Safe and Sound
  • Safe and Sound
Safe and Sound
Blog Safe and Sound - Invisible Hazardous Environmental Factors Monitoring System Conclusions - blog 23
  • Author Author: dougw
  • Date Created: 6 Jul 2017 2:40 AM Date Created
  • Views 3061 views
  • Likes 20 likes
  • Comments 10 comments
  • hazardous environmental factors
  • safe and sound
  • doug wong
  • invisible hazards
  • safe and sound design challenge
  • winners
  • safe & sound
  • wearable technology
  • Wearables
  • safe&sound
dougw
dougw
6 Jul 2017
Doug Wong
Back to Doug Wong's VCP Profile   |  Safe and Sound
Observations & Surprises
This project has been a very interesting journey researching a wide variety of invisible potential hazards, designing systems to measure invisible hazards, building wearable instrumentation and testing my environment to see what invisible hazards might be present.
It is probably obvious from the content of my blogs that I learned a lot, actually way too much to fit into a few blogs, but the big surprise for me was how much fun it was. I anticipated the usual thrill I get from designing things and making them work, but I did not foresee how much fun it would be to use the instrumentation to examine my environment. It is a bit like the first time you got to play with a magnifying glass – you just run around looking at absolutely everything in a new way. It was also surprising to me how many people around me took an interest and wanted to examine their own environments. Normally talking about my projects is a good way to elicit glazed looks of boredom, but with this project, so many people wanted to borrow instrumentation it was tough to hang onto it long enough to take my own measurements.
The Kit
I am very happy the EXP432P401R was the required processor module for this design challenge as I might not have discovered it otherwise. This module is a very powerful, very capable and cost-effective platform for applications like this and will definitely be a favourite choice for future projects. The development environment was very easy to learn and use, especially since there were good examples available for most of the functionality I wanted to implement.
The comprehensive kit of modules supplied with the challenge (thanks Texas Instruments and element14) really allowed a complete wireless instrument with LCD to be implemented without even having to use wires and cables. Normally building such a platform would be an ambitious undertaking on its own, but with these plug-and-play booster packs and existing software examples, it enables projects to start with a complete, highly functional system and go beyond just getting some computer hardware to work.
Highlights
I got to design a custom sensor booster pack and the clear documentation available from Texas Instruments allowed it to work flawlessly without rework, respin or modification. It is really worth taking the time to do the job well – the gratification (and relief image) is immense.
I also got to design many 3D printed parts, continuing my mechanical design learning journey.
It has been a long project with many little problems to overcome, but all the things I've learned and all the things I've accomplished in this project have made it a truly fabulous experience.
This is probably my last blog during this challenge as I have other projects that need attention, but you never know – I certainly will continue to work on the system and use it – the novelty has not worn off yet.
I did want to publish the software I used in the project - for completeness. However, I don't claim any kind of quality for the software, it lacks error checking and handling among other issues. One feature I didn't mention in my other blogs is if the right switch is held down during boot, the sensor system will run stand-alone, without WiFi.
