Project14
Project14
Blog Volunteer to Judge Op-Amp-a-Palooza
  • Theme Suggestions
  • Date Created: 3 May 2022 12:06 PM Date Created
  • Views 2347 views
  • Comments 9 comments
  • opampsch
tariq.ahmad
tariq.ahmad
3 May 2022
The Op-Amp-a-Palooza competition is now closed and we are looking for volunteers to choose a Grand Prize winner and award the First Place finishers.   If you didn't get a chance to participate and this is a theme of interest to you then we could use your help in picking a winner!
Op-Amp-a-Palooza
  • Op-Amp-a-Palooza is an open ended exploration of op-amps using low cost components and features premium op-amp testing equipment as prizes. There's so much that can be done with OpAmps: Amplifiers and buffers, measurement, active filters, voltage references, current measurement, audio vs RF vs HT, precision circuits low noise circuits making one from discrete components
This contest includes special op-amp related prizes and we need your help making sure those prizes go to the right place!
You will be judged on the basis of the following criteria:
  • Follow the Steps - Did they provide the steps it took to complete the project (text, video, or images) and/or schematics.
Those of you that have volunteered to judge in the past, you know the drill.  Comment below to let me know or message me directly at tariq.ahmad.
You're under no obligation to vote for the best project but we do ask that you look for complete projects and let us know your thoughts on the winners you pick.
The Projects:
Op-amp Based Wien Bridge Oscillator by scottiebabe
image image
image image
E14 Op-amp Kit - First Power Up by scottiebabe
image image
image image
LED Music Visualizer by rsjawale24
  • LED Music visualizer - Blog 1
  • LED Music visualizer - Blog 2: Filter Designs and Simulations
image image
image image
Op-Amp Line Follower by javagoza
  • Op-Amp Line Follower - Blog 1 First Steps
  • Op-Amp Line Follower - Blog 2 Following the research
  • Op-Amp Line Follower - Blog 3 The Line Follower
image image
image image
Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. by genebren
  • Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 2 - Power supply bring up and Analyzing the Noise Source.
  • Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 3 - Playing with noise.
  • Adding additional capabilities to my KORG volca modular synthesizer and learning about Op-Amps at the same time. Part 4 - Making Connection and Playing a Song.
image image
image image
Maneki Neko: Lucky Cat with a Laser by fmilburn
image image
image image
Evaluate Op-Amp MCP6032 with ECG by fyaocn
image image
image image
Inductors in Disguise by scottiebabe
image image
image image
Spectrophotometer for chemical analysis(Proof of Concept) by vinayyn
image image
image image
Breathing AMP by sunnyiut
image image
image image
Op-Amp Based Adjustable Load by milosrasic98
image image
image image
    dougw over 3 years ago +1
    Here is what I would use as a scoring spreadsheet... ..
  • tariq.ahmad
    tariq.ahmad over 3 years ago
    Thanks Jan Cumps ,  dougw,  and DAB!    I will be contacting you shortly.   :-)
  • tariq.ahmad
