RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum What Is Your Favorite Roadtest of 2023?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 19 replies
  • Subscribers 2740 subscribers
  • Views 3611 views
  • favorite roadtest of 2023
rscasny
rscasny over 2 years ago
At the end of the year, I like to reflect on what products have been roadtested in the past 12 months. I usually ask for community member input. Hence, this poll.
Given all the roadtests we have done, it may be a challenge to pin it down to one favorite one. But give it a try. Ask yourself, which one really stands out for you? Or, which one after seeing the roadtest made you want to have it.
If you need to, feel free to leave a more detailed comment. Thanks.
Here are links to the roadtests for your convenience:
ADI ADALM2000 Data Acquisition Learning Module
ADI Digital Isolator Eval Kit - MAX2256XAEVKIT#
ADI Energy Harvesting EVB ADP5091-2-EVALZ
ADI Software-Defined Radio Learning Module ADALM-Pluto
ADI Ultra-Low-Power RTC with Integrated Power Switch
Aim-TTi Source Measure Unit SMU4201
Arduino GIGA R1 WiFi
Arduino Uno R4 Minima
Avnet RASynBoard EVK AES-RASYNB-120-SK-G
Avnet ZUBoard 1CG Development Kit
Beagleboard BeaglePlay, BeagleConnect Freedom, and Grove Sensors
Cytron MAKER PI RP2040
Digilent Analog Discovery 3 (
Digilent Eclypse Z7 and ZmodDigitizer
Infineon ModusToolbox Software with the Infineon PSoC 62S2 Evaluation Kit
Keysight Battery Emulator and Profiler E36731A
Megger EV Charger Checker – EVCC300
Microchip PolarFire SoC Video Kit MPFS250-VIDEO-KIT
Multicomp Pro - Applications of Waveform Generators
Multicomp Pro MP780892 Air Quality Meter
Nordic nPM1300 Power Management IC Eval Kit
Nordic nRF7002-DK Dev kit for the Wi-Fi6 Companion IC
onsemi Type-C Interface Detection Solution EVB FUSB302BGEVB
Power Integrations Home Appliance and Industrial Power Reference Design Kit
Renesas RX671 MCU Eval Kit (EK-RX671)
Renesas Solution Starter Kit for RX23E-A
Rohm Buck Converter Eval Kit BD9G500EFJ-EVK-001
Schurter Smart Connector DT31
STMicroelectronics STM32U5A9J-DK Discovery Kit
Tektronix Mixed Signal Oscilloscope MSO22 2-BW-70
Toshiba Over Temperature Detection IC ThermoflaggerTM Eval Board
Weller WXsmart Smart Soldering Platform
Wiha Insulated Screwdriver Set
  • JWx
    JWx over 2 years ago in reply to misaz
    ok, my bad - it is in the datasheet, under "required equipment", not in the roadtest page (I have remembered it wrong):
    • One pico ammeter for measuring the current
    I personally think that clocks in general are fascinating - they can be running early, late, they can generate frequency jitter and/or wander - but this is not something that can be easily measured using hobbyist equipment (my thesis was about synchronization of network equipment - but purely theoretical, unfortunately)
  • misaz
    misaz over 2 years ago in reply to JWx
    pico amper meter was not needed since consumption is in range of tens of nano amps and you can test RTC differently. Power consumption test is not needed.
    In my opinion it is because RTC chips are boring in general. They do not blink, move, beep and they are not programable.
  • JWx
    JWx over 2 years ago in reply to balajivan1995
    IIRC it was suggested at some stage that picoamperometer is needed for RTC testing - that could be the cause of low applicant number...
  • balajivan1995
    balajivan1995 over 2 years ago in reply to me_Cris
    Just checked - It has the highest number of applicants and ADI Low Power RTC has the lowest number of applicants.
  • obones
    obones over 2 years ago
    I quite liked the ADALM-Pluto even if I missed out on that one because my email replies got lost in the "tubes"... Ah well, better luck next time.
    Jan Cumps over 2 years ago in reply to javagoza
    javagoza said:
    I would have liked to debut as a road tester
    I think you 'd like it. Less entertaining than a challenge. And less competitive (I like that sometimes). An opportunity to dig deep in one subject.
    Jan Cumps over 2 years ago in reply to me_Cris
    I liked that too. And the Renesas RX23E-A where I participated. But only one vote. It went to the source meter.
  • me_Cris
    me_Cris over 2 years ago
    For some time I have been looking for and appreciating tools, so Weller platform (I can't even believe how expensive something like this is Dizzy face).
    Most favorite
  • embeddedguy
    embeddedguy over 2 years ago in reply to Fred27
    yeah, it seems so..
  • BigG
    BigG over 2 years ago in reply to beacon_dave
    Yep, I did that too. I purchased the ADALM2000 after being impressed by what I read in the roadtest reviews.
