Project14
Project14
Documents Project14 | Test Instrumentation: Meet the Do-It-Yourself Test Equipment Projects!
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 12 Nov 2018 12:58 AM Date Created
  • Last Updated Last Updated: 14 Nov 2018 3:39 PM
  • Views 1484 views
  • Likes 12 likes
Enter Your Electronics & Design Project for a chance to win a Grand Prize for Originality, a Tool Set, and a $100 Shopping Cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
There's still time to submit your Test Instrumentation  project!
Use Whatever Components You Like in Your Project for a Chance to Win a Tool Kit and a $100 Shopping Cart to Your element14 Store!
One Grand Prize Winner Wins an 18-PC Tool Kit Plus a $100 Shopping Cart! Three First Place Winners Win a 6-PC Tool Kit Plus a $100 Shopping Cart!
18-Piece Journeyman Tool Set (~$327 Value) Plus a $100 Shopping Cart
6-Piece Trim Out Tool Set (~$100 Value) Plus a $100 Shopping Cart
Comfortable and durable tools for the professional Contains one Journeyman side-cutting pliers, one Journeyman diagonal-cutting pliers, one Journeyman long-nose pliers, one Journeyman pump pliers, one adjustable wrench, one phillips-tip screwdriver, one wire-bending screwdriver, two cabinet-tip screwdrivers, one Rapi-DrivRegistered screwdriver, one square-recess tip screwdriver, two nut drivers, one power-return rule, one Klein-KurveRegistered wire stripper/cutter, one protective eyewear, one Powerline work belt, one 10-pocket tool pouch
A quick, portable solution for electricians on the go! 6-Piece set contains one side cutting pliers, one Klein KurveRegistered Wire Stripper, one Phillips-Tip Screwdriver, one Cabinet-Tip Screwdriver, one 4-pocket leather pouch, and a lightweight utility belt Includes: Heavy Duty Side Cutting Pliers (D2000-9NE) Klein-KurveRegistered Wire Stripper (11055) #2 Phillips-Tip Screwdriver, 4-Inch (102 mm) round shank (603-4) 4-Pocket Leather Tool Pouch, riveted for extra durability (5119) Lightweight Utility Belt (5204)
Submit your project from now until anytime on November 14th to have your project featured here!
The Projects:
A Simple DC Electronic load for the experimenter's Shop.  by jw0752
MinMax - Calibration Box by rsc
tinyMonster - Analog Precision opto-isolator by mahmood.hassan
Frequency Counter (Square, Sine or Tri angular) by mahmood.hassan
Voltmeter (>1mV) with user selectable range using Micro:bit (Part-1) & Precision analog opto-isolation amplifier using HCNR200/201  by mahmood.hassan
"No Lies" IR Thermometer by koudelad
  • "No lies" IR Thermometer - part I
  • "No lies" IR Thermometer - part II
  • "No lies" IR Thermometer - part III
  • "No lies" IR Thermometer - part IV
µBOSS .... Test Instrumentation ... micro:bit by dougw
Automated Cable Tester by phoenixcomm
  • Automated Cable Test System .. part 1
  • Automated Cable Test System .. part 2
  • Automated Cable Test System .. part 3
  • Automated Cable Test System .. part 4
  • Automated Cable Test System .. part 5
  • Automated Cable Test System .. part 6
Tiny DVM by dubbie
  • TinyDVM#1
  • TinyDVM#2
  • TinyDVM#3 : Colour and Final Case
  • TinyDVM#4 : Graphical Display
  • TinyDVM#5 : Web Display of Voltages
Simple resistance measurement with the micro bit and voltage divider by kk99
Wireless voltage measurement with microbit by kk99
micro:bit as Pass / Fail indicator in an automated test setup by Jan Cumps
SCPI on a Linux Board - Part 4b: TCP/IP SCPI and Instrument Service 100% Working by Jan Cumps
Working Prototype of a Kelvin (4-Wire) Milliohm Meter by fmilburn
A Transistor Load by jc2048
Project PITS by three-phase
  • diytestinstruch
  • mahmood.hassan
    mahmood.hassan over 7 years ago +4
    Thanks
  • 14rhb
    14rhb over 7 years ago +4
    A great and diverse range of projects here. Rod
    shabaz over 7 years ago +1
    Very useful collection of projects! : )
  • 14rhb
    Rod
  • 14rhb
    Rod