IHEF Sensor MQTT Publishing Firmware
// Invisible Hazardous Environmental Factors (IHEF) Monitoring System
// Gas sensor, UV measurement and MQTT publishing software
// by Doug Wong
// 2017 - 06
// rev 01
#include <SPI.h>
#include <WiFi.h>
#include <WifiIPStack.h>
#include <Countdown.h>
#include <MQTTClient.h>
#include <OneMsTaskTimer.h>
#include <LCD_SharpBoosterPack_SPI.h>
#include <Wire.h>
// network name also called SSID
char ssid[] = "AndroidAP"; //network name - this should be altered for your system ***
// network password
char password[] = "aaaaaa";               //network password - this should be altered for your system ***
// Cloud Settings
#define MQTT_MAX_PACKET_SIZE 100
#define SERVERURLLEN 14
#define IOTFSERVER "xxx.xxx.x.xx"     //server URL - this should be altered for your system ***
char organization[] = "";
char typeId[] = "iotsample-ti-energia";
char pubtopic[] = "IHEF";
char deviceId[] = "000000000000";
char clientId[64];
uint8_t macOctets[6];
// DAS Variables
LCD_SharpBoosterPack_SPI myScreen;
int AlcPin = A11; //MQ3 - Alcohol
int COPin = A14; //MQ7 - Carbo Monoxide
int AQPin = A13; //MQ135 - Air Quality
int CO2Pin = A8; //CO2
int UVPin = A9; //Ultraviolet Light
int AlcValue = 0; //MQ3 - Alcohol
int COValue = 0; //MQ7 - Carbo Monoxide
int AQValue = 0; //MQ135 - Air Quality
int CO2Value = 0; //CO2
int UVValue = 0; //Ultraviolet Light
int AlcHpin = 31; //MQ3 Heater
int COHpin = 38; //MQ7 Heater
int AQHpin = 32; //MQ135 Heater
String AlcStr; //string to display alcohol value
String COStr; //string to display CO value
String AQStr; //string to display air quality value
String CO2Str; //string to display CO2 value
String UVStr; //string to display UV value
float AlcR; //floating point value for alcohol
float COR; //floating point value for CO
float AQR; //floating point value for air quality
float CO2R; //floating point value for CO2
float UVR; //floating point value for UV
float AlcS; //floating point value for saved alcohol
float COS; //floating point value for saved CO
float AQS; //floating point value for saved air quality
float CO2S; //floating point value for saved CO2
float UVS; //floating point value for saved UV
int SCTR = 0; //seconds counter
int PCTR = 0; //publish counter
int PubFlag = 0;
const int buttonPin = PUSH2; // the number of the pushbutton pin
int buttonState = 0; // variable for reading the pushbutton status
int WiFiFlag = 1; //flag to enable WiFi
char mqttAddr[SERVERURLLEN];
int mqttPort = 1883;
MACAddress mac;
WifiIPStack ipstack;
MQTT::Client<WifiIPStack, Countdown, MQTT_MAX_PACKET_SIZE> client(ipstack);
void setup() {
  // setup LCD to display sensor data
  pinMode(AlcHpin, OUTPUT); //heater control pin
  pinMode(COHpin, OUTPUT); //heater control pin
  pinMode(AQHpin, OUTPUT); //heater control pin
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT_PULLUP);
myScreen.begin();
myScreen.clearBuffer();
myScreen.setFont(0);
Serial.begin(115200);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  //if the pushbutton is pressed on startup disable WiFi
  if (buttonState == LOW) {
   WiFiFlag = 0;
  if (WiFiFlag){
  // attempt to connect to Wifi network:
   myScreen.text(5, 1, "Connecting...");
myScreen.flush();
  // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
  WiFi.begin(ssid, password);
  while ( WiFi.status() != WL_CONNECTED) {
   // flash + while we wait to connect
myScreen.text(86, 1, "+");
myScreen.flush();
   delay(200);
myScreen.text(86, 1, " ");
myScreen.flush();
   delay(100);
   myScreen.text(5, 1, "WiFi Connected ");
   myScreen.text(5, 16, "Waiting for ip");
myScreen.flush();
  while (WiFi.localIP() == INADDR_NONE) {
   // wait for an ip addresss
   delay(300);
  // We are connected and have an IP address.
