Industrial Automation
Blog Connect to AVNET iotconnect.io with Node-RED - part 4: set up Node-RED and first exchange
  • Date Created: 9 Mar 2021 8:24 PM Date Created
  • Views 1357 views
  • iotconnect
  • raspberry
  • avnet
  • smartedge
  • node_red
  • cloud
  • iotconnect.io
9 Mar 2021
AVNET's iotconnect.io cloud platform is an online service that you can use to send data to, and then show it on a dashboard*. In this blog series I'm learning how to talk to it with Node-RED.
In this post: install the palette and test!.
Install the Node-RED SDK
The iotconnect module for Node-RED has two components, a connection and a command inserter.
To install, navigate to the Node-RED install directory.
On a Linux machine, that's often the .node-red subdir of your home.
Then register to the iotconnect repo
$ npm adduser --registry https://repo.iotconnect.io/
$ username: <retrieve from https://help.iotconnect.io/documentation/sdk-reference/device-sdks-flavors/node-red/  >
$ password: <retrieve from https://help.iotconnect.io/documentation/sdk-reference/device-sdks-flavors/node-red/  >
Enter an email address - I used the one from my iotnet.io subscription. AVNET informed me that if you have issues with the download account, you can reach out to https://knowledgebase.iotconnect.io/contact/
Then install the nodes:
$ npm install iotconnect-nodered-sdk --registry https://repo.iotconnect.io/
The nodes are added to your installation.
Connect for the first time
Start node-red and surf to the designer page.
Create a new flow, and place a connection:
You have to enter 3 attributes:
  • CPID. This is the customer number on the Key Vault page. Do not share this
  • Unique ID. Your device's unique ID as available on the Device page
  • ENV. Selection box. Select the Environment that's shown in the key vault.
Deploy the flow. If you did everything correctly, the node shows it's connected.
The dot coloured green:
Celebrate.
First Data exchange
Let's send the first telemetry data to the iotconnect.io cloud.
Add an IotConnect Injecter node and fill in the JASON package:
        "uniqueId": "e14nodered1",
        "data": {
            "Temperature": "21"
The uniqueID is the same one you used when defining the connection.
The attribute has to be one that's registered in the template. We added Temperature.
I added a debug block at the end as part of the test, but that's not needed.
It shows the payload , if it's sent correctly to the cloud.
Press the Inject node's button. The message is sent to iotconnect.io:
Celebrate again.
In the next post: commands from the cloud.
This is the source code of my final flow.
You can import this in Node-RED by clicking the 3-bars icon in the right up corner of your Node-RED editor, then select import.
You will have to update cpID and uniqueID.
      "id":"df3bfead.a2439",
      "type":"tab",
      "label":"AVNET IotConnect e14",
      "disabled":false,
      "info":""
      "id":"e711923e.ef5d8",
      "type":"IoTConnect",
      "z":"df3bfead.a2439",
      "cpId":"USEYOURCPID",
      "uniqueId":"e14nodered1",
      "env":"PROD",
      "offlineStorageEnable":false,
      "sizeLimit":0,
      "fileCount":0,
      "isSecure":false,
      "sslKey":"",
      "sslCert":"",
      "sslCA":"",
      "x":635,
      "y":380,
      "wires":[
            "77a78d77.1e42a4"
            "43b9c47.dc8b83c",
            "66d83cd3.f10e34"
      "l":false
      "id":"3f1d5622.789b8a",
      "type":"IoTConnect-Injector",
      "iType":"SendData",
      "descText":"",
      "payload":"",
      "x":475,
      "y":380,
      "wires":[
            "e711923e.ef5d8"
      "l":false
      "id":"93b6ac97.e0525",
      "type":"inject",
      "name":"",
      "props":[
            "p":"payload"
      "repeat":"",
      "crontab":"",
      "once":false,
      "onceDelay":0.1,
      "topic":"",
      "payload":"[{\"uniqueId\":\"e14nodered1\",\"data\":{\"Temperature\":\"-1\"}}]",
      "payloadType":"json",
      "x":175,
      "y":380,
      "wires":[
            "3f1d5622.789b8a"
      "l":false
      "id":"80319059.b447a",
      "type":"random",
      "name":"random temperature",
      "low":"-10",
      "high":"65",
      "inte":"true",
      "property":"payload[0].data.Temperature",
      "x":235,
      "y":420,
      "wires":[
            "3f1d5622.789b8a"
