Industrial Automation
Blog Connect to AVNET iotconnect.io (with Node-RED) - part 6: rules and alerts
  • Date Created: 24 Mar 2021 7:56 PM Date Created
  • Views 1912 views
  • Comments 5 comments
  • iotconnect
  • avnet
  • smartedge
  • node_red
  • cloud
24 Mar 2021
AVNET's iotconnect.io cloud platform is an online service that you can use to send data to, and then show it on a dashboard*. In this blog series I'm learning how to talk to it with Node-RED.
In this post, no Node-RED. I'm testing rules and alerts. Send a mail when a condition becomes true (temperature below freeze point).
Rules are useful to manage exceptions, warnings or draw attention to a condition.
In this case I'll send a message if the temperature I'm measuring with my thing drops below 0° C.
This can reflect a real-world situation where you may have to take some measures if a device has been in freeze conditions.
Create the rule
I'll create a simple rule. It's based on a fixed condition of a single parameter:
if temp < 0, send email.
I've set it up to send an email to a single user, myself:
This is the result after saving:
Test the rule
I'm using the "inject a temperature" part of my Node-RED flow to simulate that I measure "-1 °C".
The mail arrives:
You can see the content in the header of this post.
Here's how you can monitor the rule in the console, for all your notifications:
And here how you can see the rules that were executed for a particular device:
... and you can add a tile to the dashboard created in the previous post:
You can design complex conditions and use different notification mechanisms.
The steps above will help to get started. You can build up from here.
The Python SDK with On Semiconductor RSL10 BLE article seriesIndustry
part 1: overview and goal
part 2: WiFi Provisioning
part 3: Adding a Module (RSL10)
part 4: Talk BLE to the On Semi RSL10 Sensor Kit
part 5: A Cloud User Experience Example
part 6: Register as a Gateway Device
part 7: Register a Gateway and Client Devices
The NODE-Red SDK article seriesIndustry
register a Thing and connect to IoTConnect.io cloud
part 2: create an account and log on to the portal
part 3: set up the thing and its interface in the cloud
part 4: set up Node-RED and first exchange
interact with IoTConnect.io cloud
part 5: online dashboard
part 7: messages and commands from the cloud
safer connections with certificates
part 8a: safer connect with Self Signed Certificates
part 8b: safer connect with CA certificatesY
commercial and industrial scale: outsource certificate generation and programming to subcontractors and suppliers
part 9a: Outsource Certificate Signing in IIoT Supply ChainY
part 9b: IIoT supply chain and Certificates - Create Ca Root certificate, Load to IoTConnect Cloud and ValidateY
part 9c: IIoT supply chain and Certificates - Create an Intermediate CA Certificate for your SubcontractorY
part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your DeviceY
part 9e: IIoT supply chain and Certificates - Test!Y
commercial and industrial scale: Trusted Platform Module (TPM) Authentication
part 10: Trusted Platform Module (TPM) SecurityY
Infineon SLx9670 Trusted Platform Module (TPM) for IoT SecurityY
The Automate Device Provisioning and Cloud Configuration article seriesIndustry
Automatic Provisioning with REST APIY
    Jan Cumps over 5 years ago in reply to ntewinkel +1
    I've asked for a subscription that at least would outlast the exercise I'm doing. (May be the 5th time I asked - at e14 and avnet - I don't even get a positive nor negative reply on those requests. )
    It is active. I'm talking to one of the designers about the BLE functionality. There should also be a new release of the Node-RED blocks, to support additional security options.
    my account expired.
  • ntewinkel
    ntewinkel over 5 years ago in reply to Jan Cumps
    I don't know why Avnet wouldn't just give you a subscription for a year or two - the content you create is more than I've seen from Avnet employees! That includes the (lack of) information on their own website.
  • ntewinkel
  • ntewinkel
    Jan Cumps  wrote:
    ... I don't even get a positive nor negative reply on those requests. )
    I wonder if the last person to leave that project forgot to turn off the lights imageimage
