Industrial Automation
Blog Connect to AVNET iotconnect.io with Node-RED - part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your Device
  • Date Created: 13 Apr 2021 8:10 PM Date Created
  • Views 921 views
  • node_red
  • openssl
  • iotconnect.io
13 Apr 2021
For context, check the intro post.
Summary: How to use Signed Certificates in an IoT supply chain. Without giving away your private keys to your subcontractor.
At the end of this post, you completed 90% of the end-to-end process.
You, as subcontractor Louisiana Branch, will generate and sign certificates for Things, on behalf of the conglomerate United States Manufacturing.
No private keys will be shared. The subcontractor can generate the certificates, one for each Thing.
We as Root CA will only allow devices on our cloud that have a valid certificate chain and are provisioned.
The validation part (the focus of this saga) is portable across cloud solutions.
Subcontractor Generates Thing Certificate
This is what the whole story was written for: generate a unique, valid key pair for each device we want to sell.
A key pair that can be validated by our Root public certificate.
A key pair that can be generated by any subcontractor we have an agreement (trust contract) with.
Without sharing our private key and associated password to anyone.
Traceable end to end.
Create a Key Pair for the Thing
I've consistently used Certificate and Private Key in the series. But we're at the end, time to loosen up.
A certificate is the same as a public key. A certificate + private key is a key pair.
Key pairs are used to authenticate. Let's make one for the Thing that will be installed in New Orleans, LA.
In this post you will see that I have a code in front of the thing's unique name neworleans.
That is IoTConnect.io specific. The unique name is formed by the CPID (a code you get when enrolling, I obfuscated mine), and the unique name you define for your device. Separated by a '-'.
You are now pretending you are the subcontractor.
Create a key
This key does not have a password associated to it.
openssl genrsa \
      -out louisiana/private/b***2-neworleans.key.pem 2048
chmod 400 louisiana/private/b***2-neworleans.key.pem
Create a certificate
First the request.
The Common name has to be the unique name of the Thing on the Cloud:
CN: b***2-neworleans
openssl req -config louisiana/openssl.cnf \
      -key louisiana/private/b***2-neworleans.key.pem \
      -new -sha256 -out louisiana/csr/b***2-neworleans.csr.pem
Then the certificate, signed by the Intermediate CA private key (subcontractor's key).
openssl ca -config louisiana/openssl.cnf \
      -extensions usr_cert -days 375 -notext -md sha256 \
      -in louisiana/csr/b***2-neworleans.csr.pem \
      -out louisiana/certs/b***2-neworleans.cert.pem
chmod 444 louisiana/certs/b***2-neworleans.cert.pem
Verify the certificate
cat louisiana/index.txt
openssl x509 -noout -text \
      -in louisiana/certs/b***2-neworleans.cert.pem
openssl verify -CAfile louisiana/certs/ca-chain.cert.pem \
Create Full Certification Chain File
cat \
      louisiana/certs/b***2-neworleans.cert.pem \
      > louisiana/certs/b***2-neworleans-chain.cert.pem
chmod 444 louisiana/certs/b***2-neworleans-chain.cert.pem
The subcontractor has everything needed now for a successful connection:
  • device public certificate chain: b***2-neworleans.cert.pem
  • device private key: b***2-neworleans.key.pem
  • Root CA certificate ca.cert.pem
What Have You Achieved: 90%
Previous posts:
You generated and installed a root certificate on IoTConnect Cloud.
You built a major part of the infrastructure that you will later use to generate the intermediate certificates.
Subcontractor generated a private key and a certificate request. They gave you the request file.
You generated the intermediate CA certificate and signed it with your Root CA private key.
You gave the certificate, your own root certificate, and the chain up to that point, to the supplier.
This post:
Subcontractor generated and collects all artifacts needed to authenticate a unique device for you.
Next article: Test! With a Node-RED flow. On a Raspberry Pi style device.
The Python SDK with On Semiconductor RSL10 BLE article seriesIndustry
part 1: overview and goal
part 2: WiFi Provisioning
part 3: Adding a Module (RSL10)
part 4: Talk BLE to the On Semi RSL10 Sensor Kit
part 5: A Cloud User Experience Example
part 6: Register as a Gateway Device
part 7: Register a Gateway and Client Devices
The NODE-Red SDK article seriesIndustry
register a Thing and connect to IoTConnect.io cloud
part 2: create an account and log on to the portal
part 3: set up the thing and its interface in the cloud
part 4: set up Node-RED and first exchange
interact with IoTConnect.io cloud
part 5: online dashboard
part 6: rules and alerts
part 7: messages and commands from the cloud
safer connections with certificates
part 8a: safer connect with Self Signed Certificates
part 8b: safer connect with CA certificatesY
commercial and industrial scale: outsource certificate generation and programming to subcontractors and suppliers
part 9a: Outsource Certificate Signing in IIoT Supply ChainY
part 9b: IIoT supply chain and Certificates - Create Ca Root certificate, Load to IoTConnect Cloud and ValidateY
part 9c: IIoT supply chain and Certificates - Create an Intermediate CA Certificate for your SubcontractorY
part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your DeviceY
part 9e: IIoT supply chain and Certificates - Test!Y
commercial and industrial scale: Trusted Platform Module (TPM) Authentication
part 10: Trusted Platform Module (TPM) SecurityY
Infineon SLx9670 Trusted Platform Module (TPM) for IoT SecurityY
The Automate Device Provisioning and Cloud Configuration article seriesIndustry
Automatic Provisioning with REST APIY
    Jan Cumps over 5 years ago +1
    For @self: -> ->
    For @self:
    For @self:
