Industrial Automation
Blog Connect to AVNET iotconnect.io with Node-RED - part 9e: IIoT supply chain and Certificates - Test!
  • Date Created: 14 Apr 2021 6:50 PM Date Created
  • Views 1226 views
14 Apr 2021
For context, check the intro post.
Summary: How to use Signed Certificates in an IoT supply chain. Without giving away your private keys to your subcontractor.
At the end of this post, you completed 90% of the end-to-end process.
You, as subcontractor Louisiana Branch, will generate and sign certificates for Things, on behalf of the conglomerate United States Manufacturing.
Program the Thing
Your subcontractor will load the firmware on your device, install the certificates, provision the device on the cloud and test.
You have developed the firmware and handed it over to the vendor.
When they program it and load the certificates, they may also have to do some configurations.
Most vendors will script all of this, from certificate generation over firmware configuration to the load, provisioning and test, and do this as a step on the assembly line.
In this blog, I'll do it manually.
Upload the certificate artifacts. This is highly dependent on the device you have.
Some provide a dedicated memory area that can only be read by firmware.
Some have a key vault.
On Linux, place it in a folder that's only readable by the user that runs the firmware (here: the Node-RED service user).
In this scenario, we need the tree artifacts generated in the previous post.
Configure and load the firmware. In our case a json file with a Node-RED flow.
The automated script would automatically configure customer ID (cpId), unique ID, and if we use unique names for certificates, also those.
Then import in Node-RED.
      "id":"38356517.efc10a",
      "type":"tab",
      "label":"IoTConnect New Orleans",
      "disabled":false,
      "info":""
      "id":"5139ef2a.05a86",
      "type":"IoTConnect",
      "z":"38356517.efc10a",
      "cpId":"1*****",
      "uniqueId":"neworleans",
      "env":"PROD",
      "auth":"2",
      "offlineStorageEnable":false,
      "sizeLimit":0,
      "fileCount":0,
      "sslKey":"/home/avnet/.iotconnect/.neworleans/1******-neworleans.key.pem",
      "sslCert":"/home/avnet/.iotconnect/.neworleans/1******-neworleans-chain.cert.pem",
      "sslCA":"/home/avnet/.iotconnect/.neworleans/ca.cert.pem",
      "idScope":"",
      "x":675,
      "y":200,
      "wires":[
            "61178473.a0f70c",
            "e6dd8afb.945498"
            "c56a4d18.5d2ea"
      "l":false
      "id":"2196de99.bb4322",
      "type":"IoTConnect-Injector",
      "iType":"SendData",
      "descText":"",
      "payload":"[\n    {\n        \"uniqueId\": \"\",\n        \"time\": \"2021-05-19T19:37:05.800Z\",\n        \"data\": {\n            \"temperature\": \"17\"\n        }\n    }\n]",
      "x":515,
      "y":200,
      "wires":[
            "5139ef2a.05a86"
      "l":false
      "id":"b7e2b58e.e39608",
      "type":"inject",
      "name":"",
      "props":[
            "p":"payload"
      "repeat":"",
      "crontab":"",
      "once":false,
      "onceDelay":0.1,
      "topic":"",
      "payload":"[{\"uniqueId\":\"neworleans\",\"data\":{\"temperature\":\"-1\"}}]",
      "payloadType":"json",
      "x":215,
      "y":200,
      "wires":[
            "2196de99.bb4322"
      "l":false
      "id":"48b4e7be.38da88",
      "type":"random",
      "name":"random temperature",
      "low":"-10",
      "high":"65",
      "inte":"true",
      "property":"payload[0].data.Temperature",
      "x":275,
      "y":240,
      "wires":[
            "2196de99.bb4322"
      "l":false
      "id":"ebd0a829.213a98",
      "type":"inject",
      "name":"",
      "props":[
            "p":"payload"
      "repeat":"3600",
      "crontab":"",
      "once":true,
      "onceDelay":0.1,
      "topic":"",
      "payload":"[{\"uniqueId\":\"neworleans\",\"data\":{\"temperature\":\"0\",\"latitude\":52.765929,\"longitude\":6.27153}}]",
      "x":215,
      "y":240,
      "wires":[
            "48b4e7be.38da88"
      "l":false
      "id":"aeba4e1c.0de5b",
      "type":"comment",
      "name":"iotconnect.io \\n send",
      "info":"",
      "x":550,
      "y":140,
      "wires":[
      "id":"af31f3d5.073d",
      "type":"comment",
      "name":"iotconnect.io \\n communicate",
      "info":"",
      "x":730,
      "y":140,
      "wires":[
      "id":"30c8ac63.5559d4",
      "type":"comment",
      "name":"temperature",
      "info":"",
      "x":250,
      "y":160,
      "wires":[
      "id":"61178473.a0f70c",
      "type":"debug",
      "name":"",
      "active":true,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"true",
      "targetType":"full",
      "statusVal":"",
      "statusType":"auto",
      "x":955,
      "y":200,
      "wires":[
      "icon":"font-awesome/fa-bug",
      "l":false
      "id":"286ca1a4.4a214e",
      "type":"comment",
      "name":"iotconnect.io \\n receive",
      "info":"",
      "x":970,
      "y":140,
      "wires":[
      "id":"c56a4d18.5d2ea",
      "type":"debug",