   myScreen.text(5, 1, "IP obtained");
   myScreen.text(5, 16, WiFi.localIP());
  mac = WiFi.macAddress(macOctets);
  // Use MAC Address as deviceId
  sprintf(deviceId, "%02x%02x%02x%02x%02x%02x", macOctets[0], macOctets[1], macOctets[2], macOctets[3], macOctets[4], macOctets[5]);
  sprintf(clientId, "d:%s:%s:%s", organization, typeId, deviceId);
  sprintf(mqttAddr, IOTFSERVER);
  delay(400); //to allow the text to be read before erasing
myScreen.clear();
   myScreen.text(5, 1, "STARTING DAS");
myScreen.flush();
   delay(300); //to allow the text to be read before erasing
myScreen.clear();
//display sensor labels
myScreen.setFont(1);
   myScreen.text(5, 1, "SENSORS");
   myScreen.text(5, 22, "Alc");
   myScreen.text(5, 37, "CO");
   myScreen.text(5, 52, "AQ");
   myScreen.text(5, 67, "CO2");
   myScreen.text(5, 82, "UV");
myScreen.flush();
void loop() {
  int rc = -1;
  if (SCTR >= 0 && SCTR < 60) //turn on alcohol heater for 60 seconds
digitalWrite(AlcHpin, 1); //turn on heater
digitalWrite(COHpin, 0); //turn off heater
digitalWrite(AQHpin, 0); //turn off heater
  if (SCTR > 58 && SCTR < 120) //turn on CO heater for 60 seconds
digitalWrite(AlcHpin, 0); //turn off heater
digitalWrite(COHpin, 1); //turn on heater
  if (SCTR > 118 && SCTR < 180) //turn on AQ heater for 60 seconds
digitalWrite(AQHpin, 1); //turn on heater
  SCTR++; //increment seconds counter
  PCTR++; //increment publish counter
  if (SCTR > 179) //reset seconds counter
   SCTR = 0;
  if (PCTR > 6) //reset publish counter
   PCTR = 0;
  //Read Sensors
  AlcValue = analogRead(AlcPin); //read Alcohol sensor
  COValue = analogRead(COPin); //read CO sensor
  AQValue = analogRead(AQPin); //read Air Quality sensor
  CO2Value = analogRead(CO2Pin); //read CO2 sensor
  UVValue = analogRead(UVPin); //read UV sensor
  AlcR = (float)AlcValue;
  COR = (float)COValue;
  AQR = (float)AQValue;
  CO2R = (float)CO2Value;
  UVR = (float)UVValue;
  if (SCTR == 178) //save good alcohol reading
   AlcS = AlcR;
  if (SCTR == 118) //save good CO reading
   COS = COR;
  if (SCTR == 58) //save good AQ reading
   AQS = AQR;
  AlcStr = String(AlcValue); //convert reading to ASCII for display
  COStr = String(COValue); //convert reading to ASCII
  AQStr = String(AQValue); //convert reading to ASCII
  CO2Str = String(CO2Value); //convert reading to ASCII
  UVStr = String(UVValue); //convert reading to ASCII
myScreen.text(40, 22, AlcStr + " "); //display alcohol
myScreen.text(40, 37, COStr + " "); //display CO
myScreen.text(40, 52, AQStr + " "); //display Air Quality
myScreen.text(40, 67, CO2Str + " "); //display CO2
myScreen.text(40, 82, UVStr + " "); //display UV
myScreen.text(70, 22, "ppm"); //display units
myScreen.text(70, 37, "ppm"); //display units
myScreen.text(70, 52, "ppm"); //display units
myScreen.text(70, 67, "ppm"); //display units
myScreen.text(70, 82, "idx"); //display units
myScreen.flush();
   delay (1000);
if (WiFiFlag) {
  if (PCTR == 5) //publish on the 5th second of every 6 seconds
  if (!client.isConnected()) {
// if (WiFi.status() == WL_CONNECTED) {
   while (rc != 0) {
   rc = ipstack.connect(mqttAddr, mqttPort);
MQTTPacket_connectData connectData = MQTTPacket_connectData_initializer;
connectData.MQTTVersion = 3;
connectData.clientID.cstring = clientId;
   rc = -1;
   while ((rc = client.connect(connectData)) != 0)
//make up messages to publish data and send
  char ALCjson[12] = "Alc: ";
  dtostrf(AlcS,1,2, &ALCjson[5]);
// ALCjson[1] = '{';
  ALCjson[10] = '}';
  ALCjson[11] = '\0';