      "l":false
      "id":"358a344c.e4788c",
      "type":"inject",
      "name":"",
      "props":[
            "p":"payload"
      "repeat":"300",
      "crontab":"",
      "once":true,
      "onceDelay":0.1,
      "topic":"",
      "payload":"[{\"uniqueId\":\"e14nodered1\",\"data\":{\"Temperature\":\"0\"}}]",
      "x":175,
      "y":420,
      "wires":[
            "80319059.b447a"
      "l":false
      "id":"da5174df.fac2b8",
      "type":"comment",
      "name":"iotconnect.io \\n send",
      "info":"",
      "x":510,
      "y":320,
      "wires":[
      "id":"a38ec099.0860e",
      "type":"comment",
      "name":"iotconnect.io \\n communicate",
      "info":"",
      "x":690,
      "y":320,
      "wires":[
      "id":"de5e0d4f.24ad8",
      "type":"comment",
      "name":"temperature",
      "info":"",
      "x":210,
      "y":340,
      "wires":[
      "id":"fa433c1a.1f67a",
      "iType":"SendCommandAck",
      "descText":"",
      "payload":"",
      "x":715,
      "y":460,
      "wires":[
            "e711923e.ef5d8"
      "l":false
      "id":"43b9c47.dc8b83c",
      "type":"switch",
      "name":"ACK?",
      "property":"payload.ack",
      "propertyType":"msg",
      "rules":[
            "t":"true"
            "t":"false"
      "checkall":"false",
      "repair":false,
      "outputs":2,
      "x":610,
      "y":460,
      "wires":[
            "fa433c1a.1f67a"
      "id":"c8d6826d.93e39",
      "type":"comment",
      "name":"receipt mgt",
      "info":"",
      "x":640,
      "y":500,
      "wires":[
      "id":"77a78d77.1e42a4",
      "type":"debug",
      "name":"",
      "active":true,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"true",
      "targetType":"full",
      "statusVal":"",
      "statusType":"auto",
      "x":915,
      "y":380,
      "wires":[
      "icon":"font-awesome/fa-bug",
      "l":false
      "id":"ecf3a6a7.18f888",
      "type":"comment",
      "name":"iotconnect.io \\n receive",
      "info":"",
      "x":930,
      "y":320,
      "wires":[
      "id":"66d83cd3.f10e34",
      "type":"debug",
      "name":"",
      "active":false,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"true",
      "statusVal":"",
      "x":735,
      "y":400,
      "wires":[
      "l":false
The Python SDK with On Semiconductor RSL10 BLE article seriesIndustry
part 1: overview and goal
part 2: WiFi Provisioning
part 3: Adding a Module (RSL10)
part 4: Talk BLE to the On Semi RSL10 Sensor Kit
part 5: A Cloud User Experience Example
part 6: Register as a Gateway Device
part 7: Register a Gateway and Client Devices
The NODE-Red SDK article seriesIndustry
register a Thing and connect to IoTConnect.io cloud
part 2: create an account and log on to the portal
part 3: set up the thing and its interface in the cloud
interact with IoTConnect.io cloud
part 5: online dashboard
part 6: rules and alerts
part 7: messages and commands from the cloud
safer connections with certificates
part 8a: safer connect with Self Signed Certificates
part 8b: safer connect with CA certificatesY
commercial and industrial scale: outsource certificate generation and programming to subcontractors and suppliers
part 9a: Outsource Certificate Signing in IIoT Supply ChainY
part 9b: IIoT supply chain and Certificates - Create Ca Root certificate, Load to IoTConnect Cloud and ValidateY
part 9c: IIoT supply chain and Certificates - Create an Intermediate CA Certificate for your SubcontractorY
part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your DeviceY
part 9e: IIoT supply chain and Certificates - Test!Y
commercial and industrial scale: Trusted Platform Module (TPM) Authentication
part 10: Trusted Platform Module (TPM) SecurityY
Infineon SLx9670 Trusted Platform Module (TPM) for IoT SecurityY
The Automate Device Provisioning and Cloud Configuration article seriesIndustry
Automatic Provisioning with REST APIY
    Jan Cumps over 5 years ago +1
    What my post does not show, is that this works well together with the common Node-RED components: The payload does not have to come from the bespoke IotConnect injector. You can keep it empty and feed…
    I've added the final Node-RED code to the post.
    If you want to reuse it, import it.
    Then correct the CPID and Unique ID in the Connection node and all upstream nodes.
