Project14
Project14
Documents Project14 | Winners Announcement: Owning Time With Smart Alarm Clocks!
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 17 Jul 2018 1:45 AM Date Created
  • Last Updated Last Updated: 6 Aug 2018 7:42 AM
  • Views 2365 views
  • Likes 13 likes
  • Comments 7 comments
Smart Alarm Clock
Enter Your Electronics & Design Project for Your Chance to Win a $100 Shopping Cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
Congratulations to kk99 for Self-adjusting clock with e-display and guycarver for  Object Sensing Clock !
You are the winners of the Smart Alarm Clock competition from Project14 !
"The time we have at our disposal every day is elastic; the passions that we feel expand it, those that we inspire contract it; and habit fills up what remains." - Marcel Proust, author of In Search of Lost Time
kk99 made a self-adjusting smart alarm clock using an e-ink display and an Arduino.
gcarver had trouble sleeping at night so he used an temperature sensor to trigger the display.  Now, he only has to wave his hand to turn the display on or off.
This theme was an opportunity to think about time.  The Greeks used two different words for time, chronos for chronological time and kairos for qualitative time. Cronos governed linear and chronological time while kairos defined qualitative moments of time in relation to action, when conditions were set for the accomplishment of  a crucial action, an opportune and decisive moment. Indian philosophy had a cyclical view of time, a so called Wheel of Time, wherein the universe undergoes repeated cycles of destruction and rebirth to give rise to repeating ages over the infinite life of the universe.
The Wheel of Time concept can be found in Hinduism and Buddhism, the Ancient Greek Orphics and Pythagoreans, the Mayans, the Q'ero Indians of Peru, and the Hopi Indians of Arizona. The wheel concept, thinking of time as endlessly repeating cycles could perhaps be the drawn out conclusion to observable phenomena such as the cyclical alteration of day and night, the monthly cycle of the moon, and the annual cycle of the seasons.
Ancient Greek philosophers believed time and the universe was infinite with no beginning or end. For Aristotle, time does not exist independently of events that occur in time, time is something dependent on change, its "a number of change" in respect to the before and after.  Newton believed in absolute space and time; time passes uniformly without regard to what's happening in the world. Einstein's relativity theory turned our Newtonian view of time on its head.  According to relativity, our perception of "now" is a construct of the mind, time is no longer a sequence of events that happen, time does not pass or flow, and the past, present, and future exist simultaneously.
Relativity makes time travel possible:
Early this year, in March of 2018, Stephen Hawking, the man who once held the same seat in Cambridge as Isaac Newton, passed away, but not before reshaping our contemporary perception of time and space. According to Hawking, the universe and therefore time had a beginning, approximately 15 billion years, and beginning with his A Brief History of Time, he devoted his life's work to finding a unifying theory of time. With the help of the mathematician Roger Penrose, he was able to expound upon Einstein's theory of relativity, tracing the origins of time and space to a single point of zero size and infinite density, giving mathematical expression to Big Bang Theory, initially proposed by Georges Le Maitre in 1927, and confirmed two years later with Edwin Hubble's discovery that the universe was contracting.  He later tried marrying relativity with quantum theory, proposing that space and time were finite, and that time has an end.
Without further ado here are your winners for the Smart Alarm Clock Competition...
The Winners
Self-adjusting clock with e-display by kk99
kk99 set out to make a self-adjusting clock, making it work with CET time zone and supporting daylight savings. For the source of time, he used a GPS signal received from a NEO-7M module that had a serial port, a 2.9 inch module with e-ink display, and connected all this to an Arduino Nano. This is a really interesting application of e-ink technology that uses a low-powered Arduino and automatically updates using smart technology.  He provides schematics and source code which can be used to expand this project even further!
Also on Project14 by kk99
  • Repair of tone control circuit in old transistor radio  in Simple Electronic Repairs
  • Simple thermometer  in Cool LED Display
  • Infrared thermometer  in Cool LED Display
  • Cotton LED star with Digispark module in Cool LED Display
  • Control an relay from web server using NodeMCU  in Portable Electronics Kit
  • IR intervalometer for camera in Open Arduino
  • Simple electronic musical instrument in Simple Music Maker
  • Tube headphone amplifier in Simple Music Maker
Object Sensing Clock by guycarver
This was the first Project14 from guycarver and it was a definite winner.  If you've ever been annoyed by the glowing LED from traditional alarm clock,  this smart alarm clock uses an IR Temperature sensor as the trigger for the display. Simply wave your hand and it will turn on when you want to see the time at night. He came up with this solution to prevent the light from keeping him up at night and provides source code at https://github.com/GuyCarver/raspi/tree/master/projects/clock !
Honorable Mentions
Tempus Fugit by balearicdynamics
  • Tempus Fugit... Part 1: 1978 a.d.
  • Tempus Fugit... Part 2: 2018 a.d.
  • Tempus Fugit... Part 3: micro:bit Interfacing 5V Logic
  • Tempus Fugit... Part 4: micro:bit 5V SPI
Tempus Fugit is usually translated as "Time Flies" or "it escapes, irretrievable time." It's also the title for the seventeenth episode of the fourth season of X-Files.  In that episode, following a plane crash, agents Mulder and Scully notice a 9 minute disparity between the crash and the time on the victim's wristwatch, indicating missing time.  Of course their were aliens involved...
