 3 years ago
    I submitted my project at the end of the timeline. "breathing AMP" was a part of the project meant for respiration rate monitor. The front end was designed using opamps and that's why I shared it in the Op-Amp-a-Palooza contest. Thanks a lot to tariq.ahmad for his enthusiastic reply when I approached him that I have a project based on opamps (other than the sponsored ones) to share.
    It's great to be one of the first place winners.... WOW
    So many amazing projects, and quality blogs. I learnt a lot - and that's the beauty of this community. Project14 is a great initiative, it's continuously adding values with enriched contents.
    Congratulations to javagoza, I just loved your blogs. Congratulations to milosrasic98 and genebren - well deserved first place winners.
    Thanks to all the participants for sharing their projects which enriched the community. And obviously hats off to judges - it definitely wasn't easy to go through all these quality contents to pick the winners.
  • sunnyiut
