Project14
Project14
Documents Project14 | Sensors: Meet the Projects that Sense the World Around Them!
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 12 Nov 2020 9:44 PM Date Created
  • Last Updated Last Updated: 17 Nov 2020 11:41 PM
  • Views 1631 views
  • Likes 12 likes
Sensors
Project14 Home
Monthly Themes
Monthly Theme Poll
There's Still Time to Submit Your Sensors Project!
Submit your project from now until anytime on Nov 16th to have your project featured here!
  • Build sensor related projects. You can design a sensors, use a sensor in a control system, or do something interesting with sensor data.
You will be judged on the basis of the following criteria:
  • Follow the Steps - Did they provide the steps it took to complete the project (text, video, or images) and/or schematics.
The Projects:
Spectrography using the epc901 High Speed Line Image Sensor  by fmilburn:
Real-Time Laboratory Monitoring  by rahulkhanna:
The Protector by ajayvishaal:
The Protector
Wio Terminal Sensor Fusion by ralphjy:
  • Wio Terminal Sensor Fusion - Introduction
  • Wio Terminal Sensor Fusion - Sensor Integration
  • Wio Terminal Sensor Fusion - Remote Data Display and Control using Blynk
  • Wio Terminal Sensor Fusion - Remote Data Display and Control using Blynk continued
  • Wio Terminal Sensor Fusion - TinyML Keyword Spotting Part 1
  • Wio Terminal Sensor Fusion - TinyML Keyword Spotting Part 2
  • Wio Terminal Sensor Fusion - Project Wrap Up
Motion Control Gimbal by harjinagi:
Pets' Tap Water System by  filippoaiello :
Designing a 16 channel temperature sensor array  by rsc:
Designing a 16 Channel Temperature Sensor Array
Yummy yogurt with temperature control  by  redcharly :
Cat Detector Using Sand by  dubbie:
  • Cat Detector Using Sand #1 : The Idea
  • Cat Detector Using Sand #2 : The Implementation
  • Cat Detector Using Sand #3 : The Results
Fast Easy Grafana  by  armour999:
Fast Easy Grafana
Light up Coaster using sound sensor by  carmelito:
  • Light up Coaster using sound sensor
  • Light up Coaster using touch sensor and Conductive PLA
Hall sensor AS5600 for Game Wheel.  by  maxpowerr:
Smarthab Thermostat? Or maybe a better name Life Support: Monitor and Control.  by  phoenixcomm :
Sensor Kit For BRACCIO by  milosrasic98 :
Sensor Kit for Braccio
A generic device-health monitor: Monitoring a GNSS receiver in the field by  gustavovelascoh:
ARDUINO HEARTBEAT MONITORING SYSTEM by  meera_hussien:
Arduino Heartbeat Monitoring System
  • sensorsch
    dubbie over 5 years ago +3
    There are some pretty good sensor projects here. Very impressive. I particularly liked the line image sensor and the laboratory monitor but they are all very good sensor systems. The light up coaster is…
  • rahulkhanna
    rahulkhanna over 5 years ago +1
    Hi tariq.ahmad , any updates on the results? Just curious!
  • rahulkhanna
    Hi tariq.ahmad, any updates on the results? Just curious! image
  • rahulkhanna