This project by balearicdynamics was added to the honorable mentions list for  Smart Alarm Clock because like the winners, its another strong entry and if not for "missing time" most certainly would have been a winner.  As time would have it, the idea to make a smart clock was not ibalearicdynamics's mind until a few weeks ago, when he found an incredible nice alarm clock of the past century. Alex is a digital alarm clock, dating back to 1978.   It was only partially working and therefore could be had on the cheap.
Also on Project14 from balearicdynamics :
  • Vintage 555 - A general-purpose button debouncer in DIY Test Equipment
  • TLE94112 Interactive Testing Platform in DIY Test Equipment
  • 3D Printer Filament Automatic Dispenser for Arduino - #1 Design and Hardware in DIY Test Equipment
  • The Lino Project with Arduino Mega 2560: Interrupts and Motors in Open Arduino
  • Cardboard Robot With Wheels: A BBC micro:bit STEM project in Robots with Wheels
  • Unreal. Resistance is Futile in Open Arduino
  • Dum-De-Dum, the Cardboard Drum! in Simple Music Maker
The  example project came from the AIS Alarm project and is worth mentioning.    The objective is to develop an open source AIS Alarm that alerts sailors that a new marine vessel with AIS is within range.  AIS (Automatic Identification System) is a tracking system for ships that gives information on among other things location, direction, and speed.  It is required on vessels of 300 or more gross tonnage and all passenger ships.
AIS Alarm  by fmilburn
  • AIS Alarm - The Process
  • AIS Alarm - Prototype Hardware
  • AIS Alarm - Timers and GPIO
  • AIS Alarm - Prototype Code Outline
  • AIS Alarm - UART
  • AIS Alarm - First AIS Messages
  • AIS Alarm - First FRAM Storage
  • AIS Alarm - Debouncing Momentary Button Switches
  • AIS Alarm - FRAM Ring Buffer
  • AIS Alarm - Schematic
  • AIS Alarm - PCB Version 0.1
  • AIS Alarm - PCB Version 0.1 Arrived
  • AIS Alarm - PCB Version 0.2
  • AIS Alarm - Everything Working
  • AIS Alarm - First Version 1.0 Hardware Assembled
  • AIS Alarm - Firmware Tested, Bug Squashed
Also on Project14  from fmilburn:
  • PERMA-PROTO: A Portable Prototyping System Built to Last in Portable Electronics Kit
  • LS Cubed: Little Sister Security System in Open Arduino
  • The IOT Wind Chimes in Simple Music Maker
Topsy Turvy Clock by Workshopshed
While not a smart alarm clock this is also a really cool build.  The hands are independently controlled with 2 stepper motors that also have a slotted disk which allows them to "home" and hence know their start position.
Also on Project14 by Workshopshed
  • Voice activated torch using a Rube Goldberg Machine in Wacky Automation Devices
  • Train Repair in Simple Electronic Repairs
  • A lightweight robot platform  in Robots with Wheels
  • Mini Logic Probe with display in DIY Test Equipment
  • Old fashioned Japanese Music Box in Simple Music Maker
  • Beaglebone plays the blues in Simple Music Maker
What's Happening Now
There's always stuff going on in the community so if you ran out of time for the Smart Alarm Competition you can suggest a similar idea in the Monthly Poll as well as vote on which of the community member's ideas you want to see happen next.  You can also join the Movers and Shakers competition by building any project that moves or shakes or the Solar Power Devices competition to build any project that harvests the energy of the sun to create a solar device.
Thank you for continued support of Project14 !
Keep inspiring others with your videos,  have fun, and be creative.   Your only limit is your imagination and well... time!  image
In the comments below:
Be sure to congratulate the winners and hope to see you later!
  • smartalarmclockch
  • past_contest
  • dixonselvan
    dixonselvan over 8 years ago +5
    Congratulations Winners - kk99 (Looks Simple but effective and neat project) and guycarver (Nice Build)- and Honorable Mentions - fmilburn (That's a really lot of blogs! appreciate your work) and Workshopshed…
    shabaz over 8 years ago +5
    These were really excellent projects as well as the honorable mentions! Congrats kk99 and guycarver !
  • 14rhb
    14rhb over 8 years ago +4
    Lots of really great projects in this Project14 month; but congratulations to kk99 and guy_carver for their wins. Rod
    genebren over 8 years ago
    Congratulations to winners and participants.
    Well done!
    Gene
  • kk99
    kk99 over 8 years ago
    Thank you. Congratulations for all participants.
    DAB over 8 years ago
    Well done to all participants.
    Another great challenge.
    mcb1 over 8 years ago
    Well done guys.
    Both well deserved.
    • Vote Up +5 Vote Down
  • 14rhb
    Rod
  • dixonselvan
    Congratulations Winners - kk99 (Looks Simple but effective and neat project) and guycarver (Nice Build)- and Honorable Mentions - fmilburn (That's a really lot of blogs! appreciate your work) and Workshopshed (Nice Project).