  MQTT::Message message;
  message.qos = MQTT::QOS0;
  message.retained = false;
  message.payload = ALCjson;
  message.payloadlen = strlen(ALCjson);
  rc = client.publish(pubtopic, message);
  if (rc != 0) {
   // error code processing
  char COjson[12] = "CO : ";
  dtostrf(COS,1,2, &COjson[5]);
// COjson[1] = '{';
  COjson[10] = '}';
  COjson[11] = '\0';
  message.payload = COjson;
  message.payloadlen = strlen(COjson);
  if (rc != 0) {
  char AQjson[12] = "AQ: ";
  dtostrf(AQS,1,2, &AQjson[5]);
// AQjson[1] = '{';
  AQjson[10] = '}';
  AQjson[11] = '\0';
  message.payload = AQjson;
  message.payloadlen = strlen(AQjson);
  if (rc != 0) {
  char CO2json[12] = "CO2: ";
  dtostrf(CO2R,1,2, &CO2json[5]);
// CO2json[1] = '{';
  CO2json[10] = '}';
  CO2json[11] = '\0';
  message.payload = CO2json;
  message.payloadlen = strlen(CO2json);
  if (rc != 0) {
  char UVjson[12] = "UV: ";
  dtostrf(UVR,1,2, &UVjson[5]);
// UVjson[1] = '{';
  UVjson[10] = '}';
  UVjson[11] = '\0';
  message.payload = UVjson;
  message.payloadlen = strlen(UVjson);
  if (rc != 0) {
IHEF MQTT Subscriber Firmware
by Doug Wong 2017-04-08
Remote Display via MQTT
   - connects to an MQTT server
  - subscribes to the topic "IHEF"
  - displays Alcohol, CO, Air Quality, CO2, UV
#include <SPI.h>
#include <WiFi.h>
#include <PubSubClient.h>
// your network name also called SSID
char ssid[] = "aaaaaa"; //network name – change to your system ***
// your network password
char password[] = "aaaaaa"; //network password – change to your system***
// MQTTServer to use
char server[] = "xxx.xxx.x.xx"; //server URL – change to your system***
// String dstring;
String astring;
char dchar[22];
//callback section retrieves subscribed data and displays it
void callback(char* topic, byte* payload, unsigned int length) {
   char *cstring = (char *) payload;
   char *dstring = (char *) payload;
   for (int i=0; i<=10; i++) {
   dstring[i] = cstring[i];
   if (cstring[1] == 108) // ALC
myScreen.text(5, 17, dstring);
myScreen.text(65, 17, " ppm ");
   if (cstring[2] == 32) // CO
myScreen.text(5, 32, dstring);
myScreen.text(65, 32, " ppm ");
   if (cstring[1] == 81) // AQ
myScreen.text(5, 47, dstring);
myScreen.text(65, 47, " ppm ");
   if (cstring[2] == 50) // CO2
myScreen.text(5, 62, dstring);
myScreen.text(65, 62, " ppm ");
   if (cstring[0] == 85) // UV
myScreen.text(5, 77, dstring);
myScreen.text(65, 77, " idx ");
   myScreen.flush();
WiFiClient wifiClient;
PubSubClient client(server, 1883, callback, wifiClient);
void setup()
{ //initiallization section connects to MQTT broker
myScreen.begin();
myScreen.flush();
  // Start Ethernet with the build in MAC Address
   // print dots while we wait to connect
   delay(300);
   myScreen.text(5, 9, "WiFi Connected ");
   myScreen.text(5, 18, "Waiting for ip");
myScreen.flush();
   delay(300);
   myScreen.text(5, 27, "IP obtained");
   myScreen.text(5, 36, WiFi.localIP());
myScreen.flush();
   delay(300);
void loop()
  // Reconnect if the connection was lost
  if (!client.connected()) {
if(!client.connect("IHEF")) {
   } else {
if(client.subscribe("IHEF")) {
myScreen.text(5, 45, "Subcribed");
myScreen.text(5, 54, "IHEF");
myScreen.flush();
   delay(1200);
myScreen.clear();
myScreen.text(20, 3, "MQTT IHEF");
myScreen.flush();
  // Check if any message were received
  // on the topic we subscribed to
  client.poll();
  delay(1000);
It has been fun and informative reading other entries in this challenge, and interacting with participants, I hope everyone enjoyed it as much as I did.