      "name":"",
      "active":true,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"true",
      "statusVal":"",
      "x":775,
      "y":220,
      "wires":[
      "l":false
      "id":"786abb8b.c1d6d4",
      "iType":"Disconnect",
      "descText":"",
      "payload":"",
      "x":250,
      "y":300,
      "wires":[
            "5139ef2a.05a86"
      "id":"7c8682e9.dc959c",
      "iType":"SendCommandAck",
      "descText":"",
      "payload":"",
      "x":775,
      "y":300,
      "wires":[
            "5139ef2a.05a86"
      "l":false
      "id":"e6dd8afb.945498",
      "type":"switch",
      "name":"ACK?",
      "property":"payload.ack",
      "propertyType":"msg",
      "rules":[
            "t":"true"
            "t":"false"
      "checkall":"false",
      "repair":false,
      "outputs":2,
      "x":590,
      "y":340,
      "wires":[
            "69158414.46415c"
            "9a7ee3c.75f052"
      "id":"f2c5a2d1.4b0a",
      "type":"debug",
      "name":"",
      "active":false,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"\"ACK sent\"",
      "targetType":"jsonata",
      "statusVal":"",
      "x":755,
      "y":340,
      "wires":[
      "l":false
      "id":"9a7ee3c.75f052",
      "type":"debug",
      "name":"",
      "active":false,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"\"ACK not required\"",
      "statusVal":"",
      "x":755,
      "y":380,
      "wires":[
      "l":false
      "id":"6965f124.a61b",
      "type":"comment",
      "name":"receipt mgt",
      "info":"",
      "x":570,
      "y":381,
      "wires":[
      "id":"69158414.46415c",
      "type":"function",
      "name":"",
      "func":"msg.payload['st']=6\nmsg.payload['msg']=\"ACK Success\"\nreturn msg;",
      "outputs":1,
      "noerr":0,
      "initialize":"",
      "finalize":"",
      "x":685,
      "y":321,
      "wires":[
            "7c8682e9.dc959c",
            "f2c5a2d1.4b0a"
      "l":false
Refer to this post for the correct ACK handling.
In parallel, another service at the subcontractor can use the IoTCloud REST API to provision the device on the cloud.
I may write a post on how to do that.
For the moment, I'm doing this manually in the portal:
It's also fast, but automation is better.
Test!
The subcontractor engages in testing. Manually or automatic.
Both Node-RED log and cloud portal report success.
In our case, this can also be scripted: start Node-RED and parse the output.
Or the IoTConnect REST API can be used to retrieve the status. This could again be done at the production line.
Successfully programmed devices can be packaged, failing ones binned in a rework container.
You can replicate this. With your Windows laptop, a Raspberry Pi, BB, ...
Try it.
The Python SDK with On Semiconductor RSL10 BLE article seriesIndustry
part 1: overview and goal
part 2: WiFi Provisioning
part 3: Adding a Module (RSL10)
part 4: Talk BLE to the On Semi RSL10 Sensor Kit
part 5: A Cloud User Experience Example
part 6: Register as a Gateway Device
part 7: Register a Gateway and Client Devices
The NODE-Red SDK article seriesIndustry
register a Thing and connect to IoTConnect.io cloud
part 2: create an account and log on to the portal
part 3: set up the thing and its interface in the cloud
part 4: set up Node-RED and first exchange
interact with IoTConnect.io cloud
part 5: online dashboard
part 6: rules and alerts
part 7: messages and commands from the cloud
safer connections with certificates
part 8a: safer connect with Self Signed Certificates
part 8b: safer connect with CA certificatesY
commercial and industrial scale: outsource certificate generation and programming to subcontractors and suppliers
part 9a: Outsource Certificate Signing in IIoT Supply ChainY
part 9b: IIoT supply chain and Certificates - Create Ca Root certificate, Load to IoTConnect Cloud and ValidateY
part 9c: IIoT supply chain and Certificates - Create an Intermediate CA Certificate for your SubcontractorY
part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your DeviceY
part 9e: IIoT supply chain and Certificates - Test!Y
commercial and industrial scale: Trusted Platform Module (TPM) Authentication
part 10: Trusted Platform Module (TPM) SecurityY
Infineon SLx9670 Trusted Platform Module (TPM) for IoT SecurityY
The Automate Device Provisioning and Cloud Configuration article seriesIndustry
Automatic Provisioning with REST APIY
    Jan Cumps over 5 years ago
    I have done additional tests last weekend.
    When I originally wrote this, I tried to see if the mechanism really checked if the signature matches a named device, and if at connection time it is validated if a device is signed by the expected certificate chain.
    I have now tried to see if I could spill over to another online entity (equals a company), if they happen to use the same Root CA provider.
    That is also working as expected. Even if 2 companies share and register the same Root certificate, the connection is rejected when a thing tries to connect to the other company.
    Good.
    Good.
