Industrial Automation
Blog Connect to AVNET iotconnect.io with Node-RED - part 5: online dashboard
  • Date Created: 12 Mar 2021 5:40 PM Date Created
  • Views 1788 views
  • raspberry
  • avnet
  • smartedge
  • node_red
  • cloud
  • iotconnect.io
12 Mar 2021
AVNET's iotconnect.io cloud platform is an online service that you can use to send data to, and then show it on a dashboard*. In this blog series I'm learning how to talk to it with Node-RED.
In this post: the dashboard (live link).
In the previous part of the series, I've done all the steps to exchange data between a thing and the iotconnect.io cloud.
And how to do that with Node-RED.
In this post, I will step away from Node-RED for a moment, and focus on working with the data online.
I'll create a dashboard to show the telemetry data (temperature) from my device, and build an email alert.
All of that is done in the IotConnect portal.
Make a Dashboard
In the portal (I do not put a link here, because you need to consult previous posts to get to this point), click on the New Dashboard link
Create a new one, and edit it:
Give it a name and save.
Click Edit Property, and make it the default board
Show the most recent Temperature
Let's start with a simple tile to show the temperature.
Drag a single tile on the canvas. Click the ... to enter the properties form.
Set name, select device and attribute. It will list all available devices, and the attributes of the associated template.
Apply and save the dashboard. It is a Live control and will not yet show data. The control shows data that arrives after the board is displayed.
It's now time to go to your Node-RED flow and send a message to the cloud.
You'll see that the tile shows the info almost immediately after you pushed it to the cloud.
Show a Temperature Chart
Now let's try a chart. To get somewhat interesting data, I modified the Node-RED flow to "generate" random temperature data, every 5 minutes.
Here's the payload definition of the injector:
  "uniqueId":"e14nodered1",
  "data":
   "Temperature":"0"
Then the generator overrides the temperature:
This will give a steady data stream. A new temperature every 5 minutes. Deploy the flow.
Now add a line chart to the dashboard. Edit it, set the title, select the device and attribute.
Apply and save.
Because the Node-RED flow generates a temperature "measurement" every 5 minutes, you'll slowly see the chart showing the data.
If you are impatient, you can increase the repeat speed of the inject node of your flow. But be careful not to overrun the quota of your iotconnect.io account.
It may be better to just manually push the inject button a few times. It will generate enough data points then to show on the chart.
Here's my board after a few exchanges:
and a more elaborate one:
There are controls for asset tracking:
The left upper chart shows devices physical locations (the device has to communicate LAT and LON).
The chart below that shows the itinerary of a single device. You can use this for rolling material or assets you rent out or lease.
The two tables on the right show new devices added to your portfolio, and alarms.
The Python SDK with On Semiconductor RSL10 BLE article seriesIndustry
part 1: overview and goal
part 2: WiFi Provisioning
part 3: Adding a Module (RSL10)
part 4: Talk BLE to the On Semi RSL10 Sensor Kit
part 5: A Cloud User Experience Example
part 6: Register as a Gateway Device
part 7: Register a Gateway and Client Devices
The NODE-Red SDK article seriesIndustry
register a Thing and connect to IoTConnect.io cloud
part 2: create an account and log on to the portal
part 3: set up the thing and its interface in the cloud
part 4: set up Node-RED and first exchange
interact with IoTConnect.io cloud
part 6: rules and alerts
part 7: messages and commands from the cloud
safer connections with certificates
part 8a: safer connect with Self Signed Certificates
part 8b: safer connect with CA certificatesY
commercial and industrial scale: outsource certificate generation and programming to subcontractors and suppliers
part 9a: Outsource Certificate Signing in IIoT Supply ChainY
part 9b: IIoT supply chain and Certificates - Create Ca Root certificate, Load to IoTConnect Cloud and ValidateY
part 9c: IIoT supply chain and Certificates - Create an Intermediate CA Certificate for your SubcontractorY
part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your DeviceY
part 9e: IIoT supply chain and Certificates - Test!Y
commercial and industrial scale: Trusted Platform Module (TPM) Authentication
part 10: Trusted Platform Module (TPM) SecurityY
Infineon SLx9670 Trusted Platform Module (TPM) for IoT SecurityY
The Automate Device Provisioning and Cloud Configuration article seriesIndustry
Automatic Provisioning with REST APIY
    Jan Cumps over 5 years ago +1
    This is what a full flow could look like. The input and output parts are test blocks. Input feeds generated values, output goes to a debug window. But the whole middle section is a full blown communication…
    Different dashboard artwork, focused on assets:
    But the whole middle section is a full blown communication block that can send and receive data, and deal with confirmation messages.