Links to all blogs and videos that document this project are listed here:
Safe and Sound - Invisible Hazardous Environmental Factors Monitoring System - blog 1 of 22 - blog 1
Safe and Sound - Hazardous Factors System - Development Plan - blog 2
Safe and Sound - Hazardous Factor - UV Light - blog 3
Safe and Sound - Hazardous Factor - Air Quality - blog 4
Safe and Sound - Hazardous Gasses PCB - blog 5
Safe and Sound - Hazardous Factor - Radon - blog 6
Safe and Sound - Invisible Hazards System - Kit Unboxing - blog 7
Safe and Sound - MSP-EXP432P401 & Sharp LCD - blog 8
Safe and Sound - Hazardous Factors MQTT Broker - blog 9
Safe and Sound - Hazardous Factors Sensor PCB - blog 10
Safe and Sound - Hazardous Environmental Factors - ELF - blog 11
Safe and Sound - Hazardous Factors MQTT Subscriber & Publisher - blog 12
Safe and Sound - Hazardous Factors System - ARM Car - blog 13
Safe and Sound - Environmental Factors - Wearables - blog 14
Safe and Sound - Environmental Factors - Microwaves - blog 15
Safe and Sound - Environmental Factors - GAS Sensors - blog 16
Safe and Sound - Hazardous Factors Monitoring System - Gas Sensors Module - blog 17
Safe and Sound - Invisible Hazardous Environmental Factors Monitoring System - blog 18
Safe and Sound - Cell Phone Shield Test - blog 19
Safe and Sound - Invisible Hazards Project Spin-offs - blog 20
Safe and Sound - Gas Sensor Demo - blog 21
Safe and Sound - Ultraviolet Light Tests - blog 22
Safe and Sound Kit Unboxing
Hazardous Gas Display
MSP-EXP432P401R Publishing Sensor Data to an MQTT Broker
Safe and Sound Hazardous Factors Sensor PCB
MQTT Publisher and Subscriber
Wearable Environmental Factors Instruments
Gas Sensors Module Power Up
Invisible Hazardous Environmental Factors System
CellPhoneShieldTest
GasSensorDemo
UV Tests
Safe & Sound Winners Announcement
    jw0752 over 9 years ago +6
    Thanks Doug for sharing all the fun you had making this great project. I am in awe of the great cases that you designed for the modules. Sometimes I have a little trouble getting started on a project but…
    mcb1 over 9 years ago +6
    Nice series of blogs during the development. I've decided that I don't want to be healthy in the Rest Home, and if something in the environment gets me first, then it's better that it's a surprise. I see…
    DAB over 9 years ago +6
    Hi Douglas, You have done a fantastic job with this challenge. Makes me want to put one together just to play with it. DAB
  • rachaelp
    rachaelp over 9 years ago
    Hi Doug,
    This has been an really excellent blog series to read, you've put so much effort into it. Totally awesome image
    Best Regards,
    Rachael
    • Vote Up +5 Vote Down
  • koudelad
    koudelad over 9 years ago
    Thank you for sharing all this with the community. It is an amazing project and I am looking forward to reading the blog posts again to get some inspiration for my own device image
    I hope you will win this design challenge.
    jw0752 over 9 years ago in reply to dougw
    You must be a late night person too. It seems that you are usually on the same time as I am and I know it is an hour or two later where you are. 12:38 here right now. As far as finishing goes I usually finish the project from my perspective but the final build is seldom up to commercial standards. Also most of my projects are quite simple. The most complicated thing I have ever done is a crude 30 volt 6 amp electronic load. The challenge there was designing the circuits to test for polarity, over voltage, and over current. Nothing a aesthetic as the things I have seen you build.
    dougw over 9 years ago in reply to jw0752
    I'm sure many would agree it can be even harder trying to complete a project, but the harder they are the more satisfying it is to complete.
    Thanks Doug for sharing all the fun you had making this great project. I am in awe of the great cases that you designed for the modules. Sometimes I have a little trouble getting started on a project but as you point out the reward of learning new things is well worth the effort.
    • Vote Up +6 Vote Down