          "type":"tab",
          "disabled":false,
          "info":""
          "cpId":"USEYOUROWNCPID",
          "env":"PROD",
          "sizeLimit":0,
          "fileCount":0,
          "isSecure":false,
          "sslKey":"",
          "sslCert":"",
          "sslCA":"",
          "x":635,
          "y":380,
          "wires":[
                "77a78d77.1e42a4"
                "43b9c47.dc8b83c",
                "66d83cd3.f10e34"
          "l":false
          "iType":"SendData",
          "descText":"",
          "payload":"",
          "x":475,
          "y":380,
          "wires":[
                "e711923e.ef5d8"
          "l":false
          "type":"inject",
          "name":"",
          "props":[
                "p":"payload"
          "repeat":"",
          "crontab":"",
          "once":false,
          "onceDelay":0.1,
          "topic":"",
          "x":175,
          "y":380,
          "wires":[
                "3f1d5622.789b8a"
          "l":false
          "type":"random",
          "low":"-10",
          "high":"65",
          "inte":"true",
          "x":235,
          "y":420,
          "wires":[
                "3f1d5622.789b8a"
          "l":false
          "type":"inject",
          "name":"",
          "props":[
                "p":"payload"
          "repeat":"300",
          "crontab":"",
          "once":true,
          "onceDelay":0.1,
          "topic":"",
          "x":175,
          "y":420,
          "wires":[
                "80319059.b447a"
          "l":false
          "type":"comment",
          "info":"",
          "x":510,
          "y":320,
          "wires":[
          "type":"comment",
          "info":"",
          "x":690,
          "y":320,
          "wires":[
          "type":"comment",
          "info":"",
          "x":210,
          "y":340,
          "wires":[
          "descText":"",
          "payload":"",
          "x":715,
          "y":460,
          "wires":[
                "e711923e.ef5d8"
          "l":false
          "type":"switch",
          "name":"ACK?",
          "rules":[
                "t":"true"
                "t":"false"
          "checkall":"false",
          "repair":false,
          "outputs":2,
          "x":610,
          "y":460,
          "wires":[
                "fa433c1a.1f67a"
          "type":"comment",
          "info":"",
          "x":640,
          "y":500,
          "wires":[
          "type":"debug",
          "name":"",
          "active":true,
          "tosidebar":true,
          "console":false,
          "tostatus":false,
          "complete":"true",
          "statusVal":"",
          "x":915,
          "y":380,
          "wires":[
          "l":false
          "type":"comment",
          "info":"",
          "x":930,
          "y":320,
          "wires":[
          "type":"debug",
          "name":"",
          "active":false,
          "tosidebar":true,
          "console":false,
          "tostatus":false,
          "complete":"true",
          "statusVal":"",
          "x":735,
          "y":400,
          "wires":[
          "l":false
    If you use the same Unique ID as me in your exercise, only change the CPID in the Connect node.
          "type":"tab",
          "disabled":false,
          "info":""
          "env":"PROD",
          "sizeLimit":0,
          "fileCount":0,
          "isSecure":false,
          "sslKey":"",
          "sslCert":"",
          "sslCA":"",
          "x":635,
          "y":380,
          "wires":[
                "77a78d77.1e42a4"
                "43b9c47.dc8b83c",
                "66d83cd3.f10e34"
          "l":false
          "iType":"SendData",
          "descText":"",
          "payload":"",
          "x":475,
          "y":380,
          "wires":[
                "e711923e.ef5d8"
          "l":false
          "type":"inject",
          "name":"",
          "props":[
                "p":"payload"
          "repeat":"",
          "crontab":"",
          "once":false,
          "onceDelay":0.1,
          "topic":"",
          "x":175,
          "y":380,
          "wires":[
                "3f1d5622.789b8a"
          "l":false
          "type":"random",
          "low":"-10",
          "high":"65",
          "inte":"true",
          "x":235,
          "y":420,
          "wires":[
                "3f1d5622.789b8a"
          "l":false
          "type":"inject",
          "name":"",
          "props":[
                "p":"payload"
          "repeat":"300",
          "crontab":"",
          "once":true,
          "onceDelay":0.1,
          "topic":"",
          "x":175,
          "y":420,
          "wires":[
                "80319059.b447a"
          "l":false
          "type":"comment",
          "info":"",
          "x":510,
          "y":320,
          "wires":[
          "type":"comment",
          "info":"",
          "x":690,
          "y":320,
          "wires":[
          "type":"comment",
          "info":"",
          "x":210,
          "y":340,
          "wires":[
          "descText":"",
          "payload":"",
          "x":715,
          "y":460,
          "wires":[
                "e711923e.ef5d8"
          "l":false
          "type":"switch",
          "name":"ACK?",
          "rules":[
                "t":"true"
                "t":"false"
          "checkall":"false",
          "repair":false,
          "outputs":2,
          "x":610,
          "y":460,
          "wires":[
                "fa433c1a.1f67a"
          "type":"comment",
          "info":"",
          "x":640,
          "y":500,
          "wires":[
          "type":"debug",
          "name":"",
          "active":true,
          "tosidebar":true,
          "console":false,
          "tostatus":false,
          "complete":"true",
          "statusVal":"",
          "x":915,
          "y":380,
          "wires":[
          "l":false
          "type":"comment",
          "info":"",
          "x":930,
          "y":320,
          "wires":[
          "type":"debug",
          "name":"",
          "active":false,
          "tosidebar":true,
          "console":false,
          "tostatus":false,
          "complete":"true",
          "statusVal":"",
          "x":735,
          "y":400,
          "wires":[
          "l":false
