Industrial Automation
Blog Connect to AVNET iotconnect.io with Python IoTConnectSDK and BLE - part 1: overview and goal
  • Date Created: 7 May 2021 4:00 PM Date Created
  • Views 2893 views
  • Comments 6 comments
  • ble
  • iiot
  • python
  • rsl10
  • smartedge
  • gateway
  • iot
7 May 2021
AVNET's iotconnect.io cloud platform is an online service that you can use to send data to, and then show it on a dashboard. In this blog series I'm learning the Python SDK and integrating BLE devices.
In this post: what do I want to achieve, and what will I need to get there?
Goal
I got a kit from Avnet with a SmartEdge IIOT Gateway and an ON Semiconductor RSL10 BLE sensor kit.
The SmartEdge and the RSL10 are preloaded with an example specific for this combination.
My goal is to understand the example, evaluate the solution and extend it.
I've played with the Python sample code that runs on the SmartEdge and understand most of it by now.
My first posts will focus on the SDK part that gets the device provisioned on the iotconnect.io cloud.
I learned something new while investigating: how to remotely debug a Python script running on a Linux box with Visual Studio.
Just like the standard Python SDK example that is pre-installed on SmartEdge IIOT Gateways, this example uses TPM (Trusted Platform Module) security.
I'll review how that works in a breakout post.
If I do everything correctly, my board will appear on this map and the data measured by the RSL10 sensors will be available...
The Python SDK with On Semiconductor RSL10 BLE article series Industry
part 2: WiFi Provisioning
part 3: Adding a Module (RSL10)
part 4: Talk BLE to the On Semi RSL10 Sensor Kit
part 5: A Cloud User Experience Example
part 6: Register as a Gateway Device
part 7: Register a Gateway and Client Devices
part 8: Get BLE Image from Camera and Send to Cloud
The NODE-Red SDK article series Industry
register a Thing and connect to IoTConnect.io cloud
part 2: create an account and log on to the portal
part 3: set up the thing and its interface in the cloud
part 4: set up Node-RED and first exchange
interact with IoTConnect.io cloud
part 5: online dashboard
part 6: rules and alerts
part 7: messages and commands from the cloud
safer connections with certificates
part 8a: safer connect with Self Signed Certificates
part 8b: safer connect with CA certificates Y
commercial and industrial scale: outsource certificate generation and programming to subcontractors and suppliers
part 9a: Outsource Certificate Signing in IIoT Supply Chain Y
part 9b: IIoT supply chain and Certificates - Create Ca Root certificate, Load to IoTConnect Cloud and Validate Y
part 9c: IIoT supply chain and Certificates - Create an Intermediate CA Certificate for your Subcontractor Y
part 9d: IIoT supply chain and Certificates - Subcontractor Generates a Thing Certificate for Your Device Y
part 9e: IIoT supply chain and Certificates - Test! Y
commercial and industrial scale: Trusted Platform Module (TPM) Authentication
part 10: Trusted Platform Module (TPM) Security Y
Infineon SLx9670 Trusted Platform Module (TPM) for IoT Security Y
Infineon Trust Platform Module + Raspberry Pi 3 B - Review (road test) Y
Infineon SLx9670 Trusted Platform Module (TPM) on Debian 11 "bullseye" - part1: OS and Azure Cloud validation Y
Infineon SLx9670 Trusted Platform Module (TPM) on Debian 11 "bullseye" - part2: Trusted Software Stack (tss) Y
Infineon SLx9670 Trusted Platform Module (TPM): TSS Programming in C, with cross-compile and remote debug in Eclipse Y
part 11: Act as Gateway with Clients Y
The Automate Device Provisioning and Cloud Configuration article series Industry
Automatic Provisioning with REST API Y
    Jan Cumps over 5 years ago +1
    I have the majority of the functions up and running. The device connects, logs, and can be checked from the online world map dashboard. www.youtube.com/watch
    Example of user experience demo: a worker approaches a machine. Operation and service instructions are pushed to her tablet: www.youtube.com/watch
  • fmilburn
    fmilburn over 5 years ago in reply to Jan Cumps
    Cool
  • fmilburn
    Cool
